Home » Archived » BIRT » Customize a Pie Chart with Java under Eclispe
Customize a Pie Chart with Java under Eclispe [message #653294] |
Wed, 09 February 2011 09:19 |
kkt8 Mising name Messages: 27 Registered: November 2010 |
I'm developing a java plugin for eclipse, where I present the data as a PieChart.
These data are managed and communicated via this same plugin.
I built a collection of Objects which contain my data and I see these datas via a ChartWithoutAxes, withTextDataSet, the Series and PieSeries, I caught an example I am not sure to understand everything, here is a piece of my code:
ChartWithoutAxes cwoaPie = ChartWithoutAxesImpl.create( );
cwoaPie.setSeriesThickness( 20 );
cwoaPie.getBlock( ).setBackground( ColorDefinitionImpl.WHITE( ) );
cwoaPie.setDimension(ChartDimension.TWO_DIMENSIONAL_WITH_DEPTH_LITERAL);
// Plot
Plot p = cwoaPie.getPlot( );
p.getClientArea( ).setBackground( null );
p.getClientArea( ).getOutline( ).setVisible( false );
// Legend
Legend lg = cwoaPie.getLegend( );
lg.getOutline( ).setVisible( false );
lg.getText( ).getFont( ).setSize( 8 );
lg.getClientArea().setBackground(ColorDefinitionImpl.create(255, 255, 204));
((ColorDefinitionImpl)lg.getClientArea().getBackground()).brighter();
lg.setAnchor(Anchor.NORTH_LITERAL);
lg.setItemType( LegendItemType.CATEGORIES_LITERAL );
// Title
cwoaPie.getTitle( ).getLabel( ).getCaption( ).setValue(title);
cwoaPie.getTitle( ).getOutline( ).setVisible( false );
//Base Data Set
List<String> textLabels = new ArrayList<String>();
for (DataObject obj : objData) {
//String label = nameField.getValue(obj);
String label = obj.nameSection;
textLabels.add(label);
TextDataSet categoryValues = TextDataSetImpl.create(textLabels );
// Base Series
Series seCategory = SeriesImpl.create( );
seCategory.setDataSet( categoryValues );
SeriesDefinition sdBase = SeriesDefinitionImpl.create( );
cwoaPie.getSeriesDefinitions( ).add( sdBase );
sdBase.getSeriesPalette( ).shift( -1 );
sdBase.getSeries( ).add( seCategory );
SeriesDefinition sdValue = SeriesDefinitionImpl.create( );
sdBase.getSeriesDefinitions( ).add( sdValue );
List<Double> doubleValues = new ArrayList<Double>();
doubleValues.add(obj.size);
NumberDataSet Values = NumberDataSetImpl.create(doubleValues);
// Pie Series
PieSeries sePie = (PieSeries) PieSeriesImpl.create( );
sePie.setSeriesIdentifier( "fnfn");
sePie.setExplosion(3);
sePie.setDataSet( Values );
sePie.getLabel().getCaption().getFont().setSize(8);
sePie.setLeaderLineStyle(LeaderLineStyle.FIXED_LENGTH_LITERAL);
sePie.setLeaderLineLength(15);
DataPointComponent dpc = DataPointComponentImpl.create( DataPointComponentType.ORTHOGONAL_VALUE_LITERAL,
JavaNumberFormatSpecifierImpl.create( "###.###,00" ) );
sePie.getDataPoint( ).getComponents( ).clear( );
sePie.getDataPoint( ).getComponents( ).add( dpc );
//By default the title of the Value Series is not visible
sePie.getTitle().setVisible(false);
//Mouse over the Serie to Show Tooltips
setTriggering(sePie,lg);
sdValue.getSeries( ).add( sePie);
it works really well although I display my chart with my data entry!
I would just customize it all:
I have 2 types of data eg 5 data "type 1"and 10 data "type 2", I would like in one PieChart, post a first quarter "Type 1" which contains 5 sub-districts with cool colors and 2nd district "type 2" containing 10 sub districts it with warm colors, all representing a PieChart.
how to specify this?
A track?
