Re: project text encoding resetted each time [message #652979 is a reply to message #652828] |
Mon, 07 February 2011 14:35   |
On 2/7/2011 4:06 AM, frms@webologix.com wrote:
> Hi evreybody
> I face a problem with Eclipse since I use utf-8 encoding I set old
> projects properties to iso-8859-1 and it works fine until next session.
> When I restart the project the next day encoding switched back to utf-8
> again while the .settings/core.eclipse.resources.prefs shows:
> #Thu Feb 03 15:01:21 CET 2011
> eclipse.preferences.version=1
> encoding/<project>=ISO-8859-1
> I have to re-define text encoding each time I re-open the project and if
> I forget it I get bad transcoded caracters. Realy boring :evil:
I have not heard of this problem before, but to check the obvious ... is
this a "shared" project? could a team mate be changing it back?
I assume you have not other software/plugins installed that might be
changing it back?
Also, I have seen some recent bugs about encoding preferences not
"taking", see bug 202384,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=202384
but think that had to do with closing/reopening a project.
You might search the platform's bugs and see if any matches, and if not,
perhaps open one, if you can provide reproducible steps, on a clean
install of just Eclipse code.
FUDForum. Page generated in 0.03048 seconds
