pattern attribute of correlation implicitly always set [message #647627] |
Fri, 07 January 2011 13:15 |
Christoph Messages: 21 Registered: September 2010 |
As always, this is a question to the developers
SA00046 of App. B in the BPEL spec asks to check whether the pattern attribute of a correlation is set in some cases. As it points out, the pattern attribute is implicitly ALWAYS set in the model of the process. Thus, asking for correlation.getPattern() == null is useless (the value of pattern is always request, as long as not explicitly set to response or requestresponse).
So I'm keen on the answer how to check then whether the correlation uses the attribute.
The BPEL Validator uses an own model, I know. But I'm committed to the task to develop another validator, just if you ask.
[Updated on: Fri, 07 January 2011 17:53] Report message to a moderator
Re: pattern attribute of correlation implicitly always set [message #648105 is a reply to message #647627] |
Tue, 11 January 2011 09:10 |
Hi Bob,
I know how the BPEL validator handles this rule, but I cannot go the same way (building an own tree of the process and using this for validation).
SA00046 says that one MUST NOT use the pattern attribute if the invoked operation is one-way. But since the attribute is always implicitly set, I cannot programmatically decide, whether the attribute is used or not. I wonder whether this (implicitly set attribute) is a violation of the specification.
[Updated on: Tue, 11 January 2011 09:10] Report message to a moderator
Re: pattern attribute of correlation implicitly always set [message #648643 is a reply to message #648105] |
Thu, 13 January 2011 18:39 |
Ah, I think I understand what you're saying now: you are suggesting that the CorrelationImpl class should NOT be initializing the pattern attribute to "request" on construction and should simply leave it as null, right? You probably have a point here, but I would have to see what, if anything, is affected by a change like this.
Can you please file a bugzilla here so that we can track this?
Thanks!
Bob
FUDForum. Page generated in 0.06906 seconds
