Home » Modeling » TMF (Xtext) » Creating grammar mixin
Creating grammar mixin [message #653381] Wed, 09 February 2011 10:25 Go to next message
I try to mix some grammars. So I use a grammar for the Data description:
Data.xtext
grammar de.foo.common.Data with org.eclipse.xtext.common.Terminals
generate data "[url]http://www.foo.de/common/Data[/url]"
Datamodel:
  (types+=Type)*;
Type:
  DataType | Entity;
DataType:
  "datatype" name=ID;
Entity:
  "entity" name=ID "{"
    (features+=Feature)*
Feature:
  type=[Type|ID] name=ID;
And another for the User:
User.xtext
grammar de.foo.common.User with org.eclipse.xtext.common.Terminals
generate user "[url]http://www.bizware.de/common/User[/url]"
Usermodel:
	(users+=User)*;
User:
  "User" name=ID "!";
Finally I want to reuse the definition in a new grammar Base:
Base.xtext
grammar de.foo.common.Base with de.foo.common.Data,de.foo.common.User
generate base "[url]http://www.foo.de/common/Base[/url]"
Model:
  (Datamodel|Usermodel)*;
But Eclipse always told me that it "Couldn't resolve reference to Grammar 'de.foo.common.Data'
Here's my generator (GenerateCommon.mwe2)
module de.foo.common
import org.eclipse.emf.mwe.utils.*
import org.eclipse.xtext.generator.*
import org.eclipse.xtext.ui.generator.*
var grammarURI = "classpath:/de/foo/Base.xtext"
var file.extensions = "base.model"
var projectName = "de.foo.common"
var runtimeProject = "../${projectName}"
Workflow {
    bean = StandaloneSetup {
		platformUri = "${runtimeProject}/.."
	component = DirectoryCleaner {
		directory = "${runtimeProject}/src-gen"
		directory = "${runtimeProject}.ui/src-gen"
	component = Generator {
		pathRtProject = runtimeProject
		pathUiProject = "${runtimeProject}.ui"
		projectNameRt = projectName
		projectNameUi = "${projectName}.ui"
		language = {
			uri = grammarURI
			fileExtensions = file.extensions
			// Java API to access grammar elements (required by several other fragments)
			fragment = grammarAccess.GrammarAccessFragment {}
			// generates Java API for the generated EPackages
			fragment = ecore.EcoreGeneratorFragment {
			// referencedGenModels = "uri to genmodel, uri to next genmodel"
			// the serialization component
			fragment = parseTreeConstructor.ParseTreeConstructorFragment {}
			// a custom ResourceFactory for use with EMF
			fragment = resourceFactory.ResourceFactoryFragment {
			// The antlr parser generator fragment.
			fragment = parser.antlr.XtextAntlrGeneratorFragment {
			//  options = {
			//		backtrack = true
			// java-based API for validation
			fragment = validation.JavaValidatorFragment {
				composedCheck = "org.eclipse.xtext.validation.ImportUriValidator"
				composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
				// registerForImportedPackages = true
			// scoping and exporting API
			// fragment = scoping.ImportURIScopingFragment {}
			// fragment = exporting.SimpleNamesFragment {}
			fragment = scoping.ImportNamespacesScopingFragment {}
			fragment = exporting.QualifiedNamesFragment {}
			fragment = builder.BuilderIntegrationFragment {}
			// formatter API
			fragment = formatting.FormatterFragment {}
			// labeling API
			fragment = labeling.LabelProviderFragment {}
			// outline API
			fragment = outline.OutlineTreeProviderFragment {}
			fragment = outline.QuickOutlineFragment {}
			// quickfix API
			fragment = quickfix.QuickfixProviderFragment {}
			// content assist API
			fragment = contentAssist.JavaBasedContentAssistFragment {}
			// generates a more lightweight Antlr parser and lexer tailored for content assist
			fragment = parser.antlr.XtextAntlrUiGeneratorFragment {}
			// project wizard (optional)
			// fragment = projectWizard.SimpleProjectWizardFragment {
			// 		generatorProjectName = "${projectName}.generator"
			//		modelFileExtension = file.extensions
Any ideas why it doesn' recognize it?
