Re: [EMF ECORE] EMF model [message #647111 is a reply to message #647034] |
Tue, 04 January 2011 16:02 |
Ed Merks Messages: 33142 Registered: July 2009 |
ST,
Comments below.
ST wrote:
> I'm not sure I follow your question. What's a "virgin example EMF"?
> Q1: how can I create an EMF model from a meta-model without using the
> wizards (which class use?) ?
If you invoke Generate Test Code and check out the generated
XyzExample.java you'll see how it creates an instance of the model and
saves it to a resource.
> Q2: I have a model "XML file", and I want to convert it to a model EMF
> ". ecore", how can I do it?
Likely the XyzExample.java answer this question too.
> thx
Ed Merks
FUDForum. Page generated in 0.03029 seconds
