Re: Unresolved inclusion: <gtkmm.h> [message #650855 is a reply to message #650784] |
Wed, 26 January 2011 20:59 |
No real name Messages: 2 Registered: January 2011 |
Quote: | Eclipse (or better said the internal indexer) should find the header after the first compilation. The indexer will scan the build output and find all include paths.
If gtkmm is not in MinGW directory, at least for me it does not find it.
Long story short, didn't have time to read yet but now it kind of works.
Here's it for other ppl:
Have installed MinGW + MSYS in C:\MinGW and gtkmm in C:\gtkmm. To use MSYS, have your system variables set correctly!
GTKMM_BASEPATH is "C:\gtkmm",
Path: "C:\gtkmm\bin;C:\MinGW\bin;C:\MinGW\msys\1.0\bin;..."
Add `pkg-config gtkmm-2.4 --cflags` (including single quotation marks; this is for MinGW/MSYS!) under C++ Compiler/Misc/Other flags.
Add `pkg-config gtkmm-2.4 --libs` under C++ Linker/Misc/Linker flags.
Edit C++ Linker/Command line pattern in the way to move "${FLAGS}" at the end and KEEP SPACES as they make sense.
Use toolchain: Linux GCC and Gnu Make Builder
Under "Binary Parsers" activate "PE Windows Parser".
Enable Indexer with "... unused headers as C++ files" AND "... C files".
Go to Paths and Symbols/Source Location. Click "Link Folder" and in there check "Link to folder...", browse to C:\gtkmm\include and give the foldername something you want to.
If you delete the .exe and recompile, you will get some error because the whole added directory is getting compiled which makes no real sense.
Thus, right lick (oh my i forgot a "c" before lick lolo ) on the "linked folder" in Project Explorer/Resource Configurations/Exclude from Build.
Rebuild and be happy to use gtkmm with pkg-config and no unresolved symbols (hopefully, at least it seems to work for me right now).
[Updated on: Wed, 26 January 2011 21:00] Report message to a moderator
Re: Unresolved inclusion: <gtkmm.h> [message #651000 is a reply to message #650855] |
Thu, 27 January 2011 12:03 |
John McCabe Messages: 228 Registered: July 2009 |
Thank you very much for taking the time to post those instructions.
On Wed, 26 Jan 2011 15:59:38 -0500, <eclipseforum1112@mailinator.com>
wrote:
>Quote:
>Enable Indexer wirh "... unused headers as C++ files" AND "... C files".
>Thus, right lick (oh my i forgot a "c" before lick lolo :roll: ) on the "linked folder" in Project Explorer/Resource Configurations/Exclude from Build.
FUDForum. Page generated in 0.03360 seconds
