Home » Eclipse Projects » Virgo » XML parser implementation
XML parser implementation [message #648757] Fri, 14 January 2011 07:45 Go to next message
I have some legacy code with dependencies to Oracles Xml parser v. 2.
I would like to deploy this as web bundle.
In order to make the code work - i need to add the jar xmlparserv2-1.0.0.jar to my bundles classpath. I have just added the jar to the lib folder in the META-INF of my bundle and added the jar to my bundles Bundle-Classpath in the MANIFEST.
This seems to work -- but now one of my other (Spring) bundles complains with
Caused by: javax.xml.parsers.FactoryConfigurationError: Provider oracle.xml.jaxp.JXDocumentBuilderFactory not found
at javax.xml.parsers.DocumentBuilderFactory.newInstance(Documen tBuilderFactory.java:129)
at org.springframework.beans.factory.xml.DefaultDocumentLoader. createDocumentBuilderFactory(DefaultDocumentLoader.java:89)
at org.springframework.beans.factory.xml.DefaultDocumentLoader. loadDocument(DefaultDocumentLoader.java:70)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReade r.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:388)
when parsing the bean definition.
The Oracle parser dependent web bundle is deployed in a PAR containing other bundles as well.
Why does adding the oracle xml parser jar to a bundles (private??) classpath affect the other bundles in my PAR?
Shouldn't they still use the standard XML parser in Java 6?
/Eva
Re: XML parser implementation [message #648786 is a reply to message #648757] Fri, 14 January 2011 09:08 Go to previous messageGo to next message
Does the parser dependent web bundle accidentally export any XML parser packages?
Re: XML parser implementation [message #648792 is a reply to message #648786] Fri, 14 January 2011 09:21 Go to previous messageGo to next message
No, the only Export-Packages are internal business logic classes.
The oracle parser jar contains classes in the packages javax.xml.parsers, javax.xml.transform, javax.xml.transform.dom, javax.transform.sax, javax.transform.stream.
But why do the classes in these packages show up on the other bundles classpath??
/Eva
Re: XML parser implementation [message #648798 is a reply to message #648792] Fri, 14 January 2011 09:30 Go to previous messageGo to next message
I guess it's due to the peculiar way in which document builder factories are located, which is presumably not OSGi friendly. I'd be very surprised if the Oracle classes are actually loadable from the other bundles.
Not sure how to proceed on this one. Have you tried deploying the bundles outside a PAR for comparison?
Re: XML parser implementation [message #648805 is a reply to message #648798] Fri, 14 January 2011 10:19 Go to previous messageGo to next message
Haven't tried that.
Setting the parameters
-Djavax.xml.parsers.DocumentBuilderFactory=com.sun.org.apach e.xerces.internal.jaxp.DocumentBuilderFactoryImpl -Djavax.xml.transform.TransformerFactory=com.sun.org.apache. xalan.internal.xsltc.trax.TransformerFactoryImpl -Djavax.xml.parsers.SAXParserFactory=com.sun.org.apache.xerc es.internal.jaxp.SAXParserFactoryImpl
in the virgo servers launch configuration got me past the error, though.
/Eva
Re: XML parser implementation [message #648809 is a reply to message #648805] Fri, 14 January 2011 10:35 Go to previous messageGo to next message
I suppose desperate times call for desperate measures.
Glad you are making progress now. Smile
Re: XML parser implementation [message #648965 is a reply to message #648809] Sun, 16 January 2011 15:11 Go to previous messageGo to next message
Right you are!
You are probably right that the Oracle code is osgi-hostile - using System.setProperty or something like that.
Oh well Smile
/Eva
Re: XML parser implementation [message #1122793 is a reply to message #648757] Tue, 01 October 2013 19:36 Go to previous messageGo to next message
Sorry to brings to this old thread alive again, but I've got this problem here to.
I have a bundle that embeds Eclipse Birt Runtime using Bundle ClassPath, and after do that, some other bundles have throw this error by simple loading their spring contexts.
Can a bundle classpath inner dependency, afect how another bundles context is loaded? This can be some bug? I can post a test case to replicate this problem if needed.
Re: XML parser implementation [message #1123071 is a reply to message #1122793] Wed, 02 October 2013 02:57 Go to previous messageGo to next message
It would be great if you can provide a "small" test case to reproduce this problem. Then it will be much easier for interested people digging into this problem if they can spare some time.
[Updated on: Wed, 02 October 2013 06:37] by Moderator
Re: XML parser implementation [message #1123312 is a reply to message #1123071] Wed, 02 October 2013 08:32 Go to previous messageGo to next message
Sure! I will do that this afternoon! Thanks!
Re: XML parser implementation [message #1123736 is a reply to message #1123071] Wed, 02 October 2013 17:49 Go to previous messageGo to next message
I've tried to create a test case, but I can't replicate the problem only configuring the Bundle-Classpath with the xml parser..
I guess that Birt Report Engine sets a new parser when it is configured. Post a test project case, with all the Birt runtime will be a bad idea (about 50MB). I will post more details!
