Home » Eclipse Projects » Virgo » Upgrading version of spring
| Upgrading version of spring [message #649372] |
Tue, 18 January 2011 18:57  |
First, I'd like to thank the folks who post to this forum for all the help I've received from reading their blogs and posts on this site. It took me a little while, but I was able to move my site from spring 2.x running on tomcat 5.5 format to spring 3.x running on a virgo web server. You guys have been a huge help.
But, I have a question:
Is it possible to upgrade the version of spring within the virgo repository/ext? I would like to update the versions of the spring jars so that I can use spring security 3.0.5 which requires spring 3.0.3 or higher jars.
The first thing I tried was to add the new spring 3.0.3 jars into the repository/usr directory, but this caused an error saying that there was a version conflict between the spring jars (or something along those lines). The next thing I tried was to remove the old spring jars from repository/ext, replace them with the newer jars and restart the server using the -clean option. After completing this, the server would not start at all.
Is there a path to upgrade the spring jars or do I need to wait for Virgo to upgrade before an upgrade is possible?
| Re: Upgrading version of spring [message #650111 is a reply to message #649501] |
Fri, 21 January 2011 14:33   |
Hi Glyn, it didn't work again... perhaps I am doing something else wrong. Either way, I will probably go ahead and stick with what works until the next release.
FYI, I've attached the log file. Also included is my manifest file.
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: whale_probe
Bundle-SymbolicName: whale_probe
Bundle-Version: 1.0.0.qualifier
Bundle-ClassPath: whale_probe.jar,
WebRoot/WEB-INF/lib/FastInfoset.jar,
WebRoot/WEB-INF/lib/activation.jar,
WebRoot/WEB-INF/lib/aopalliance-1.0.jar,
WebRoot/WEB-INF/lib/aspectjrt-1.5.4.jar,
WebRoot/WEB-INF/lib/backport-util-concurrent.jar,
WebRoot/WEB-INF/lib/bcmail-jdk14-128.jar,
WebRoot/WEB-INF/lib/bcprov-ext-jdk15-141.jar,
WebRoot/WEB-INF/lib/bcprov-jdk15-141.jar,
WebRoot/WEB-INF/lib/cglib-nodep-2.1_3.jar,
WebRoot/WEB-INF/lib/commons-beanutils.jar,
WebRoot/WEB-INF/lib/commons-codec.jar,
WebRoot/WEB-INF/lib/commons-collections.jar,
WebRoot/WEB-INF/lib/commons-dbcp.jar,
WebRoot/WEB-INF/lib/commons-digester.jar,
WebRoot/WEB-INF/lib/commons-fileupload.jar,
WebRoot/WEB-INF/lib/commons-httpclient.jar,
WebRoot/WEB-INF/lib/commons-logging.jar,
WebRoot/WEB-INF/lib/commons-pool.jar,
WebRoot/WEB-INF/lib/el-api.jar,
WebRoot/WEB-INF/lib/el-ri.jar,
WebRoot/WEB-INF/lib/icefaces-comps.jar,
WebRoot/WEB-INF/lib/icefaces-facelets.jar,
WebRoot/WEB-INF/lib/icefaces.jar,
WebRoot/WEB-INF/lib/json_simple.jar,
WebRoot/WEB-INF/lib/jta.jar,
WebRoot/WEB-INF/lib/krysalis-jCharts-1.0.0-alpha-1.jar,
WebRoot/WEB-INF/lib/log4j-1.2.14.jar,
