Home » Archived » Buckminster » ERROR [0003] : IU * has no artifacts
ERROR [0003] : IU * has no artifacts [message #652310] |
Thu, 03 February 2011 14:42 |
David Gonzalez Messages: 24 Registered: January 2011 |
Hey,
I've problem using my own generated p2 site for another buckminster build.
So, first I created Component A with all necessary plugins and features and called #site.p2 Action afterwards.
Now I want to create Component B (which needs Component A) and of course I don't want to create Component A again, I want to use the created one. So in the rmap i defined like this:
<rm:searchPath name="com.example">
<rm:provider componentTypes="osgi.bundle,eclipse.feature" readerType="p2" source="false" mutable="false">
<rm:uri format="file:///E:/test/p2"/>
</rm:provider>
</rm:searchPath>
The location to this p2 site is correct and the build works without any problems - until this happens:
Quote: | Provider eclipse.import(file:///E:/test/p2): materializing to E:/.hudson/jobs/xslteditor/workspace/plugins/com.example.com mon.exporter/
Provider eclipse.import(file:///E:/test/p2): materializing to E:/.hudson/jobs/xslteditor/workspace/plugins/com.example.com mon.img/
Provider eclipse.import(file:///E:/test/p2): materializing to E:/.hudson/jobs/xslteditor/workspace/plugins/com.example.com mon.xslttransformer/
Provider eclipse.import(file:///E:/test/p2): materializing to E:/.hudson/jobs/xslteditor/workspace/features/com.example.co mmon.feature/
ERROR [0003] : IU com.example.common.feature.feature.group/4.0.30000.00145 has no artifacts
ERROR: IU com.example.common.feature.feature.group/4.0.30000.00145 has no artifacts
What does this mean, "IU has no artifacts"? And why does this error appear at the end of the process?
I don't know if it makes a difference, but I use Buckminster plugin in Hudson.
Let me know if you need more log or other stuff.
Greets
[Updated on: Thu, 03 February 2011 14:43] Report message to a moderator
Re: ERROR [0003] : IU * has no artifacts [message #652923 is a reply to message #652310] |
Mon, 07 February 2011 16:04 |
No idea what this error could mean?
Is it possible that I do something wrong when building the p2 repo? I just call the #site.p2 action and afterwards mirror it with Ant p2 tasks to another repository. But it doesn't matter if I use the original path of the p2 site or the one of the new repo - the same error.
By the way - is there any document where I can see what error-code (or whatever it means) [0003] means? In another thread someone had a similar problem, but error-code [0002] - where is the difference?
[Updated on: Mon, 07 February 2011 16:06] Report message to a moderator
Re: ERROR [0003] : IU * has no artifacts [message #655079 is a reply to message #655058] |
Fri, 18 February 2011 09:18 |
On 2011-02-18 09:16, Gonzo wrote:
> Hey,
> is there nobody that knows what this error means?
The error comes from the "eclipse.import" reader type. It's deprecated (replaced by the p2 reader type) and shouldn't
normally be used. What version of Buckminster are you using? Is there any entry for readerType="eclipse.import" in your
RMAP?
- thomas
Re: ERROR [0003] : IU * has no artifacts [message #655102 is a reply to message #655084] |
Fri, 18 February 2011 10:17 |
On 2011-02-18 10:51, Gonzo wrote:
> Thanks for your reply!
> Thomas Hallgren wrote on Fri, 18 February 2011 10:18
> I use Buckminster 3.6
>> Is there any entry for readerType="eclipse.import" in your RMAP?
> No, I use p2 reader. Here the whole RMAP (perhaps there is another problem?):
Do you have an MSPEC where you redirect binaries into the workspace instead of to a target platform?
- thomas
Re: ERROR [0003] : IU * has no artifacts [message #655113 is a reply to message #655105] |
Fri, 18 February 2011 11:36 |
On 2011-02-18 11:48, Gonzo wrote:
> Thomas Hallgren wrote on Fri, 18 February 2011 11:17
>> - thomas
> Yep:
> <mspec:mspec xmlns:mspec="http://www.eclipse.org/buckminster/MetaData-1.0" name="com.example.xslteditor.releng"
> url="xslteditor.cquery">
> <mspec:mspecNode materializer="workspace" namePattern="^com\.example(\..+)?"/>
> <mspec:mspecNode namePattern=".*"/>
> </mspec:mspec>
> All of "my" Plug-Ins should go to the workspace, all others (especially Eclipse Plug-Ins) should go to the target
> platform.
Sounds good. But that's not what your MSPEC does.
> No problems with that, works as expected.
