| Reading delimited data from web [message #650647] |
Tue, 25 January 2011 14:52   |
Eclipse User  |
Is there a way how to read delimited data from http protocol using BIRT? The sample dataset I would like to use is here ( http://www.cnb.cz/cs/financni_trhy/devizovy_trh/kurzy_devizo veho_trhu/rok.txt?rok=2011 - FX history).
I think the best way would be to use scripted data source, but from examples I have found I was not able to create anything usable.
There are other ways possible, like:
- use some kind of csv/plain-text jdbc driver
- use ETL solution to extract data from web and than store data in the database (this works - using Clover does the job well, but I think there must be some simple solution using BIRT only)
I have the following questions:
- do you know any example, how scripted data source is used to read delimited plain text data from web?
- is there any plain text jdbc driver you can use in BIRT to extract data from web?
- any other simple solution?
Thank you for any ideas.
Tomas
| Re: Reading delimited data from web [message #651275 is a reply to message #651176] |
Fri, 28 January 2011 11:36   |
Eclipse User  |
Thanks.  I posted it this morning on Birt Exchange.
Jason
On 1/28/2011 3:02 AM, TomasGreif wrote:
> Jason, it is completely ok if you use it on birt-exchange (anyway, it is
> your solution).
> Maybe you can consider also the following typical issues (at least for
> me) when reading such kind of data:
> - solving different locale (like different decimal separator - ","
> instead of "." in the example above, or different date format)
> - skipping more rows at the beginning (another stable dataset -
> interbank interest rates,
>  http://www.cnb.cz/cs/financni_trhy/penezni_trh/pribor/rok.tx t?year=2011)
FUDForum. Page generated in 0.03619 seconds
