Re: Problem with export to pdf [message #652365 is a reply to message #652228] |
Thu, 03 February 2011 16:40 |
Can you try to add:
-Djava.awt.headless=true
To your tomcat starup?
Jason
On 2/3/2011 4:16 AM, Bartek wrote:
> Hello,
> I start runing tomcat and birt on my server.
> but i have problem with export my raport from the website.
> - org.eclipse.birt.report.service.api.ReportServiceException: Error
> happened while running the report.
> AxisFault
> faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userExcept ion
> faultSubcode: faultString:
> faultActor: faultNode: faultDetail:
> {http://xml.apache.org/axis/}stackTrace:org.eclipse.birt.rep ort.service.api.ReportServiceException:
> Error happened while running the report.
> at org.eclipse.birt.report.service.ReportEngineService.throwDum
> myException(ReportEngineService.java:1096)
> at org.eclipse.birt.report.service.ReportEngineService.renderRe
> port(ReportEngineService.java:1543)
> at org.eclipse.birt.report.service.BirtViewerReportService.rend
> erReport(BirtViewerReportService.java:369)
> at org.eclipse.birt.report.service.actionhandler.BirtRenderRepo
> rtActionHandler.__execute(BirtRenderReportActionHandler.java :65)
> at org.eclipse.birt.report.service.actionhandler.AbstractBaseAc
> tionHandler.execute(AbstractBaseActionHandler.java:90)
> at org.eclipse.birt.report.presentation.aggregation.layout.Fram
> esetFragment.doService(FramesetFragment.java:222)
> esetFragment.service(FramesetFragment.java:86)
> at org.eclipse.birt.report.servlet.ViewerServlet.__doGet(Viewer
> Servlet.java:181)
> at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer
> vlet.doGet(BirtSoapMessageDispatcherServlet.java:160)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
> at org.apache.axis.transport.http.AxisServletBase.service(AxisS
> ervletBase.java:327)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
> vlet.service(BirtSoapMessageDispatcherServlet.java:122)
> at org.apache.catalina.core.ApplicationFilterChain.internalDoFi
> lter(ApplicationFilterChain.java:269)
> at org.apache.catalina.core.ApplicationFilterChain.doFilter(App
> licationFilterChain.java:188)
> at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerF
> ilter.java:68)
> lter(ApplicationFilterChain.java:215)
> at org.apache.catalina.core.StandardWrapperValve.invoke(Standar
> dWrapperValve.java:210)
> at org.apache.catalina.core.StandardContextValve.invoke(Standar
> dContextValve.java:172)
> at org.apache.catalina.core.StandardHostValve.invoke(StandardHo
> stValve.java:127)
> at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo
> rtValve.java:117)
> at org.apache.catalina.core.StandardEngineValve.invoke(Standard
> EngineValve.java:108)
> at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd
> apter.java:151)
> at org.apache.coyote.http11.Http11Processor.process(Http11Proce
> ssor.java:875)
> at org.apache.coyote.http11.Http11BaseProtocol$Http11Connection
> Handler.processConnection(Http11BaseProtocol.java:665)
> at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo
> lTcpEndpoint.java:528)
> at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(
> LeaderFollowerWorkerThread.java:81)
> at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru
> n(ThreadPool.java:685)
> at java.lang.Thread.run(Thread.java:636)
> Caused by: org.eclipse.birt.report.engine.api.EngineException: Error
> at org.eclipse.birt.report.engine.api.impl.RenderTask.render(Re
> nderTask.java:308)
> port(ReportEngineService.java:1537)
> ... 28 more
> Caused by: java.lang.NoClassDefFoundError: Could not initialize class
> sun.awt.X11.XToolkit
> at java.lang.Class.forName0(Native Method)
> at java.lang.Class.forName(Class.java:186)
> at java.awt.Toolkit$2.run(Toolkit.java:849)
> at java.security.AccessController.doPrivileged(Native Method)
> at java.awt.Toolkit.getDefaultToolkit(Toolkit.java:841)
> at org.eclipse.birt.report.engine.layout.pdf.util.PropertyUtil.
