emf.Ecore2Java Ant task is flaky [message #646586] |
Wed, 29 December 2010 01:04 |
Mirko Raner Messages: 125 Registered: July 2009 Location: New York City, NY |
Hi all,
we're using the emf.Ecore2Java task in an external tools builder to generate the Java sources from a .genmodel file. Unfortunately, the task is producing somewhat inconsistent results and works only half of the time, it seems.
There is an Ant target that deletes the src-gen folder when the .ecore or .genmodel file is updated and another target that regenerates the src-gen folder if it is not present:
<target name="generate" depends="check-rebuild" unless="already-exists">
<mkdir dir="src-gen"/>
<eclipse.refreshLocal resource="com.intuit.eclipse.emf.tps.formset" depth="infinite"/>
<emf.Ecore2Java genmodel="model/formset.genmodel" reconcileGenModel="keep"
generateJavaCode="true"
generatetestsproject="false"
generateeditproject="false"
generateeditorproject="false"
generatemodelproject="true"
modelproject="com.intuit.eclipse.emf.tps.formset"
modelpluginid="com.intuit.eclipse.emf.tps.formset"
modelprojectfragmentpath="src-gen">
<model file="model/formset.ecore"/>
</emf.Ecore2Java>
</target>
First of all, without the eclipse.refreshLocal, the emf.Ecore2Java would report that it was generating all the source files, but the src-gen folder would still be empty after the task finished. Only when running the task a second time (?!) the src-gen folder was properly populated. Luckily (though somewhat inexplicably), adding the eclipse.refreshLocal task fixed that.
Now I have the problem that only a part of the sources is generated sometimes. Especially, the .util package with the base implementations of resources and resource factories often remains incomplete (i.e., a couple sources are generated while others are missing) after the project was just imported into the workspace. There are no indications on the console that would indicate that emf.Ecore2Java ran into any kind of trouble during execution, and the Ant build finishes successfully, so I'm not sure how to debug this.
Any ideas what's going here or how I could further debug this? I'm already running Ant with -d but nothing out of the ordinary is reported.
Mirko
Re: emf.Ecore2Java Ant task is flaky [message #646588 is a reply to message #646586] |
Wed, 29 December 2010 01:23 |
Ed Merks Messages: 33142 Registered: July 2009 |
Mirko,
Comments below.
Mirko Raner wrote:
> Hi all,
> the time, it seems.
Which half? :-P
> depth="infinite"/>
> </emf.Ecore2Java>
> </target>
If the workspace is updated "externally" a refresh is needed to get the
state back in sync... Are there any problems reported in the error log?
> properly populated.
I suppose something in the first attempt is doing a refresh.
I imagine if there are failures, they'd be recorded in the error log.
Given that the generator is more generally running within the IDE,
writing to System.out/err wouldn't normally be a good way to inform the
user...
The error log; <workspace>/.metadata/.log, is likely to yield
informative traces.
> Mirko
Ed Merks
Re: emf.Ecore2Java Ant task is flaky [message #646592 is a reply to message #646588] |
Wed, 29 December 2010 02:45 |
Good point, Ed! I forgot that emf.Ecore2Java actually runs inside the IDE and did not check the workspace log.
