Home » Eclipse Projects » Remote Application Platform (RAP) » Update ui for OSGi-EventAdmin-Event(Receiving an Event from EventAdmin want to update the RAP UI)
Update ui for OSGi-EventAdmin-Event [message #652279] |
Thu, 03 February 2011 12:55 |
Stefan Klaus Messages: 21 Registered: February 2011 |
Hello!
I'm trying to show an Event received via OSGi-EventAdmin. Within my RCP-App everything works fine. Thanks to Tom Schindl and http://tomsondev.bestsolution.at/2011/01/03/enhanced-rcp-how -views-can-communicate/ .
Now in RAP I tried first following:
class ... {
Composite parent;
TableViewer tableViewer;
protected Composite createEventCompositeInternal(final Composite parent) {
this.parent = parent;
this.tableViewer = new TableViewer(composite);
BundleContext ctx = FrameworkUtil.getBundle(Client.class)
.getBundleContext();
EventHandler handler = new EventHandler() {
public void handleEvent(final Event event) {
UICallBack.activate("alarm");
Thread bgThread = new Thread(createRunnable(event));
bgThread.setDaemon(true);
bgThread.start();
Dictionary<String, String> properties = new Hashtable<String, String>();
properties.put(EventConstants.EVENT_TOPIC, "events");
ctx.registerService(EventHandler.class.getName(), handler, properties);
return composite;
private Runnable createRunnable(final Event event) {
return new Runnable() {
public void run() {
// do some work...
// schedule the UI update
parent.getDisplay().asyncExec(new Runnable() {
public void run() {
// update the UI
tableViewer.add(event.toString());
// Deactivate the UI call-back
public void run() {
UICallBack.deactivate("alarm");
But this throws the following exception:
Log ErrorException while dispatching event org.osgi.service.event.Event [topic=events] to handler client.EventCompositeFacadeImpl$2@5ecfe500
java.lang.IllegalStateException: No context available outside of the request service lifecycle.
Looking in the RAP-FAQ for the IllegalstateException then tried UICallBack#runNonUIThreadWithFakeContext:
class...{
Composite parent;
Composite composite = new Composite(parent, SWT.NONE);
composite.setLayout(new FillLayout());
this.tableViewer.getTable().setHeaderVisible(true);
this.tableViewer.getTable().setLinesVisible(true);
this.tableViewer.setLabelProvider(new ColumnLabelProvider() {
public String getText(Object element) {
// return DateFormat.getDateTimeInstance().format(element);
return element.toString();
UICallBack.runNonUIThreadWithFakeContext(parent.getDisplay(),
new Runnable() {
public void run() {
// do some work...
public void run() {
// update the UI
No Exception is thrown, but the UI does not automatically refresh. I have to first resize the browser window or the click in the tableviewer to see the new added events to the table.
Any suggestions?
Thanks for your help.
Stefan
Re: Update ui for OSGi-EventAdmin-Event [message #652288 is a reply to message #652279] |
Thu, 03 February 2011 13:36 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Stefan,
in your second example the UICallBack is not activated at all, thus UI
HTH,
Ivan
On 2/3/2011 2:55 PM, Stefan wrote:
> Hello!
> class ... {
> Composite parent;
> @Override
> parent) {
> bgThread.start();
> String>();
> properties);
> return composite;
> public void run() {
> // do some work...
> public void run() {
> // update the UI
> public void run() {
> class...{
> Composite parent;
> @Override
> parent) {
> @Override
> // return
> UICallBack.runNonUIThreadWithFakeContext(parent.getDisplay() ,
> new Runnable() {
> public void run() {
> // do some work...
> Runnable() {
> public void run() {
> // update the UI
> String>();
> properties);
> Any suggestions?
> Stefan
Re: Update ui for OSGi-EventAdmin-Event [message #652335 is a reply to message #652324] |
Thu, 03 February 2011 15:36 |
Hi Stefan,
it's great that your code is running fine now. I will suggest to
deactivate the UICallBack when it is not needed anymore. In other words
- activate before you start the background thread, deactivate it when
the job is done.
Best,
Ivan
On 2/3/2011 5:19 PM, Stefan wrote:
> Short answer but very helpful! :d
> For others searching the same question here the running code:
> bgThread.start();
> properties.put(EventConstants.EVENT_TOPIC, "Events");
> properties);
> public void run() {
> new Runnable() {
> public void run() {
> // do some work...
> Runnable() {
> public void run() {
> // update the UI
Current Time: Fri Apr 26 21:39:32 GMT 2024
Powered by FUDForum. Page generated in 0.04372 seconds
