Deploy on hosted server leads to AccessControlException [message #654112] |
Mon, 14 February 2011 09:10 |
I am able to deploy my RAP .war to my local tomcat but when uploading to
a hosted server at my web hotel I get the stacktrace below. I suspect
this is due to insufficient privileges on this server
(clearPrefixedSystemProperties) but I am wondering if/how I can work
around this problem or if I cannot use this web hotel for hosting my
deployed RAP application. All suggestions are welcome!
/Ola
java.security.AccessControlException: access denied
(java.util.PropertyPermission * read,write)
java.security.AccessControlContext.checkPermission(Unknown Source)
java.security.AccessController.checkPermission(Unknown Source)
java.lang.SecurityManager.checkPermission(Unknown Source)
java.lang.SecurityManager.checkPropertiesAccess(Unknown Source)
java.lang.System.getProperties(Unknown Source)
org.eclipse.equinox.servletbridge.FrameworkLauncher.clearPre fixedSystemProperties(FrameworkLauncher.java:638)
org.eclipse.equinox.servletbridge.FrameworkLauncher.setIniti alProperty(FrameworkLauncher.java:587)
org.eclipse.equinox.servletbridge.FrameworkLauncher.buildIni tialPropertyMap(FrameworkLauncher.java:534)
org.eclipse.equinox.servletbridge.FrameworkLauncher.start(Fr ameworkLauncher.java:353)
org.eclipse.equinox.servletbridge.BridgeServlet.init(BridgeS ervlet.java:65)
javax.servlet.GenericServlet.init(GenericServlet.java:212)
sun.reflect.GeneratedMethodAccessor45.invoke(Unknown Source)
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
java.lang.reflect.Method.invoke(Unknown Source)
org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil .java:270)
org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil .java:269)
java.security.AccessController.doPrivileged(Native Method)
javax.security.auth.Subject.doAsPrivileged(Unknown Source)
org.apache.catalina.security.SecurityUtil.execute(SecurityUt il.java:302)
org.apache.catalina.security.SecurityUtil.doAsPrivilege(Secu rityUtil.java:163)
org.apache.catalina.security.SecurityUtil.doAsPrivilege(Secu rityUtil.java:117)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:298)
org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler. java:190)
org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.ja va:291)
org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java :776)
org.apache.jk.common.ChannelSocket.processConnection(Channel Socket.java:705)
org.apache.jk.common.ChannelSocket$SocketConnection.runIt(Ch annelSocket.java:898)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:690)
java.lang.Thread.run(Unknown Source)
Re: Deploy on hosted server leads to AccessControlException [message #654143 is a reply to message #654142] |
Mon, 14 February 2011 11:12 |
Thanks for the answer Ralf. I will contact the hosting service and get
their comments on this.
Do you (or anyone else) have suggestions for companies with hosting
services that are confirmed to work with deployed RAP applications?
/Ola
On 2011-02-14 11.35, Ralf Sternberg wrote:
> Hi Ola,
> obviously, you are not allowed to read all system properties because your
> security policy is too restrictive. The servlet bridge calls
> System.getProperties() at some point and you're out.
> I personally doubt that such a restrictive policy can be an acceptable
> basis for hosting applications.
> Regards, Ralf
Re: Deploy on hosted server leads to AccessControlException [message #654150 is a reply to message #654143] |
Mon, 14 February 2011 11:52 |
I got this reply from my web hotel:
You are not allowed to write properties as that would change settings
for other users in the shared instance.
If you run the following it requires read and write:
Properties sysProps = System.getProperties();
If you change to the following it only requires read:
Properties myProps = new Properties();
This looks weird to me. Can anyone with more experience comment on this?
Also, it leaves me uncertain how to solve my problem of deploying so I'd
value any input on this matter!
/Ola
> Cheers,
> /Ola
>> Hi Ola,
>> Regards, Ralf
FUDForum. Page generated in 0.03610 seconds
