Home » Eclipse Projects » EclipseLink » Error in implementation(?): Calling Stored Procedures in FireBird 2.1(...results in syntax error)
Error in implementation(?): Calling Stored Procedures in FireBird 2.1 [message #654343] Tue, 15 February 2011 05:06 Go to next message
Calling a Stored Procedure in FireBird 2.1 results in "SQL error code = -104":
Local Exception Stack:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.1.1.v20100817-r8050): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: org.firebirdsql.jdbc.FBSQLException: GDS Exception. 335544569. Dynamic SQL Error
Token unknown - line 1, column 33
Error Code: 335544569
Call: EXECUTE PROCEDURE LOGIN1(param1 = ?, param2 = ?)
bind => [onlinetester, test]
Query: DataReadQuery(name="test_proc
Apparently EclipseLink generates the following syntax EXECUTE PROCEDURE LOGIN1(param1 = ?, param2 = ?) which isn't proper FireBird 2.1 syntax and should be called via EXECUTE PROCEDURE LOGIN1 ?, ?.
I've described the details of this problem on StackOverflow: http://stackoverflow.com/questions/4960049/executing-stored- procedures-in-firebird-using-jpa-namedstoredprocedurequery
Re: Error in implementation(?): Calling Stored Procedures in FireBird 2.1 [message #654403 is a reply to message #654343] Tue, 15 February 2011 10:32 Go to previous messageGo to next message
From the other post,
@StoredProcedureParameter(queryParameter = "param1", name = "USER_NAME", direction = Direction.IN, type = String.class),
is telling EclipseLink to execute the procedure using named database parameters. If instead of
EXECUTE PROCEDURE LOGIN1("USER_NAME= ? ) you want EXECUTE PROCEDURE LOGIN1(?) try by removing the name from the StoredProcedureParameter definition, leaving it unnamed:
@StoredProcedureParameter(queryParameter = "param1", direction = Direction.IN, type = String.class),
Best Regards,
Chris
Re: Error in implementation(?): Calling Stored Procedures in FireBird 2.1 [message #654509 is a reply to message #654403] Wed, 16 February 2011 01:12 Go to previous messageGo to next message
Got: "Call: EXECUTE PROCEDURE LOGIN1(param1 = ?)" but the error remains the same. Actually the included parenthesis aren't valid FB SQL syntax. Valid FB SQL syntax should look like "EXECUTE PROCEDURE LOGIN1 ?"
Best Regards,
Alex
Re: Error in implementation(?): Calling Stored Procedures in FireBird 2.1 [message #654682 is a reply to message #654343] Wed, 16 February 2011 11:24 Go to previous messageGo to next message
Found a solution/workaround: http://stackoverflow.com/questions/4960049/executing-stored- procedures-in-firebird-using-jpa-namedstoredprocedurequery/5 019044#5019044
[Updated on: Wed, 16 February 2011 11:24] by Moderator
Re: Error in implementation(?): Calling Stored Procedures in FireBird 2.1 [message #654730 is a reply to message #654682] Wed, 16 February 2011 15:39 Go to previous messageGo to next message
Sorry, only after you found the workaround using the native API to call addUnamedArgument directly was I able to check that EclipseLink is only using named arguments for @StoredProcedureParameter.
Please vote for 294772
- EclipseLink does not support unnamed parameters in @NamedStoredProcedureQuery
to have this fixed.
Best Regards,
Chris
Re: Error in implementation(?): Calling Stored Procedures in FireBird 2.1 [message #654749 is a reply to message #654730] Wed, 16 February 2011 17:38 Go to previous message
Thx anyway!
Previous Topic:Does deleting a relationsip remove the dependant object from the database?
Next Topic:double insert
Current Time: Wed Nov 05 19:01:33 EST 2025
Powered by FUDForum. Page generated in 0.03104 seconds
