Home » Modeling » Modeling (top-level project) » [EMF] "@generated NOT" does not work
Re: [EMF] "@generated NOT" does not work [message #654418 is a reply to message #654305] |
Tue, 15 February 2011 16:58 |
Hugo Melo Messages: 14 Registered: July 2009 |
Hi Ed,
I've created this topic because I didn't find the same behaviour anywhere. Fortunately, I found the cause and I'm sharing with you:
* This is just a example
Project name = "project"
Model name = "model"
Project source code = "project.src"
By default, the generated model code goes to "/project/src". This is defined in the property "Model -> Model Directory", on the genmodel file, as well as the edit code goes to "/project.edit/src".
But in my project, the model code should be generated in "project.src.modelcode" package and the edit code should be generated in "project.src.modelcode.provider". To accomplish this, I have appended the "Model Directory" and the "Edit Directory" properties of the genmodel to "/project/src/modelcode".
This way, the generated code goes to right place, but with some minor errors. And in this way, the "generated NOT" marked methods are still overwritten after each re-gereration action.
To solve the erros and problems, I've just edited the genmodel correctly. Instead change the model or edit directory, I've changed the root EPackage ("model") property, labelled as "Base Package", and setted his value to "modelcode".
I still dont know why the problem occurs, but I can correct and reproduce it.
Hugo Melo
Re: [EMF] "@generated NOT" does not work [message #1728322 is a reply to message #654418] |
Sat, 02 April 2016 00:05 |
Paul Roubekas Messages: 207 Registered: March 2012 Location: Chattanooga, TN USA |
I am on Eclipse 4.5.2
EMF 2.11.2
Windows 7 SP1
I have a similar issue on my enum with the constructor. When "NOT" is used method is re-written. When @generate is removed the re-write does not happen.
This preserves source code changes, but add a new MyConstants with the original signature.
* Only this class can construct instances.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
private MyConstants(int value, String name, String literal, BigDecimal constantValue, BigDecimal uncertainty, String unitOfMeasure) {
this.value = value;
this.name = name;
this.literal = literal;
this.constantValue = constantValue;
this.uncertainty = uncertainty;
this.unitOfMeasure = unitOfMeasure;
* @generated NOT
this.value = value;
this.name = name;
Oxygen 3a
Windows 10
Re: [EMF] "@generated NOT" does not work [message #1728333 is a reply to message #1728322] |
Sat, 02 April 2016 06:36 |
Ed Merks Messages: 33216 Registered: July 2009 |
Paul,
I can't reproduce that. E.g., if I change an enum's constructor and
then regenerate I end up with two constructors:
* @generated
private X(int value, String name, String literal) {
this.value = value;
this.name = name;
* @generated NOT
private X(int value, String name, String literal, float x) {
this.value = value;
this.name = name;
Of course the new constructor I wrote does not have the same name and
signature as any generated constructor so marking it as @generated NOT
is misleading. Perhaps something like this is more sensible:
* @generated
this.value = value;
this.name = name;
* Only this specialized constructor should be used.
this(value, name, literal);
// Do something with x....
> EMF 2.11.2
> Windows 7 SP1
> does not happen.
> original signature.
> this.value = value;
> this.name = name;
> original signature.
> * @generated NOT
> this.value = value;
> this.name = name;
Ed Merks
Re: [EMF] "@generated NOT" does not work [message #1728335 is a reply to message #1728333] |
Sat, 02 April 2016 08:30 |
Ed Willink Messages: 7670 Registered: July 2009 |
EMF has a mostly helpful generation setting whereby unchanged files are
not rewritten. For this purpose, comment and annotation changes are not
considered changes. It is therefore possible to be thoroughly puzzled as
to why your 'improvements' are having no effect. A similar no-change
problem occurs if there is a model path typo and so you are looking in
one place while generation is generating somewhere else.
You can avoid both of these confusions by making sure that you delete
the files that you hope to generate before generating them. (Once you've
finished debugging your tooling, make sure to restore the original files
and regenerate so that any old explicit/implicit @generated NOT code is
not lost.)
NB removal of @generated is a comment change, leaving an implicitly
@generated NOT segment of code.
Ed Willink
On 02/04/2016 07:36, Ed Merks wrote:
> Paul,
> * @generated
> this.value = value;
> this.name = name;
> * @generated NOT
> this.value = value;
> this.name = name;
> * @generated
> this.value = value;
> this.name = name;
>> EMF 2.11.2
>> Windows 7 SP1
>> does not happen.
>> unitOfMeasure) {
>> this.value = value;
>> this.name = name;
>> * @generated NOT
>> unitOfMeasure) {
>> this.value = value;
>> this.name = name;
Current Time: Sun Sep 22 10:51:16 GMT 2024
Powered by FUDForum. Page generated in 0.03531 seconds