Thank you
K
Re: Customize a Pie Chart with Java under Eclispe [message #653449 is a reply to message #653294] |
Wed, 09 February 2011 18:45 |
What are you trying to specify the data?
Does the code you posted not work?
Remember when specifying category and series values that each has to
have the same number of points for a particular chart. Ie in your code
doubleValues and textLabels have to be the same size for one chart.
Jason
On 2/9/2011 4:20 AM, kkt8 wrote:
> Hello,
> PieChart.
> piece of my code:
> cwoaPie.setDimension(ChartDimension.TWO_DIMENSIONAL_WITH_DEP TH_LITERAL);
> // Plot
> // Legend
> lg.getClientArea().setBackground(ColorDefinitionImpl.create( 255, 255,
> 204));
> ((ColorDefinitionImpl)lg.getClientArea().getBackground()).br ighter();
> // Title
> //Base Data Set
> // Base Series
> // Pie Series
> sePie.setLeaderLineStyle(LeaderLineStyle.FIXED_LENGTH_LITERA L);
> A track?
> Thank you
> K :p
Re: Customize a Pie Chart with Java under Eclispe [message #653699 is a reply to message #653526] |
Thu, 10 February 2011 18:14 |
Try:
final Fill[] fillcolors= {
ColorDefinitionImpl.ORANGE( ),
ColorDefinitionImpl.RED( ),
ColorDefinitionImpl.GREEN( )
sdVal.getSeriesPalette( ).getEntries( ).clear( );
for (final Fill element : fillcolors) {
sdVal.getSeriesPalette( ).getEntries( ).add( element );
Jason
On 2/10/2011 1:43 AM, kkt8 wrote:
> Hello,
> I just want to specify the color of the chart, and to differencie 2
> sorts of data in the same chart, I want to specify my self the color : 1
> sort with cold colors for ex, and the sd sort with hot colors.
> The code works well, I put it in ex to let see what I'm doing.
> do you have any idea to specify the color ?
Re: Customize a Pie Chart with Java under Eclispe [message #653779 is a reply to message #653699] |
Fri, 11 February 2011 07:08 |
YES ! thank you it's very difficult to find some documentation about the API ...
Do you know if it's possible and how to do in the same chart, 2 series of datas .
For ex, I've 2 sorts of datas:
DATA : 100, 200, 1500 and 3000
CODE : 450, 200, 700, 4500
I want to represente all the datas : 100, 200, 1500 and 3000 and 450, 200, 700, 4500 in one piechart, BUT I want see differently the datas DATA and the datas CODE.
Make datas DATA in hot colors (RED, ORANGE...)
Make datas CODE in cold colors (BLUE, GREEN...)
And put next the datas DATA a title and put next the datas CODE another title.
I'm clear ?
If you have a task ....
Thank !
Re: Customize a Pie Chart with Java under Eclispe [message #653871 is a reply to message #653779] |
Fri, 11 February 2011 16:13 |
For a pie chart a new series will create a separate pie. Multiple
series on one pie is currently not supported. You could do multiple
series on a line. Do you want an example of that?
Jason
On 2/11/2011 2:08 AM, kkt8 wrote:
> YES ! thank you :d it's very difficult to find some documentation about
> the API ...
> of datas .
> title.
> I'm clear ?
> If you have a task .... :roll:
> Thank !
Re: Customize a Pie Chart with Java under Eclispe [message #653894 is a reply to message #653885] |
Fri, 11 February 2011 18:02 |
Also in Eclipse there is a view call Chart Examples that you can open
that will show you how to create a lot of different chart types.
Jason
On 2/11/2011 12:35 PM, kkt8 wrote:
> Oh yes, I'll see what is it.
> In fact, I've done a pie chart with my specific color,as I know in what
> order are the data, once I know associate each given a color. But I
> still have the problem of putting a title at a set of color, maybe I'll
> do it in the legend.
> thank you for your precious help.
> Do you know where find an help about the BIRT API ?
> Have a good week-end :d
Current Time: Fri Apr 26 21:56:31 GMT 2024
Powered by FUDForum. Page generated in 0.03962 seconds
