Re: DerivedTable.queryTable not setted [message #649991 is a reply to message #649877] |
Fri, 21 January 2011 10:25 |
Victor Roldan Betancort Messages: 524 Registered: July 2009 |
Thanks Brian, I'll give it a look and see if it can be used for other
connectivity implementations :)
Cheers!
Brian Payton escribió:
> Take a look at the parseView method in class DerbyDdlParser in plugin
> org.eclipse.datatools.connectivity.apache.derby for an example where the
> setQueryExpression is getting called. Also take a look at the
> DerbyCatalogView and DerbyTableLoader classes.
> On 1/18/2011 9:33 AM, Víctor Roldán Betancort wrote:
>> Hi everyone,
>> we are reusing the SQL EMF model created in DTP, to perform some model
>> transformations. I noticed that DerivedTable has an attribute called
>> "queryExpression". However, no one seems to be setting it (nor I could
>> find calls to DerivedTable.setQueryExpression(QueryExpression)
>> We are interested in knowing, through this model, which is the query
>> that defines a View, so I guessed that may be the place to get it.
>> Can you confirm the implementation does no set this attribute? Is there
>> any chance to get it into the model?
>> Cheers,
>> Víctor.
FUDForum. Page generated in 0.03124 seconds
