| i can't deploy process bpel in ode [message #647284] |
Wed, 05 January 2011 09:42  |
i had installed bpel and ode
i take ode in tomcat/webapps
when i start ode, i have this message console
5 janv. 2011 14:45:21 org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jre6\bin;.;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\sys tem32;C:\WINDOWS;C:/Program Files/Java/jre6/bin/client;C:/Program Files/Java/jre6/bin;C:/Program Files/Java/jre6/lib/i386;C:\WINDOWS\system32;C:\WINDOWS;C:\W INDOWS\System32\Wbem;C:\Program Files\Java\jdk1.6.0\bin
5 janv. 2011 14:45:22 org.apache.coyote.http11.Http11BaseProtocol init
INFO: Initialisation de Coyote HTTP/1.1 sur http-8080
5 janv. 2011 14:45:22 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1281 ms
5 janv. 2011 14:45:22 org.apache.catalina.core.StandardService start
INFO: Démarrage du service Catalina
5 janv. 2011 14:45:22 org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.5.31
5 janv. 2011 14:45:22 org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
- Unable to find config file. Creating new servlet engine config file: /WEB-INF/server-config.wsdd
- Unable to find required classes (javax.activation.DataHandler and javax.mail.internet.MimeMultipart). Attachment support is disabled.
5 janv. 2011 14:45:38 org.apache.catalina.core.ApplicationContext log
INFO: org.apache.webapp.balancer.BalancerFilter: init(): ruleChain: [org.apache.webapp.balancer.RuleChain: [org.apache.webapp.balancer.rules.URLStringMatchRule: Target string: News / Redirect URL: http://www.cnn.com], [org.apache.webapp.balancer.rules.RequestParameterRule: Target param name: paramName / Target param value: paramValue / Redirect URL: http://www.yahoo.com], [org.apache.webapp.balancer.rules.AcceptEverythingRule: Redirect URL: http://jakarta.apache.org]]
5 janv. 2011 14:45:39 org.apache.catalina.core.ApplicationContext log
INFO: ContextListener: contextInitialized()
INFO: SessionListener: contextInitialized()
14:46:11,015 WARN [ODEServer] Config file C:\Documents and Settings\HK\Mes documents\Téléchargements\TOMCAT\apache-tomcat-5.5.31\weba pps\ode\WEB-INF\conf\ode-axis2.properties not found, default values will be used.
14:46:21,750 INFO [ODEServer] Using DAO Connection Factory class org.apache.ode.dao.jpa.BPELDAOConnectionFactoryImpl.
14:46:58,234 INFO [BpelProcess] Created new process DAO for {http://www.se.uni-hannover.de/soa08/tutorial/HelloBPELProce ss}HelloBPELProcess-2 (guid=lmwxsf9j1lh1ne44o85srhxuka8kx2n0).
14:46:58,328 INFO [BpelServerImpl] Registered process {http://www.se.uni-hannover.de/soa08/tutorial/HelloBPELProce ss}HelloBPELProcess-2.
14:46:58,328 INFO [CronScheduler] Cancelling PROCESS CRON jobs for: {http://www.se.uni-hannover.de/soa08/tutorial/HelloBPELProce ss}HelloBPELProcess-2
14:46:58,328 INFO [CronScheduler] Scheduling PROCESS CRON jobs for: {http://www.se.uni-hannover.de/soa08/tutorial/HelloBPELProce ss}HelloBPELProcess-2
14:46:58,562 INFO [BpelServerImpl] BPEL Server Started.
14:46:58,593 INFO [SystemSchedulesConfig] SYSTEM CRON configuration: C:\Documents and Settings\HAKIOUI Khamoussi\Mes documents\Téléchargements\TOMCAT\apache-tomcat-5.5.31\weba pps\ode\WEB-INF\conf\schedules.xml
14:47:02,265 INFO [DeploymentPoller] Poller started.
14:47:02,265 INFO [ODEServer] Process deployment polling started on path C:\Documents and Settings\HK\Mes documents\Téléchargements\TOMCAT\apache-tomcat-5.5.31\weba pps\ode\WEB-INF\processes.
14:47:02,265 INFO [ODEServer] ODE Service Engine has been started.
