Home » Archived » BIRT » Creating a dynamic start/end time parameter range
Creating a dynamic start/end time parameter range [message #651774] Tue, 01 February 2011 09:52 Go to next message
My dataset has a datetime column.
I would like to create two parameters that would allow the user to choose a start time and an end time in order to filter the report. Ideally the datetime parameters should default to the min time and max time in the dataset column respectively.
I've played around a bit and can get a list parameter populated with the datetime field but I cannot figure out a way to set the default value dynamically from the min or max value.
It occurs to me that this would be a very common parameter pattern for charting so I'm sure someone has solved this better than I.
Any help is appreciated.
Mike
Re: Creating a dynamic start/end time parameter range [message #651833 is a reply to message #651774] Tue, 01 February 2011 13:07 Go to previous messageGo to next message
Mike
Why not copy the dataset and sort ascending in on and descending in the
other. The default value will be the first date in one and the last in
the other.
Jason
On 2/1/2011 9:52 AM, Mike Wulkan wrote:
> Mike
Re: Creating a dynamic start/end time parameter range [message #651842 is a reply to message #651833] Tue, 01 February 2011 13:57 Go to previous messageGo to next message
I'm not quite sure what you mean Jason?
I tried creating two separate cascading parameter groups; one for the start time and one for the end time.
I needed cascading parameter groups as this was the only thing that let me specify my data to populate the combo box.
The sort ascending/descending works but there are two issues that I can't figure out.
1) I can't get a default value. It isn't filling in the first value.
2) The second parameter is displaying with both the combo box and a text box; selectable with radio buttons but I didn't specify multiple parameters in the group!
So what obvious thing am I missing here?
Re: Creating a dynamic start/end time parameter range [message #651850 is a reply to message #651842] Tue, 01 February 2011 14:16 Go to previous messageGo to next message
okay, I figured those two things out.
1 I changed the cascading parameter group to a parameter group and somehow it retained the dataset association and now fills in the first value as the default value.
2) I had chosen combo box as the second parm instead of listbox which was what gave me the weird radio button UI.
But here is another head scratcher...
I want to use these values to filter the dataset; however if I attempt to add the filter referencing these parms to the dataset I get nothing because the dataset is used to populate the prompt and since it gets filtered before the prompt the dataset is empty (ie., chicken and egg)
I could create a filter in the charts but I would have to do this for every chart and table in the report. There has got to be a better way?
Re: Creating a dynamic start/end time parameter range [message #651863 is a reply to message #651850] Tue, 01 February 2011 15:07 Go to previous messageGo to next message
Mike
Just add another dataset and use the dataset parameter feature to link
the report parameters to the new dataset parameters.
Jason
Re: Creating a dynamic start/end time parameter range [message #651864 is a reply to message #651863] Tue, 01 February 2011 15:08 Go to previous messageGo to next message
Just to clarify add the new dataset parameter put ? in your query.
On 2/1/2011 3:07 PM, Jason Weathersby wrote:
> Mike
> Jason
Re: Creating a dynamic start/end time parameter range [message #651887 is a reply to message #651864] Tue, 01 February 2011 16:49 Go to previous messageGo to next message
Sorry if I'm being thick but I don't get what you are suggesting?
Re: Creating a dynamic start/end time parameter range [message #652084 is a reply to message #651887] Wed, 02 February 2011 11:03 Go to previous message
Mike
You need three datasets. one for start date one for end date and the
last for the table in the report. The table in the report will have sql
like:
select *
from orders
where orderdate between ? and ?
