unable to launch Ecore Examples using 3D editor [message #647014] |
Tue, 04 January 2011 03:19 |
psuedopoda Messages: 4 Registered: December 2010 |
Hi Jens,
We have finally installed GEF3D and also we are able to see the camera.
The problems now are as follows:
1.We created a GEF3D example file and were able to see using 3D editor but we are a bit confused about using the camera as in are there any particular buttons, controls or combination of them to be used while changing the angle of the diagram or rotating the whole plane.
2.We created an Ecore diagram with just a single class in it to just taste the flavor of 3D effect. But when we open the Ecore diagram file with 3D editor, the eclipse session gets closed with the following errors on the parent eclipse session. Please also see the attached screen shot.
Jan 3, 2011 6:42:01 PM org.eclipse.draw3d.graphics3d.Graphics3DRegistry updateDescriptors
INFO: Extension found: org.eclipse.core.internal.registry.ExtensionHandle@500, Contributor: org.eclipse.draw3d.lwjgl
Jan 3, 2011 6:42:01 PM org.eclipse.draw3d.graphics3d.lwjgl.Graphics3DLwjgl <init>
INFO: Graphics3DLwjgl constructor called
Jan 3, 2011 6:45:16 PM org.eclipse.draw3d.graphics3d.lwjgl.Graphics3DLwjgl <init>
Jan 3, 2011 6:48:39 PM org.eclipse.draw3d.graphics3d.lwjgl.Graphics3DLwjgl <init>
Jan 3, 2011 6:48:39 PM org.eclipse.gef3d.gmf.runtime.diagram.ui.services.editpart.D iagramRootEditPart3DProvider <init>
INFO: Created
Jan 3, 2011 6:48:39 PM org.eclipse.gef3d.gmf.runtime.diagram.ui.services.editpart.D iagramRootEditPart3DProvider createRootEditPart
INFO: Create Root!
Re: unable to launch Ecore Examples using 3D editor [message #647251 is a reply to message #647014] |
Wed, 05 January 2011 12:12 |
See http://wiki.eclipse.org/GEF3D_Camera
> screen shot.
Cool, a "real" screen shot :-) Unfortunately it doesn't help me solving
your problem. Are there any exceptions (stack trace) or messages shown
in the error log?
The console log doesn't show any problems, I've got the very same
output. There should be some more output either in the console or in the
error log.
Jens
FUDForum. Page generated in 0.03921 seconds
