"Index file is in use" [message #652533] |
Fri, 04 February 2011 12:40 |
h1055071 Messages: 335 Registered: July 2009 |
Using the latest eGit from Hudson, 0.11.0.201102031130
Oftentimes I get the error:
Committing failed
Committing changes
java.io.IOException: Index file is in use
at org.eclipse.jgit.lib.GitIndex.write(GitIndex.java:273)
at
org.eclipse.egit.core.op.CommitOperation.doCommits(CommitOpe ration.java:303)
at
org.eclipse.egit.core.op.CommitOperation.access$8(CommitOper ation.java:289)
at org.eclipse.egit.core.op.CommitOperation$1.run(CommitOperati on.java:178)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1975)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1957)
at
org.eclipse.egit.core.op.CommitOperation.execute(CommitOpera tion.java:192)
at
org.eclipse.egit.ui.internal.actions.CommitActionHandler$2.r un(CommitActionHandler.java:208)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Is this normal?
FUDForum. Page generated in 0.03374 seconds