[Updated on: Wed, 09 February 2011 10:26] by Moderator
Re: Creating grammar mixin [message #653397 is a reply to message #653381] Wed, 09 February 2011 11:03 Go to previous messageGo to next message
Hi Martin,
first of all: It is not possible to mixin two languages at the same time
(you should see an error marker in the editor).
You'll have to make sure that your projects are properly set up in order
to mixin another language, e.g. the project with Base has to declare a
dependency to the project that contains Data. Does that help?
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 09.02.11 16:25, schrieb Martin:
> Data.xtext
> [code]
> generate data "http://www.foo.de/common/Data"
> Datamodel:
> (types+=Type)*;
> Type:
> DataType | Entity;
> DataType:
> "datatype" name=ID;
> Entity:
> (features+=Feature)* "}";
> Feature:
> [code]
> And another for the User: User.xtext
> [code]
> generate user "http://www.bizware.de/common/User"
> Usermodel:
> (users+=User)*;
> User: "User" name=ID "!";
> [code]
> Base.xtext
> [code]
> generate base "http://www.foo.de/common/Base"
> Model:
> [code]
> [code]
> Workflow {
> language = {
> uri = grammarURI
> fragments)
> // generates Java API for the generated EPackages fragment =
> // a custom ResourceFactory for use with EMF fragment =
> // options = {
> // backtrack = true
> // java-based API for validation fragment =
> // scoping and exporting API fragment =
> // formatter API fragment = formatting.FormatterFragment {}
> // labeling API fragment = labeling.LabelProviderFragment {}
> // outline API fragment = outline.OutlineTreeProviderFragment {}
> // quickfix API fragment = quickfix.QuickfixProviderFragment {}
> // content assist API fragment =
> content assist fragment = parser.antlr.XtextAntlrUiGeneratorFragment {}
> // project wizard (optional) // fragment =
> // generatorProjectName = "${projectName}.generator" //
> [code]
Re: Creating grammar mixin [message #653398 is a reply to message #653397] Wed, 09 February 2011 11:21 Go to previous messageGo to next message
ah okay, I get it. If I want to declare a common subset I define a own "Common" Xtext Project and then another Xtext Project where I refer via dependencies to the common grammar.
Right?
[Updated on: Thu, 10 February 2011 06:24] by Moderator
Re: Creating grammar mixin [message #653472 is a reply to message #653398] Wed, 09 February 2011 15:48 Go to previous messageGo to next message
Am 09.02.11 17:21, schrieb Martin:
> Right?
That's at least the way that I prefer.
You could even use the very same Xtext project for more than one
language. It's more or less a matter of taste.
Sebastian
Re: Creating grammar mixin [message #653598 is a reply to message #653472] Thu, 10 February 2011 06:24 Go to previous messageGo to next message
what kind of dependency did I need? plugin-dependency, like this manifest.mf:
Require-Bundle: org.eclipse.xtext,
 org.eclipse.xtext.generator;resolution:=optional,
 org.eclipse.emf.codegen.ecore;resolution:=optional,
 org.eclipse.emf.mwe.utils;resolution:=optional,
 org.eclipse.emf.mwe2.launch;resolution:=optional,
 com.ibm.icu;resolution:=optional,
 de.foo.common;bundle-version="1.0.0"
Re: Creating grammar mixin [message #654127 is a reply to message #653598] Mon, 14 February 2011 04:43 Go to previous messageGo to next message
Am 10.02.11 12:24, schrieb Martin:
> manifest.mf:
> [/quote]
It always depends on the features that you use but it looks good to me
at a first glance for a normal Xtext project.
Sebastian
Re: Creating grammar mixin [message #705416 is a reply to message #653472] Fri, 29 July 2011 17:06 Go to previous message
> You could even use the very same Xtext project for more than one language.
Hi Sebastian,
Where can I find detailed instructions on this?
Previous Topic:Hierarchic (java-like) scoping
Next Topic:Local Scope and Shadowing
Current Time: Fri Nov 07 17:23:28 EST 2025
Powered by FUDForum. Page generated in 0.03835 seconds