Re: XML parser implementation [message #1249328 is a reply to message #1123736] Tue, 18 February 2014 01:13 Go to previous messageGo to next message
I am sorry to reopen the thread again !.
I have a similar case in my Virgo setup where I have conflicts with the org.apache.xerces.jaxp.SAXParserFactoryImpl, and com.sun.org.apache.xerces.internal.jaxp.SAXParserFactoryImpl. I have my JMX_OPTS in dmk.bat for my xml needs as below
set JMX_OPTS=%JMX_OPTS% -Djavax.xml.parsers.DocumentBuilderFactory=com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderFactoryImpl
set JMX_OPTS=%JMX_OPTS% -Djavax.xml.transform.TransformerFactory=com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFactoryImpl
set JMX_OPTS=%JMX_OPTS% -Djavax.xml.parsers.SAXParserFactory=com.sun.org.apache.xerces.internal.jaxp.SAXParserFactoryImpl
While I want to use the com.sun.*.SAXParserFactory for my xml loading needs, I depend on a library(eclipse.sphinx.emf) which depends on org.apache.xerces.*.SAXParserFactoryImpl. So while using the library I get the below error.
[Request processing failed; nested exception is java.lang.ClassCastException: org.eclipse.sphinx.emf.resource.ExtendedErrorHandlerWrapper cannot be cast to com.sun.org.apache.xerces.internal.xni.parser.XMLErrorHandler] with root cause java.lang.ClassCastException: org.eclipse.sphinx.emf.resource.ExtendedErrorHandlerWrapper cannot be cast to com.sun.org.apache.xerces.internal.xni.parser.XMLErrorHandler
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.setProperty(XMLErrorReporter.java:589)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.setProperty(XML11Configuration.java:965)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.setProperty(AbstractSAXParser.java:1946)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.setProperty(SAXParserImpl.java:518)
at org.eclipse.sphinx.emf.resource.ExtendedXMLLoadImpl.load(ExtendedXMLLoadImpl.java:180)
Is there a way to override the JMX_OPTS for a special cases ?
Murthy
Re: XML parser implementation [message #1251439 is a reply to message #1249328] Thu, 20 February 2014 03:09 Go to previous messageGo to next message
I was able to resolve this issue by explicitly setting the system property before calling the sphinx dependent module in the java code and then reset it back. Something like below
		//Get the properties for later resetting
		String saxParserFactory = System.getProperty("javax.xml.parsers.SAXParserFactory");
        String documentBuilderFactory = System.getProperty("javax.xml.parsers.DocumentBuilderFactory");
        String transformerFactoryImpl = System.getProperty("javax.xml.transform.TransformerFactory");
		//Override the xml properties with the apache.xerces factories
        System.setProperty("javax.xml.parsers.DocumentBuilderFactory","org.apache.xerces.jaxp.DocumentBuilderFactoryImpl");
        System.setProperty("javax.xml.parsers.SAXParserFactory","org.apache.xerces.jaxp.SAXParserFactoryImpl");
        System.setProperty("javax.xml.transform.TransformerFactory","org.apache.xalan.xsltc.trax.TransformerFactoryImpl");
		//My Sphinx related code.......
		//Reset the old factories back
        System.setProperty("javax.xml.parsers.SAXParserFactory",saxParserFactory);
        System.setProperty("javax.xml.parsers.DocumentBuilderFactory",documentBuilderFactory);
        System.setProperty("javax.xml.transform.TransformerFactory",transformerFactoryImpl);
Though my XML parsing works with this setting, using org.apache.xerces is very slow(~2 sec per xml file). any idea what could be wrong ?
Murthy
Re: XML parser implementation [message #1256278 is a reply to message #1251439] Tue, 25 February 2014 04:14 Go to previous messageGo to next message
Hi Murthy,
did you find some more time to investigate this? (e.g. with a profiling tool as mentioned here).
florian
Re: XML parser implementation [message #1262198 is a reply to message #1256278] Mon, 03 March 2014 06:11 Go to previous messageGo to next message
Hello Florian,
Yes,we've tried the yourkit profiler. We are still stuck with the sphinx library as it depends on "org.apache.xerces". Somehow our xml parsing is 5 times faster when I use com.sun.org.apache as compared to parsing using org.apache.xalan. I have posted my query question in Sphinx forum, but have not got any response yet.
Also I sometimes face some problems while starting up the Virgo server due to the sphinx library. Apparently when virgo tries to resolve the dependencies of org.eclipse.sphinx.platform, sometimes it enters into a race condition where the server startup just hangs. Restart is then the only way out. Any idea what could be wrong ? Could these issues related ?
Murthy
Re: XML parser implementation [message #1853124 is a reply to message #1251439] Sun, 19 June 2022 10:14 Go to previous message
It worked for me @Murthy Bhat. Thank you!
[Updated on: Sun, 19 June 2022 10:16] by Moderator
Previous Topic:Virgo Future
Next Topic:AspectJ logs not printing issue with Open JDK 17
Current Time: Sat Aug 16 09:57:24 EDT 2025
Powered by FUDForum. Page generated in 0.06986 seconds
