Home » Newcomers » Newcomers » no errors shown in package explorer using Eclipse for Java
no errors shown in package explorer using Eclipse for Java [message #647549] |
Fri, 07 January 2011 01:55 |
Missing name Mising name Messages: 12 Registered: January 2010 |
Junior Member |
My problem is with the "error" notification in Eclipse. I am using Eclipse for Java Developers (Galileo- build: 20090920-1017), and primarily developing Android projects (Android Development Tools 0.9.7.v201005071157-36220), although my problem occurs with non-android Java projects as well.
Everything used to work "fine" (and I don't remember making any changes to explain the new behavior): red error markers used to showed up highlighting the problem code "in-line", show up in the file margin, show up in the tab displaying the open file, show up in "package explorer" by the file name, and finally the entire project would show up with a red error marker.
Now, the only error markers I get, are the errors highlighting the problematic code "in-line", and in the file margin. There is no error demarcated in the tab displaying the open file, or more importantly in the package explorer. [This is why this problem is frustrating because the only way I can find my errors is to open and peruse every file...] Even the project name in the package explorer no longer is indicated as having an error.
I have found a few references to this problem, and the fix usually entails turning on the "Build Automatically" option (which I have done), making sure the "java Builder" is on the list of Builders (which it is), and repeatedly clean&build project and/or close/open Eclipse.
Any help appreciated.
Thnx, Jim
Re: no errors shown in package explorer using Eclipse for Java [message #647561 is a reply to message #647549] |
Fri, 07 January 2011 04:51 |
> having an error.
> Thnx, Jim
What happens when you do Window -> Show View -> Other... -> General ->
Problems ?
Re: no errors shown in package explorer using Eclipse for Java [message #647589 is a reply to message #647549] |
Fri, 07 January 2011 08:19 |
Dani Megert Messages: 3802 Registered: July 2009 |
> Eclipse.
Make sure that your files are on the Java build path of the project.
Dani
> Thnx, Jim
Current Time: Fri Apr 26 22:43:35 GMT 2024
Powered by FUDForum. Page generated in 0.09512 seconds
