Home » Modeling » Graphiti » Send to Front or Back(Supported for Shapes, but not for Connections ?)
Send to Front or Back [message #654274] Mon, 14 February 2011 15:51 Go to next message
The method Graphiti.getPeService().sendToFront allows one to send a shape to the front, there is also a method to send a shape to the back. I have a Connection that I need to send to the back, but cannot find a method to do this. What would b the best way to achieve this ?
Jos
Re: Send to Front or Back [message #654326 is a reply to message #654274] Tue, 15 February 2011 03:13 Go to previous messageGo to next message
Graphiti renders all connections onto one specific layer in the diagram,
that's the reason why there is no send to back/front for them.
Michael
Re: Send to Front or Back [message #654826 is a reply to message #654326] Thu, 17 February 2011 05:26 Go to previous messageGo to next message
You seem to be right, even when I call sendToFront() for a shape, it still is behind the connections.
This does mean (at least for my case) that connections are always in front of the shapes. Is there a way to make the connection layer be under the shapes layers, such that all connections are underneath the shapes.
Jos
Re: Send to Front or Back [message #655754 is a reply to message #654826] Tue, 22 February 2011 09:41 Go to previous message
Hi Jos,
have a look at
ScalableRootEditPartAnimated
There exists a field
connectionLayerOnTop
which defaults to true.
Currently there is no API to change the value.
(To try it, you might use the debugger (change value...) or reflection)
You might open a bugzilla request for introducing API to change the value
of the field.
Best, Tim
Previous Topic:Interacting With A Connection
Next Topic:Graphiti API
Current Time: Mon Oct 27 06:29:08 EDT 2025
Powered by FUDForum. Page generated in 0.07171 seconds
