Home » Eclipse Projects » Eclipse Platform » Compare bug, have patch, any chance for 3.6.2?
Compare bug, have patch, any chance for 3.6.2? [message #651642] |
Tue, 01 February 2011 02:16 |
Gergely Nagy Messages: 17 Registered: July 2009 |
When upgrading from our product from 3.3 to 3.6.1 (finally got the green light from managers after some fights),
I've run into a this regression..
basically Compare framework does not seem to work with non-textual/non-steam input any more, ContentMergeViewers are not created as they should.
It's https://bugs.eclipse.org/bugs/show_bug.cgi?id=293926,
reported >1 year ago, trivial patch is provided around that time, verified it -> it works.
Added several comments to clarify -> got no response yet. - am unsure if some is looking it at all. Is there a better place to push this forward (mailing list, another forum, IRC, raise another bug, tagging, etc...)?
Is there a way that this patch be included 3.6.2 (out soon as I understand).
No pressure:) but ... I would much prefer to upgrade to an official Eclipse version than having to build a custom patch.
Thank you in advance,Gergely
[Updated on: Tue, 01 February 2011 11:26] Report message to a moderator
Re: Compare bug, have patch, any chance for 3.6.2? [message #651744 is a reply to message #651712] |
Tue, 01 February 2011 13:01 |
Deepak Azad Messages: 543 Registered: July 2009 |
> I think the best is to keep on posting comments on that bug until
> someone replies...
> Good luck!
> Mauro.
Yep, you can ping on the bug once a week. Someone will respond..
Re: Compare bug, have patch, any chance for 3.6.2? [message #651776 is a reply to message #651754] |
Tue, 01 February 2011 14:50 |
On 2/1/2011 7:04 PM, Gergely Nagy wrote:
> Thanks for the replies hint - I'll try that :)
> The only thing is I'd really like this to happen within 3.6.2, otherwise
> I'd have to either build my own patched org.eclipse.compare bundle, or
> wait at least another year (actually this is not really an option).
The next release - 3.7 - will happen in June, so the wait is not a year :)
> Should I just import it into Eclipse, add fix, change version
> (qualifier?) rebuild, export plugin from Eclipse, and replace old jar in
> the app with the new one?
Sure you can do this, but note that if you change the version you also
have to fiddle with p2 to get it to work. But if you keep the same
version and then replace the old jar, then things should work just fine.
Re: Compare bug, have patch, any chance for 3.6.2? [message #651882 is a reply to message #651776] |
Tue, 01 February 2011 21:31 |
Deepak Azad wrote on Tue, 01 February 2011 09:50 | On 2/1/2011 7:04 PM, Gergely Nagy wrote:
Ok, well as an ISV I prefer to wait for SR1-2 to get less bugs to hack around
Good point, although I managed to avoid the P2 minefield so far. Just overwriting existing jar with no version change sounds dirty and dangerous too.
Any guidelines, best practices for patch versioning?
Thanks.
Re: Compare bug, have patch, any chance for 3.6.2? [message #651912 is a reply to message #651882] |
Wed, 02 February 2011 03:54 |
On 2/2/2011 3:01 AM, Gergely Nagy wrote:
> Quote:
>> jar in
> dangerous too.
> Thanks.
The right way is to go via p2 - the export wizard also lets you install
into the host eclipse (though I have not tried this option to install a
plugin into another eclipse installation).
Overwriting the existing jar is just a quick and dirty way, but not
dangerous ;-)
Re: Compare bug, have patch, any chance for 3.6.2? [message #651980 is a reply to message #651882] |
Wed, 02 February 2011 10:54 |
Dani Megert Messages: 3802 Registered: July 2009 |
>> year :)
> around
> Quote:
>> jar in
>> also have to fiddle with p2 to get it to work. But if you keep the
>> same version and then replace the old jar, then things should work
>> just fine.
> dangerous too.
See
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. pde.doc.user/guide/tools/project_wizards/new_feature_patch.h tm
Dani
> Thanks.
Current Time: Thu Sep 26 00:21:21 GMT 2024
Powered by FUDForum. Page generated in 0.04882 seconds