WebRoot/WEB-INF/lib/mail.jar,
WebRoot/WEB-INF/lib/mysql-connector-java-5.0.7-bin.jar,
WebRoot/WEB-INF/lib/objenesis-1.0.jar,
WebRoot/WEB-INF/lib/quartz-all-1.6.1.jar,
WebRoot/WEB-INF/lib/standard-1.1.2.jar,
WebRoot/WEB-INF/lib/standard.jar,
WebRoot/WEB-INF/lib/xercesImpl.jar,
WebRoot/WEB-INF/lib/xml-apis.jar,
WebRoot/WEB-INF/lib/mybatis-3.0.2.jar,
WebRoot/WEB-INF/lib/spring-security-acl-3.0.3.RELEASE.jar,
WebRoot/WEB-INF/lib/spring-security-acl-3.0.5.RELEASE-source s.jar,
WebRoot/WEB-INF/lib/spring-security-acl-3.0.5.RELEASE.jar,
WebRoot/WEB-INF/lib/spring-security-aspects-3.0.5.RELEASE-so urces.jar,
WebRoot/WEB-INF/lib/spring-security-aspects-3.0.5.RELEASE.ja r,
WebRoot/WEB-INF/lib/spring-security-config-3.0.3.RELEASE.jar ,
WebRoot/WEB-INF/lib/spring-security-config-3.0.5.RELEASE-sou rces.jar,
WebRoot/WEB-INF/lib/spring-security-config-3.0.5.RELEASE.jar ,
WebRoot/WEB-INF/lib/spring-security-core-3.0.3.RELEASE.jar,
WebRoot/WEB-INF/lib/spring-security-core-3.0.5.RELEASE-sourc es.jar,
WebRoot/WEB-INF/lib/spring-security-core-3.0.5.RELEASE.jar,
WebRoot/WEB-INF/lib/spring-security-taglibs-3.0.3.RELEASE.ja r,
WebRoot/WEB-INF/lib/spring-security-taglibs-3.0.5.RELEASE-so urces.jar,
WebRoot/WEB-INF/lib/spring-security-taglibs-3.0.5.RELEASE.ja r,
WebRoot/WEB-INF/lib/spring-security-web-3.0.3.RELEASE.jar,
WebRoot/WEB-INF/lib/spring-security-web-3.0.5.RELEASE-source s.jar,
WebRoot/WEB-INF/lib/spring-security-web-3.0.5.RELEASE.jar,
WebRoot/WEB-INF/lib/jsf-api-1.2.jar,
WebRoot/WEB-INF/lib/jsf-impl-1.2.jar,
WebRoot/WEB-INF/lib/com.springsource.javax.servlet.jsp.jstl- 1.2.0.jar,
WebRoot/WEB-INF/lib/testing/easymockclassextension.jar,
WebRoot/WEB-INF/lib/testing/hamcrest-core-1.1.jar,
WebRoot/WEB-INF/lib/testing/hamcrest-library-1.1.jar,
WebRoot/WEB-INF/lib/testing/jmock-2.5.1.jar,
WebRoot/WEB-INF/lib/testing/jmock-legacy-2.5.1.jar,
WebRoot/WEB-INF/lib/testing/jmock-script-2.5.1.jar,
WebRoot/WEB-INF/lib/testing/junit-4.8.2.jar,
WebRoot/WEB-INF/lib/testing/shale-core-1.0.5.jar,
WebRoot/WEB-INF/lib/testing/shale-spring-1.0.5.jar,
WebRoot/WEB-INF/lib/testing/shale-test-1.0.5.jar,
Export-Package: com.icesoft.faces.application,
... there's a bunck that were loaded by eclipse when I converted the project...
... including log4j if that's relevant to the errors ..
Import-Bundle: org.springframework.web;version="[3.0.3.RELEASE,3.0.3.RELEASE] "
Import-Package: javax.servlet,
javax.servlet.http,
org.springframework.context,
org.springframework.core.io.support,
org.springframework.dao,
org.springframework.jdbc.core.support,
org.springframework.scheduling.quartz,
org.springframework.web.context,
org.springframework.web.servlet,
org.springframework.web.util
Import-Library: org.springframework.spring
Attachment: log.log
(Size: 372.43KB, Downloaded 444 times)
Current Time: Fri Nov 07 01:46:49 EST 2025
Powered by FUDForum. Page generated in 0.05005 seconds
