Home » Archived » Tycho » Naming of generated .zip files from product
Naming of generated .zip files from product [message #646534] Tue, 28 December 2010 04:07 Go to next message
Hi all,
I'm currently creating the build for the proposed eclipse RTP project.
So, first of all I want to say that it's pretty easy to create an
eclipse based build with tycho, good job!
But I'm stumbling with one issue regarding the naming of the created
product .zip files. i can explain this using the tycho-demo/itp04-rcp
example. When you run this build two zip file will be created. The name
of one of this files is:
example.product.id-linux.gtk.x86.zip
That's not what I need for my zip files. I need a format like this:
example.product.id-<version>-<buildType>-incubation-linux.gtk.x86-.zip
I searched a while for a solution but I can't find one. Can somebody
tell me how to affect the name of this archived zip files? Thanks in
advance.
Regards Holger
Holger Staudacher | EclipseSource Karlsruhe
Need professional support for RAP and RCP?
Go to: http://eclipsesource.com/support
Twitter : @hstaudacher
Blog : http://eclipsesource.com/blogs/tag/rap/
Re: Naming of generated .zip files from product [message #647899 is a reply to message #646534] Mon, 10 January 2011 05:40 Go to previous messageGo to next message
for now you will have to rename the zip file in a post-build step (e.g.
using maven antrun plugin).
Not sure if we should make this configurable as we have potentially several
products and file names have to be unique across all configured
environments.
Once installed/deployed to a maven repo, the file name is always changed
anyway by maven to standard
<artifactid>-<version>-<classifier>.<extension>
which can't be configured as this is how maven locates artifacts.
Best Regards,
Jan
"Holger Staudacher" <hstaudacher@eclipsesource.com> wrote in message
news:ifc92n$g9m$1@news.eclipse.org...
> Hi all,
> I'm currently creating the build for the proposed eclipse RTP project. So,
> first of all I want to say that it's pretty easy to create an eclipse
> example. When you run this build two zip file will be created. The name of
> I searched a while for a solution but I can't find one. Can somebody tell
> me how to affect the name of this archived zip files? Thanks in advance.
> Regards Holger
Re: Naming of generated .zip files from product [message #647900 is a reply to message #647899] Mon, 10 January 2011 05:47 Go to previous messageGo to next message
Hi Jan,
thanks for your answer. I solved teh problem using the maven assembly plugin.
Regards Holger
> environments.
> Best Regards,
> Jan
>> Hi all,
>> Regards Holger
Re: Naming of generated .zip files from product [message #655357 is a reply to message #647900] Sat, 19 February 2011 14:39 Go to previous messageGo to next message
Holger/Jan,
Can you point us to where RTP is exactly using this? I have so far seen no
further update on my question regarding the examples or automatically
deploying to an update site from Maven/Hudson with Tycho.
It works rather well manually for UOMo and the feature is also visually
integrated with Eclipse now, but having either the ZIP archive of that
feature or an update site built by Hudson would be great.
TIA,
Werner Keil | UOMo Lead
Re: Naming of generated .zip files from product [message #655467 is a reply to message #655357] Mon, 21 February 2011 04:04 Go to previous message
Hi Werner,
RTP uses the assembly plugin to name the zip files and exclude some
files from the product during the install phase.
Just take a look at the pom.xml of the products in our repository:
http://git.eclipse.org/c/rtp/org.eclipse.rtp.git/
Hope this helps,
Regards Holger
On 2011-02-19 21:09:03 +0100, "Werner Keil" <werner.keil@gmx.net> said:
> Holger/Jan,
> no further update on my question regarding the examples or
> automatically deploying to an update site from Maven/Hudson with Tycho.
> TIA,
Previous Topic:Building Plugin-Examples with Tycho
Next Topic:Making Tycho work with a different manifest.mf location
Current Time: Wed Aug 06 00:40:29 EDT 2025
Powered by FUDForum. Page generated in 0.14842 seconds
