Re: Where to start Custom SWT App to RAP [message #650042 is a reply to message #649482] |
Fri, 21 January 2011 14:17 |
Hi Timothy,
of course you can run plain SWT applications on RAP. Turning them into RCP
first is neither necessary nor recommended, since RCP is more heavyweight
and complex than needed for most web applications.
The "standalone" approach (Ivan pointed you to the FAQ) is the way to go
when you don't want to deal with OSGi.
But even if you like to use OSGi, there's no need for RCP. You can turn
your SWT application into a bundle, add a dependency to
org.eclipse.rap.ui, and deploy it the usual way.
Best regards, Ralf
Ralf Sternberg
Twitter: @ralfstx
FUDForum. Page generated in 0.03298 seconds