this will create two dataset parameters. You can click on parameters in
the dataset editor and link the two parameters to the start and end date
report parameters. Attached is an example.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.6.1.v20100902 Build &lt;2.6.1.v20100915-1750></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<parameters>
<scalar-parameter name="startdate" id="9">
<property name="valueType">dynamic</property>
<property name="isRequired">true</property>
<property name="dataSetName">startdate</property>
<expression name="valueExpr"
type="javascript">dataSetRow["ORDERDATE"]</expression>
<expression
name="sortByColumn">dataSetRow["ORDERDATE"]</expression >
<property name="sortDirection">asc</property>
<property name="dataType">date</property>
<property name="distinct">true</property>
<property name="paramType">simple</property>
<property name="controlType">list-box</property>
<property name="mustMatch">true</property>
<property name="fixedOrder">false</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="enddate" id="11">
<property name="dataSetName">enddate</property>
<property name="fixedOrder">true</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<list-property name="privateDriverProperties">
<ex-property>
<name>contentBidiFormatStr</name>
<value>ILYNN</value>
</ex-property>
<ex-property>
<name>metadataBidiFormatStr</name>
</ex-property>
</list-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="startdate" id="8">
<list-property name="computedColumns">
<structure>
<property name="name">maxdate</property>
<property name="dataType">date-time</property>
<property name="aggregateFunction">MAX</property>
<list-property name="arguments">
<structure>
<property name="name">Expression</property>
<expression
name="value">row["ORDERDATE"]</expression>
</structure>
</list-property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
<text-property
name="heading">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">ORDERDATE</property>
<text-property
name="displayName">ORDERDATE</text-property>
<text-property name="heading">ORDERDATE</text-property>
</structure>
<structure>
<property name="columnName">REQUIREDDATE</property>
<text-property
name="displayName">REQUIREDDATE</text-property>
<text-property
name="heading">REQUIREDDATE</text-property>
</structure>
<structure>
<property name="columnName">SHIPPEDDATE</property>
<text-property
name="displayName">SHIPPEDDATE</text-property>
<text-property
name="heading">SHIPPEDDATE</text-property>
</structure>
<structure>
<property name="columnName">STATUS</property>
<text-property
name="displayName">STATUS</text-property>
<text-property name="heading">STATUS</text-property>
</structure>
<structure>
<property name="columnName">COMMENTS</property>
<text-property
name="displayName">COMMENTS</text-property>
<text-property name="heading">COMMENTS</text-property>
</structure>
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<text-property
name="displayName">CUSTOMERNUMBER</text-property>
<text-property
name="heading">CUSTOMERNUMBER</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">ORDERDATE</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">STATUS</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">COMMENTS</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">CUSTOMERNUMBER</property>
</structure>
<structure>
<property name="position">8</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">STATUS</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">COMMENTS</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orders]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERDATE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>ORDERDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERDATE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>REQUIREDDATE</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>REQUIREDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>REQUIREDDATE</design:label>
<design:attributes>
<design:name>SHIPPEDDATE</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>SHIPPEDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SHIPPEDDATE</design:label>
<design:attributes>
<design:name>STATUS</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>STATUS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATUS</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>COMMENTS</design:name>
<design:position>6</design:position>
<design:precision>32700</design:precision>
<design:uiHints>
<design:displayName>COMMENTS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COMMENTS</design:label>
<design:displaySize>32700</design:displaySize>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>7</design:position>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set
name="enddate" id="10">
<structure>
<structure>
<expression
</structure>
</list-property>
</structure>
</list-property>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
from orders
order by orderdate desc]]></xml-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:criteria/>
</oda-data-set>
<oda-data-set
name="ReportDataSet" id="12">
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
</list-property>
<list-property name="parameters">
<structure>
<property name="name">param_1</property>
<property name="paramName">startdate</property>
<property name="nativeName"></property>
<property name="isOptional">true</property>
<property name="allowNull">true</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
<structure>
<property name="name">param_2</property>
<property name="paramName">enddate</property>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
from orders
where orderdate between ? and ?]]></xml-property>
<model:DesignValues
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:name></design:name>
<design:inputAttributes>
<design:elementAttributes>
<design:optional>true</design:optional>
</design:elementAttributes>
</design:inputAttributes>
</design:parameterDefinitions>
<design:attributes>
</design:DataSetParameters>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
Previous Topic:Running Report against different copies of a database
Next Topic:Gantt chart with summary tasks
Current Time: Sun Nov 09 19:23:12 EST 2025
Powered by FUDForum. Page generated in 0.04284 seconds