14:47:02,296 INFO [CronScheduler] Cancelling PROCESS CRON jobs for: {http://www.se.uni-hannover.de/soa08/tutorial/HelloBPELProce ss}HelloBPELProcess-2
14:47:02,328 INFO [CronScheduler] Scheduling PROCESS CRON jobs for: {http://www.se.uni-hannover.de/soa08/tutorial/HelloBPELProce ss}HelloBPELProcess-2
14:47:02,484 FATAL [DeploymentPoller] Encountered an unexpected error. Exiting poller...
java.lang.RuntimeException: java.lang.NullPointerException
at org.apache.ode.utils.WatchDog.check(WatchDog.java:163)
at org.apache.ode.axis2.deploy.DeploymentPoller.checkDeployXmlW atchDog(DeploymentPoller.java:198)
at org.apache.ode.axis2.deploy.DeploymentPoller.check(Deploymen tPoller.java:142)
at org.apache.ode.axis2.deploy.DeploymentPoller.access$300(Depl oymentPoller.java:60)
at org.apache.ode.axis2.deploy.DeploymentPoller$PollingThread.r un(DeploymentPoller.java:251)
Caused by: java.lang.NullPointerException
at org.apache.ode.store.ProcessStoreImpl.refreshSchedules(Proce ssStoreImpl.java:873)
at org.apache.ode.axis2.deploy.DeploymentPoller$DDWatchDogObser ver.init(DeploymentPoller.java:296)
at org.apache.ode.utils.WatchDog$DefaultObserver.onUpdate(Watch Dog.java:318)
at org.apache.ode.utils.WatchDog.check(WatchDog.java:132)
... 4 more
5 janv. 2011 14:47:03 org.apache.catalina.core.ApplicationContext log
5 janv. 2011 14:47:03 org.apache.coyote.http11.Http11BaseProtocol start
INFO: Démarrage de Coyote HTTP/1.1 sur http-8080
5 janv. 2011 14:47:04 org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
5 janv. 2011 14:47:04 org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/109 config=null
5 janv. 2011 14:47:04 org.apache.catalina.storeconfig.StoreLoader load
INFO: Find registry server-registry.xml at classpath resource
5 janv. 2011 14:47:04 org.apache.catalina.startup.Catalina start
INFO: Server startup in 102922 ms
only one process "HelloBPELProcess-2" is shown in:
http://localhost:8080/ode/processes.html
and it sn't deployed
although i had 6 processes in ode/WEB-INF/processes
when i tape :
the URL of wsdl file,
http://localhost:8080/ode/processes/HelloBPELService
i have the exception
<Exception>
org.apache.axis2.AxisFault: The endpoint reference (EPR) for the Operation not found is /ode/processes/HelloBPELService and the WSA Action = null
at org.apache.axis2.engine.DispatchPhase.checkPostConditions(Di spatchPhase.java:86)
at org.apache.axis2.engine.Phase.invoke(Phase.java:308)
at org.apache.axis2.engine.AxisEngine.invoke(AxisEngine.java:21 2)
at org.apache.axis2.engine.AxisEngine.receive(AxisEngine.java:1 32)
at org.apache.axis2.transport.http.util.RESTUtil.invokeAxisEngi ne(RESTUtil.java:125)
at org.apache.axis2.transport.http.util.RESTUtil.processURLRequ est(RESTUtil.java:119)
at org.apache.axis2.transport.http.AxisServlet$RestRequestProce ssor.processURLRequest(AxisServlet.java:799)
at org.apache.axis2.transport.http.AxisServlet.doGet(AxisServle t.java:242)
at org.apache.ode.axis2.hooks.ODEAxisServlet.doGet(ODEAxisServl et.java:62)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:627)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:188)
at org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:172)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:174)
at org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:879)
at org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:665)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:528)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:81)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:689)
at java.lang.Thread.run(Unknown Source)
</Exception>
i apllied many tutorials
have you suggestion , a zip file of deploiment
or the correct steps for deploiement
thanks for answer
[Updated on: Wed, 05 January 2011 09:45] by Moderator
FUDForum. Page generated in 0.04005 seconds