There are a couple of warnings like this in the log:
org.eclipse.emf.common.util.WrappedException: org.eclipse.emf.codegen.jet.JETException: ClassNotFoundException: org.eclipse.emf.codegen.ecore.templates.model.FactoryClass_
at org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAda pter.generateJava(AbstractGeneratorAdapter.java:1112)
at org.eclipse.emf.codegen.ecore.genmodel.generator.GenPackageG eneratorAdapter.generateFactoryInterface(GenPackageGenerator Adapter.java:520)
at org.eclipse.emf.codegen.ecore.genmodel.generator.GenPackageG eneratorAdapter.generateModel(GenPackageGeneratorAdapter.jav a:220)
at org.eclipse.emf.codegen.ecore.genmodel.generator.GenBaseGene ratorAdapter.doGenerate(GenBaseGeneratorAdapter.java:221)
at org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAda pter.generate(AbstractGeneratorAdapter.java:290)
at org.eclipse.emf.codegen.ecore.generator.Generator.generate(G enerator.java:617)
at org.eclipse.emf.codegen.ecore.generator.Generator.generate(G enerator.java:528)
at org.eclipse.emf.codegen.ecore.Generator$PlatformRunnable$1.r un(Generator.java:424)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1975)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1957)
at org.eclipse.emf.codegen.ecore.Generator$PlatformRunnable.run (Generator.java:458)
at org.eclipse.emf.codegen.ecore.Generator.run(Generator.java:1 17)
at org.eclipse.emf.ant.taskdefs.codegen.ecore.GeneratorTask.gen erateCodeFromGenModel(GeneratorTask.java:531)
at org.eclipse.emf.ant.taskdefs.codegen.ecore.GeneratorTask.doE xecute(GeneratorTask.java:394)
at org.eclipse.emf.ant.taskdefs.EMFTask.execute(EMFTask.java:76 )
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:357)
at org.apache.tools.ant.Target.performTasks(Target.java:385)
at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1337)
at org.apache.tools.ant.Project.executeTarget(Project.java:1306 )
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
at org.apache.tools.ant.Project.executeTargets(Project.java:118 9)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:662)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:495)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:378)
at org.eclipse.ant.internal.launching.launchConfigurations.AntL aunchDelegate.runInSameVM(AntLaunchDelegate.java:321)
at org.eclipse.ant.internal.launching.launchConfigurations.AntL aunchDelegate.launch(AntLaunchDelegate.java:274)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:853)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:702)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:695)
at org.eclipse.core.externaltools.internal.model.ExternalToolBu ilder.launchBuild(ExternalToolBuilder.java:181)
at org.eclipse.core.externaltools.internal.model.ExternalToolBu ilder.doBuildBasedOnScope(ExternalToolBuilder.java:169)
at org.eclipse.core.externaltools.internal.model.ExternalToolBu ilder.build(ExternalToolBuilder.java:88)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:629)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:172)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:203)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:255)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:258)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:311)
at org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:343)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:144)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:242)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: org.eclipse.emf.codegen.jet.JETException: ClassNotFoundException: org.eclipse.emf.codegen.ecore.templates.model.FactoryClass_
at org.eclipse.emf.codegen.jet.JETEmitter$EclipseHelper.initial ize(JETEmitter.java:883)
at org.eclipse.emf.codegen.jet.JETEmitter.initialize(JETEmitter .java:397)
at org.eclipse.emf.codegen.jet.JETEmitter.generate(JETEmitter.j ava:459)
at org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAda pter.generateJava(AbstractGeneratorAdapter.java:981)
... 55 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.emf.codegen.ecore.templates.model.FactoryClass_
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:319)
at java.lang.ClassLoader.loadClass(ClassLoader.java:254)
at org.eclipse.emf.codegen.jet.JETEmitter$EclipseHelper$3.loadC lass(JETEmitter.java:841)
at org.eclipse.emf.codegen.jet.JETEmitter$EclipseHelper.initial ize(JETEmitter.java:861)
... 58 more
The affected class varies, though. In the log there are entries that report ValidatorClass_, XMLProcessorClass_, FactoryClass_, EnumClass_, or simply Class_ to be not found. So, apparently, this has to do with the generated .JETEmitters project.
Re: emf.Ecore2Java Ant task is flaky [message #646597 is a reply to message #646592] |
Wed, 29 December 2010 03:28 |
Mirko,
It sounds like the generator is trying to load dynamic templates.
You're making use of dynamic templates? Maybe a task that removes the
hidden .JETEmitters project so it can be regenerated cleanly will help...
> Adapter.java:520)
> enerator.java:617)
> enerator.java:528)
> java:1975)
> java:1957)
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
> Utils.java:106)
> ssorImpl.java:39)
> ager.java:629)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> ldManager.java:172)
> ldManager.java:203)
> ager.java:255)
> ldManager.java:258)
> ager.java:343)
> ildJob.java:144)
> ob.java:242)
> .java:397)
> .. 55 more
> at java.security.AccessController.doPrivileged(Native Method)
> .. 58 more
Ed Merks
FUDForum. Page generated in 0.03117 seconds
