Home » Modeling » Graphiti » Disabling Undo
Disabling Undo [message #654034] Sun, 13 February 2011 06:43 Go to next message
I am trying to disable undo in my Graphiti editor. I have redefined canUndo() to return false in all features. Disregarding this, the Undo option in the default popup menu is still enabled and performing an undo. I see several types of undo: Undo Layout, Undo Update, Undo Add and Undo Do. I don't understand why Graphiti still assumes it can undo things.
Is there anything else that I can do to disable the undo command? I just want it to be removed from the standard popup menu.
Jos
Re: Disabling Undo [message #654216 is a reply to message #654034] Mon, 14 February 2011 10:50 Go to previous messageGo to next message
I am still wondering why Graphiti allows undo while all features are non-undo-able, but at least I found a reasonable workaround to disable the Undo menu option. It works as follows:
  1. Define your own subclass of DiagramEditorContextMenuProvider
  2. Override the method addDefaultMenuGroupUndo(IMenuManager manager) to do nothing.
  3. Define your own subclass of DiagramEditor.
  4. Override the method createContextMenuProvider() to return a new instance of your own subclass of DiagramEditorContextMenuProvider.
If needed, you can tweak the menus further by overriding other methods in the subclass of DiagramEditorContextMenuProvider
Jos
Re: Disabling Undo [message #654522 is a reply to message #654216] Wed, 16 February 2011 03:08 Go to previous messageGo to next message
Jos,
it is not possible for the framework to determine if really all features are
not undoable or if there isin the end not one single feature in a certain
selection or whatever state that could be undone. That's simply the reason.
Of course could we introduce a flag to disable undo that could be set by a
tool, but as of today such a flag does not exist.
Michael
Re: Disabling Undo [message #658720 is a reply to message #654522] Wed, 09 March 2011 10:40 Go to previous messageGo to next message
Michael,
Each feature that is executed can directly be asked by the framework whether it is undo-able (the canUndo() method is there). This way the framework should be able to know whether an applies feature is undo-able and can remove (or disable) the Undo option. Ain't that right?
Jos
Re: Disabling Undo [message #658723 is a reply to message #658720] Wed, 09 March 2011 10:48 Go to previous messageGo to next message
In principle yes, the problem starts you you have to determine all features
that are available for a tool. There's no guarantee that you get the full
set in any state you ask the tool for all its features. Even if you could
get really all features and they all return false on canUndo() in that state
you could not guarantee that they there is not a single other state in which
one feature will return true.
Michael
"Jos Warmer" wrote in message news:il86ku$enh$1@news.eclipse.org...
Michael,
Jos
Re: Disabling Undo [message #730855 is a reply to message #658723] Thu, 29 September 2011 07:38 Go to previous messageGo to next message
I would like to know if there is any way to disable undo button in the context menu and the tool bar.
Please note we are not extending DiagramEditor for our Graphiti editor.
We tried returing false in the hasChanges() method of the features but it did not help.
Saurav
Re: Disabling Undo [message #730861 is a reply to message #730855] Thu, 29 September 2011 07:45 Go to previous messageGo to next message
Simply implement the Graphiti interface ICustomUndoableFeature (available in
Graphiti 0.8.0) in your feature and return false for canUndo() and
canRedo().
HTH,
Michael
"saurav" schrieb im Newsbeitrag news:j61klo$mk5$1@news.eclipse.org...
did not help.
Saurav
My Blog http://codifyit.blogspot.com/
Follow me: http://twitter.com/sauravs
Re: Disabling Undo [message #732247 is a reply to message #730861] Tue, 04 October 2011 06:23 Go to previous messageGo to next message
Hi Jos,
As suggested by you, we were able to disable the Undo option in the context menu by creating our own DiagramEditorContextMenuProvider and overriding the method.
We also have to disable the Undo and Redo button in the toolbar, Please suggest how to do it.
Harish
Re: Disabling Undo [message #1255605 is a reply to message #730861] Mon, 24 February 2014 11:20 Go to previous messageGo to next message
Hi Michael,
Implementing ICustomUndoableFeature interface in each feature and retirning false in canUndo and canRedo method does not help!!
Surya
Re: Disabling Undo [message #1258649 is a reply to message #1255605] Thu, 27 February 2014 10:54 Go to previous messageGo to next message
Surya,
can you provide some more details? At least in my news reader this appears
as single message without the thread context...
Michael
Re: Disabling Undo [message #1259377 is a reply to message #1258649] Fri, 28 February 2014 05:10 Go to previous message
Hi Michael,
I need to disable "undo and redo" context menus from diagram editor.
I tried the following two methods, and does not work in my case.
1. As mentioned in this tread, my features implement ICustomUndoableFeature, and canUndo() and canRedo() methods return false. Still, I can see Undo and Redo menus enabled in the diagram context menu!!
public class TaskMoveFeature extends DefaultMoveShapeFeature implements ICustomUndoableFeature {
	public boolean canUndo(IContext context) {
		return false;
	public boolean canRedo(IContext context) {
		return false;
2. I also tried to extend DiagramEditorContextMenuProvider and override addDefaultMenuGroupUndo method, which infact does nothing.
public class IdmTaskFlowEditorContextMenuProvider extends DiagramEditorContextMenuProvider {
	public IdmTaskFlowEditorContextMenuProvider(EditPartViewer viewer,
                 ActionRegistry registry,
                 IConfigurationProvider  configurationProvider) {
		super(viewer, registry, configurationProvider);
	protected void addDefaultMenuGroupUndo(IMenuManager manager) {
		// do nothing
I am not sure if this will work but I tried to set the context menu from configureGraphicalViewer method of IdmDiagramEditor(extends DiagramEditor) as below, but how can I get IConfigurationProvider in parameter 3.
	protected void configureGraphicalViewer() {
		super.configureGraphicalViewer();
	        getGraphicalViewer().setContextMenu(new IdmTaskFlowEditorContextMenuProvider(getGraphicalViewer(),
					getActionRegistry(), ???));
Any workaround will be appreciated.
Surya
[Updated on: Fri, 28 February 2014 07:55] by Moderator
Previous Topic:createContextMenuProvider Method in DiagramEditor not available
Next Topic:Reading created model
Current Time: Fri Sep 19 05:28:09 EDT 2025
Powered by FUDForum. Page generated in 0.05075 seconds