Obviously it doesn't. Your com.example stuff from E:\test\p2 that is fetched using p2 also ends up in your workspace.
That's your problem right there. The easiest way to resolve this is to simply remove the mspec and rely on the defaults.
All providers marked source="true" will end up in the workspace, all others in the TP.
Alternatively, you can alter your mspec to reflect the defaults. Note the lack of namePattern:
<mspec:mspec xmlns:mspec="http://www.eclipse.org/buckminster/MetaData-1.0" materializer="p2"
name="com.example.xslteditor.releng" url="xslteditor.cquery">
<mspec:mspecNode materializer="workspace" filter="(buckminster.source=true)"/>
</mspec:mspec>
HTH,
- thomas
Re: ERROR [0003] : IU * has no artifacts [message #655134 is a reply to message #655119] |
Fri, 18 February 2011 12:58 |
On 2011-02-18 13:05, Gonzo wrote:
> Thomas Hallgren wrote on Fri, 18 February 2011 12:36
>> defaults. All providers marked source="true" will end up in the workspace, all others in the TP.
> Well. I don't understand what the "problem" is here. I do want to have the Plug-Ins from the p2 in my workspace. If they
> are not, a lot of errors occure because of missing imports and so on.
In that case you have a problem with how your target platform is configured. There's absolutely no reason to have a
compiled binary in your workspace.
> And the next point: and don't want to have my
> Plug-Ins to end up in the target platform. Even not those ones coming from the p2 repo. Only Eclipse Plug-Ins (and
> Plug-Ins from others).
Why?
> To explain why I do this. Component A (something like common here) is built and afterwards stored in the p2 repo.
> Component B (like xslteditor) needs Component A to build and I don't want B to build A again, so B fetches A from the
> repo. But to be able to build, A has to be in the workspace.
No, A does not need to be in the workspace. The workspace is for source code, not binaries. Binaries should go into your
target platform.
HTH,
- thomas
Re: ERROR [0003] : IU * has no artifacts [message #655163 is a reply to message #655146] |
Fri, 18 February 2011 14:09 |
On 2011-02-18 14:50, Gonzo wrote:
> I wonder why this happens because the import was successful, my Plug-Ins ended in the target platform but something
> seems to be wrong - any suggestions what could be wrong now?
> Greets
Well, the first thing to check is if the jaxen lib really is there. Is it an OSGi bundle? If so, can you find it in your
TP? Or should it reside inside of Plug-In A? If it's the latter, is it really there? Did you really mark it for
inclusion in your build.properties? Check if there's a check-mark in front of it in your manifest editor.
- thomas
Re: ERROR [0003] : IU * has no artifacts [message #655166 is a reply to message #652310] |
Fri, 18 February 2011 14:35 |
In my target platform is an osgi bundle called 'com.example.common.external_4.0.30000.00145.jar'. Inside this jar there is a folder META-INF with following MANIFEST.MF:
Manifest-Version: 1.0
Ant-Version: Apache Ant 1.7.1
Created-By: 14.3-b01 (Sun Microsystems Inc.)
Export-Package: org.dom4j,org.dom4j.io,org.jaxen,org.jaxen.dom,org.jax
en.dom4j,org.jaxen.expr,org.jaxen.expr.iter,org.jaxen.function,org.ja
xen.jdom,org.jaxen.pattern,org.jaxen.saxpath,org.jaxen.saxpath.helper
s,org.jaxen.util
Bundle-Vendor: Example
Bundle-ClassPath: lib/dom4j-1.6.1.jar,.,lib/jaxen-1.1.1.jar
Bundle-Version: 4.0.30000.00145
Bundle-Name: External Libs
Bundle-ManifestVersion: 2
Bundle-SymbolicName: com.example.common.external
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
And there is a folder 'lib' with 'dom4j-1.6.1.jar' and 'jaxen-1.1.1.jar' in it. So of course it's marked in the build.properties.
Re: ERROR [0003] : IU * has no artifacts [message #655175 is a reply to message #655166] |
Fri, 18 February 2011 14:42 |
> en.dom4j,org.jaxen.expr,org.jaxen.expr.iter,org.jaxen.functi on,org.ja
> xen.jdom,org.jaxen.pattern,org.jaxen.saxpath,org.jaxen.saxpa th.helper
> s,org.jaxen.util
> build.properties.
OK, in that case the packages are on the classpath. But apparently the compiler doesn't see them, so something is amiss.
- thomas
Current Time: Tue Sep 24 15:57:50 GMT 2024
Powered by FUDForum. Page generated in 0.06157 seconds