> getScreenDpi(PropertyUtil.java:322)
> getRenderDpi(PropertyUtil.java:294)
> getRenderDpi(PropertyUtil.java:305)
> at org.eclipse.birt.report.engine.nLayout.area.impl.ContainerAr
> ea.getResolution(ContainerArea.java:770)
> ea.getDimensionValue(ContainerArea.java:866)
> ea.validateBoxProperty(ContainerArea.java:906)
> at org.eclipse.birt.report.engine.nLayout.area.impl.BlockContai
> nerArea.initialize(BlockContainerArea.java:174)
> at org.eclipse.birt.report.engine.nLayout.area.impl.BlockTextAr
> ea.layout(BlockTextArea.java:58)
> at org.eclipse.birt.report.engine.nLayout.LayoutEngine.startCon
> tent(LayoutEngine.java:488)
> at org.eclipse.birt.report.engine.emitter.ContentEmitterAdapter
> .startText(ContentEmitterAdapter.java:147)
> .startData(ContentEmitterAdapter.java:163)
> at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.st
> artContent(ContentEmitterUtil.java:71)
> at org.eclipse.birt.report.engine.layout.html.HTMLTableLayoutEm
> itter.startContent(HTMLTableLayoutEmitter.java:146)
> at org.eclipse.birt.report.engine.layout.html.buffer.HTMLPageBu
> ffer.startContent(HTMLPageBuffer.java:116)
> at org.eclipse.birt.report.engine.layout.html.buffer.TableBreak
> Buffer.startContent(TableBreakBuffer.java:287)
> at org.eclipse.birt.report.engine.layout.html.HTMLLeafItemLM.st
> art(HTMLLeafItemLM.java:67)
> at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la
> yout(HTMLAbstractLM.java:139)
> at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking
> LM.layoutNodes(HTMLBlockStackingLM.java:70)
> at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.la
> youtChildren(HTMLStackingLM.java:26)
> yout(HTMLAbstractLM.java:140)
> at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin
> gLM.resumeLayout(HTMLInlineStackingLM.java:111)
> gLM.layoutNodes(HTMLInlineStackingLM.java:160)
> at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.l
> ayoutChildren(HTMLTableBandLM.java:67)
> at org.eclipse.birt.report.engine.layout.html.HTMLGroupLM.layou
> tChildren(HTMLGroupLM.java:117)
> at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layou
> tChildren(HTMLTableLM.java:132)
> at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout
> (HTMLPageLM.java:90)
> at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE
> ngine.layout(HTMLReportLayoutEngine.java:99)
> at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRange
> Render.render(RenderTask.java:602)
> nderTask.java:284)
> ... 29 more
> {http://xml.apache.org/axis/}hostname:192.168.0.1
> {}:org.eclipse.birt.report.service.api.ReportServiceExceptio n: Error
> Servlet.java:181)
> ilter.java:68)
> stValve.java:127)
> rtValve.java:117)
> apter.java:151)
> ssor.java:875)
> nderTask.java:308)
> ... 28 more
> nderTask.java:284)
> ... 29 more
> at org.apache.axis.AxisFault.makeFault(AxisFault.java:101)
> at org.eclipse.birt.report.utility.BirtUtility.makeAxisFault(Bi
> rtUtility.java:761)
> tionHandler.execute(AbstractBaseActionHandler.java:94)
> Servlet.java:181)
> ilter.java:68)
> stValve.java:127)
> rtValve.java:117)
> apter.java:151)
> ssor.java:875)
> Caused by: org.eclipse.birt.report.service.api.ReportServiceException:
> ... 25 more
> nderTask.java:308)
> ... 28 more
> nderTask.java:284)
> ... 29 more
> What can i do to solve this problem?
FUDForum. Page generated in 0.03466 seconds
