Home » Eclipse Projects » Target Management » Pending Changes(Getting pending changes to the remote system.)
Pending Changes [message #651791] Tue, 01 February 2011 10:53 Go to next message
I edited a remote file using RSE and and saved it, expecting the change would be in the remote file. But the remote file did not change. Instead the change went into a "Pending Changes" archive on my local machine. I did not find a way to get the pending changes to the remote system. I need to know how to do this.
Re: Pending Changes [message #652508 is a reply to message #651791] Fri, 04 February 2011 05:25 Go to previous message
Hello Stephen,
Usually, RSE should write to the remote file immediately, just as you expect.
The only reason I can think of for not doing so, is when there is a conflict (remote file changed unexpectedly), or a permission problem (you don't have the right to write to the remote file).
Please investigate the situation in a bit more detail, and if you still think it doesn't behave as expected, file a defect:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Target%2 0Management
Martin
Previous Topic:Requests
Next Topic:Extending dstore server launcher?
Current Time: Mon Nov 10 05:42:17 EST 2025
Powered by FUDForum. Page generated in 0.25266 seconds
