*current* tutorial for UML2? [message #650882] |
Thu, 27 January 2011 01:25 |
Hi -
I'm just getting started, and want to learn how to build a class diagram. Are there any tutorials out there that match the current rev of eclipse and UML2? Thanks.
Re: *current* tutorial for UML2? [message #651069 is a reply to message #650962] |
Thu, 27 January 2011 16:24 |
Thank you, Vlad. I am following your video on class diagram creation. I believe that I have installed all necessary software: UML 2.2, EMF and Java (although I hope to use UML with C++, all the examples seem to be within a Java context).
So, when I create a package, and right click on it, here's what I get:
No options for a class diagram. Nor are they in the "New --> " sub-menu. Any idea what I might have done wrong?
Thanks.
Re: *current* tutorial for UML2? [message #651090 is a reply to message #650882] |
Thu, 27 January 2011 17:32 |
OK, I do have another question now...if I want to use the UML Tools 0.9.0, do I manually download them, or is this available from one of the software sites, and if so, which one?
Thanks again.
EDIT:
I did download it manually, but haven't installed anything yet. I notice that all the plugins are .jar files. Does this imply that this will only work within the Java resource, or will it be C++ compatible as well?
[Updated on: Thu, 27 January 2011 17:37] Report message to a moderator
Re: *current* tutorial for UML2? [message #651132 is a reply to message #651130] |
Thu, 27 January 2011 22:30 |
Sheesh...nothing's ever simple, is it? Any recommendations? Right now, all I want to do is be able to construct a class diagram, either directly, or have it derived from code. If the latter, it does have to work with C++, though.
Thanks for any suggestions.
Re: *current* tutorial for UML2? [message #651147 is a reply to message #651136] |
Fri, 28 January 2011 01:39 |
OK, thanks, Rafael. I'm looking at the MDT Papyrus tool on the list you gave me.
In the installation instructions, it says:
Quote: | Use the discovery interface ("Help" => "Install Modeling Component") and select Papyrus.
I don't have an "install Modeling Component" option under the Help menu. Did I miss installing a prerequisite, or has this been changed to using the "Install New Software..." option?
Re: *current* tutorial for UML2? [message #651190 is a reply to message #650882] |
Fri, 28 January 2011 10:12 |
Vlad Varnica Messages: 546 Registered: July 2009 Location: Milton Keynes - UK |
EclipseUML2 is an UML metamodel coming from EMF serialization.
Saying that you have three options today:
- Use UML2 metamodel directly without any editor in order to create your model. It works pretty well and is very very powerful way to create advanced UML models
- Use a GMF/EMF related UML tool which use this EclipseUML2 as a plugin on which GMF add the graphical presentation and EMF model transformations. The tools related to this technology are : RSA IBM, Objecteering, Papyrus, Topcased, UML2 Eclipse projects,
- Use a native UML2 editor on the top of the UML2 metamodel without any transformation or graphical mapper. The main advantage is the power and flexibility. Only one tool is currently providing a native UML2 editor (e.g. Omondo).
I think that EclipseUML2 is one of the most important modeling project and will remain alive even if no modification for many years once the other plugins will have disappear. The reason is that EclipseUML 2 is an official UML2 metamodel and an implementation of the OMG specification what is not EMF, GMF etc.....
[Updated on: Fri, 28 January 2011 10:24] Report message to a moderator
Re: *current* tutorial for UML2? [message #651446 is a reply to message #651190] |
Mon, 31 January 2011 00:38 |
Thank you, Vlad. I was able to get TOPCASED installed, and I can create a class diagram (though only from the context of a Java project, unfortunately). This is further than I've gotten with any of the other tools, so I'll probably go with it for awhile, even though my projects will be C++. At least I can make the diagrams, even if I can't do any forward engineering.
Do you happen to know if TOPCASED has a users forum? I couldn't find one here.
Thanks again...
Re: *current* tutorial for UML2? [message #651571 is a reply to message #651459] |
Mon, 31 January 2011 16:49 |
Rafael Chaves wrote on Sun, 30 January 2011 23:50 | I don't think Topcased is an Eclipse.org project.
What exactly does that mean? It's on the list of tools that you posted above.
If I could get anyone on the Papyrus forum to answer me, I'd take another look at them. I guess I'm not having a lot of luck with these UML tools...
Thanks, Rafael.
FUDForum. Page generated in 0.04022 seconds
