[Acceleo 3] Illegal Signature issue in Service Wrapper Query [message #653658] |
Thu, 10 February 2011 15:18 |
dieppi Messages: 27 Registered: November 2010 |
i've created the following method
public boolean hasTriggers(Set<Transition> transition)
I generated a service wrapper for my java class file but after generation a syntax error is in generated invoke method query
[query public hasTriggers(arg0 : Set(OclAny)) : Boolean
= invoke('services.StringServices', 'hasTriggers(java.util.Set)', Sequence{arg0}) /]
The error code is
Description Resource Path Location Type
illegal operation signature: (invoke(String, String, Sequence(Set(OclAny)))) stringservices2.mtl /de.test.acceleo/src/services line 52 Acceleo Problem
What is wrong here?
Best regards
Maik
[Updated on: Thu, 10 February 2011 17:59] Report message to a moderator
Re: [Acceleo 3] Illegal Signature issue in Service Wrapper Query [message #653851 is a reply to message #653658] |
Fri, 11 February 2011 14:17 |
--------------080300080103050801030408
Hi Maik,
Which version of Acceleo are you using? I know that this has been fixed
in 3.0.2 and 3.1.0 ... not sure about 3.0.1.
Laurent Goubet
Obeo
On 10/02/2011 16:18, Maik wrote:
> So now i want generate a service wrapper for my java class file. But
> Sequence{arg0}) /]
> The error code is
> What is wrong there?
> Best regards
> Maik
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------080300080103050801030408--
Re: [Acceleo 3] Illegal Signature issue in Service Wrapper Query [message #654569 is a reply to message #653977] |
Wed, 16 February 2011 10:44 |
--------------040908010209000905060500
Hi Maik,
The version 3.0.2 will be available starting today (later this afternoon
(CET)) from the update site
http://download.eclipse.org/modeling/m2t/acceleo/updates/rel eases/3.0
The version 3.1.0M5 is the latest milestone, 3.1.0M6 will be available
on march, 18. 3.1.0 finale will be available in June.
Laurent Goubet
Obeo
On 12/02/2011 10:45, Maik wrote:
> Hi Laurent,
> i use 3.0.1 version from update site. When will version 3.1.x availiable
> from update site? in download area stable build 3.1.x M5 is availiable.
> Best regards
> Maik
--------------040908010209000905060500--
FUDForum. Page generated in 0.03310 seconds
