User Defined Sort On Grouped Data [message #646376] |
Thu, 23 December 2010 15:09 |
TicTac Messages: 3 Registered: December 2010 |
I am trying to allow report users to sort data on any column and in any sort direction (asc/desc). So far, after poring over many websites, I am still unable to achieve this.
Here is the problem:
In this contrived example the report has 3 tables; Customer Details, Order Details 1 and Order Details 2. The aim is to order by column 1 descending, in all 3 tables. In the Customer Details table this is done by including the following code for the "onPrepare" event:
importPackage( Packages.org.eclipse.birt.report.engine.api.script.element );
importPackage( Packages.org.eclipse.birt.report.model.api.simpleapi );
var sortCondition = StructureScriptAPIFactory.createSortCondition();
sortCondition.setKey("row[\"CUSTOMERNUMBER\"]");
sortCondition.setDirection("desc");
var sortKey = sortCondition.getStructure();
this.addSortCondition( SimpleElementFactory.getInstance().createSortCondition(sortK ey));
In the Order Details 1 table I have used the same method as above but this time it has no effect. This table is grouped by ORDERNUMBER, so presumably I would need to get to the "group" itself, before applying the sort condition.
With this in mind I have an Order Details 2 table. In the "beforeFactory" event I have included the following code, attempting to change the sort condition:
importPackage(Packages.org.eclipse.birt.report.model.api.ele ments);
delm = reportContext.getDesignHandle().findElement("OrderTest");
tghOrderTest = delm.getGroups().get(0);
tghOrderTest.setKey("row[\"ORDERNUMBER\"]");
tghOrderTest.setSortDirection("desc"); //"asc"
This code has no effect, although...curiously, if I swap the last two lines of code, the report does render "ORDERNUMBER" in descending order. It appears that there is a problem with the "setKey" code although I can't think why, as the syntax is identical to the working version in the "Customer Details" table.
I am new to BIRT and may have overlooked something really obvious, but having spent some time trying various options I am none the wiser.
Can you help?
Report code:
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.6.1.v20100902 Build <2.6.1.v20100915-1750></property>
<property name="units">in</property>
<method name="beforeFactory">< ![CDATA[importPackage(Packages.org.eclipse.birt.report.model .api.elements);
]]></method>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="1030">
<property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="CustomerDataSet" id="1031">
<list-property name="columnHints">
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<text-property name="displayName">CUSTOMERNUMBER</text-property>
<text-property name="heading">CUSTOMERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">CUSTOMERNAME</property>
<text-property name="displayName">CUSTOMERNAME</text-property>
<text-property name="heading">CUSTOMERNAME</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">CUSTOMERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNAME</property>
<property name="dataType">string</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select customernumber, customername
from customers
order by customernumber asc]]></xml-property>
</oda-data-set>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="OrderDataSet" id="1048">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property name="displayName">ORDERNUMBER</text-property>
<text-property name="heading">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property name="displayName">QUANTITYORDERED</text-property>
<text-property name="heading">QUANTITYORDERED</text-property>
</structure>
</list-property>
<structure>
<property name="name">ORDERNUMBER</property>
</structure>
<structure>
<property name="name">QUANTITYORDERED</property>
</structure>
</list-property>
</structure>
<structure>
<property name="nativeName">ORDERNUMBER</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select ordernumber, quantityordered
from CLASSICMODELS.ORDERDETAILS
order by ordernumber asc]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
<design:uiHints>
<design:displayName>CUSTOMERNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:displaySize>50</design:displaySize>
<design:attributes>
<design:name>CONTACTLASTNAME</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>CONTACTLASTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CONTACTLASTNAME</design:label>
<design:attributes>
<design:name>CONTACTFIRSTNAME</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>CONTACTFIRSTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CONTACTFIRSTNAME</design:label>
<design:attributes>
<design:name>PHONE</design:name>
<design:position>5</design:position>
<design:uiHints>
<design:displayName>PHONE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PHONE</design:label>
<design:attributes>
<design:name>ADDRESSLINE1</design:name>
<design:position>6</design:position>
<design:uiHints>
<design:displayName>ADDRESSLINE1</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ADDRESSLINE1</design:label>
<design:attributes>
<design:name>ADDRESSLINE2</design:name>
<design:position>7</design:position>
<design:uiHints>
<design:displayName>ADDRESSLINE2</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ADDRESSLINE2</design:label>
<design:attributes>
<design:name>CITY</design:name>
<design:position>8</design:position>
<design:uiHints>
<design:displayName>CITY</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CITY</design:label>
<design:attributes>
<design:name>STATE</design:name>
<design:position>9</design:position>
<design:uiHints>
<design:displayName>STATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATE</design:label>
<design:attributes>
<design:name>POSTALCODE</design:name>
<design:position>10</design:position>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>POSTALCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>POSTALCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>COUNTRY</design:name>
<design:position>11</design:position>
<design:uiHints>
<design:displayName>COUNTRY</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COUNTRY</design:label>
<design:attributes>
<design:name>SALESREPEMPLOYEENUMBER</design:name>
<design:position>12</design:position>
<design:uiHints>
<design:displayName>SALESREPEMPLOYEENUMBER</design:displayName >
</design:uiHints>
<design:usageHints>
<design:label>SALESREPEMPLOYEENUMBER</design:label>
<design:attributes>
<design:name>CREDITLIMIT</design:name>
<design:position>13</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>CREDITLIMIT</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CREDITLIMIT</design:label>
<design:displaySize>22</design:displaySize>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table name="Customer1" id="1032">
<property name="dataSet">CustomerDataSet</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression" type="javascript">dataSetRow["CUSTOMERNUMBER"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["CUSTOMERNAME"]</expression >
</structure>
</list-property>
<method name="onPrepare"><![CDATA[importPackage( Packages.org.eclipse.birt.report.engine.api.script.element );
this.addSortCondition( SimpleElementFactory.getInstance().createSortCondition(sortK ey)); ]]></method>
<column id="1046"/>
<column id="1047"/>
<header>
<row id="1049">
<cell id="1050">
<label id="1052">
<property name="fontWeight">bold</property>
<property name="textAlign">left</property>
<text-property name="text">Customer Details Table</text-property>
</label>
</cell>
<cell id="1051"/>
</row>
<row id="1033">
<cell id="1034">
<label id="1035">
<text-property name="text">CUSTOMERNUMBER</text-property>
</label>
</cell>
<cell id="1036">
<label id="1037">
<text-property name="text">CUSTOMERNAME</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="1038">
<cell id="1039">
<data id="1040">
<property name="whiteSpace">nowrap</property>
<property name="resultSetColumn">CUSTOMERNUMBER</property>
</data>
</cell>
<cell id="1041">
<data id="1042">
<property name="resultSetColumn">CUSTOMERNAME</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="1043">
<cell id="1044"/>
<cell id="1045"/>
</row>
</footer>
</table>
<table name="Order1" id="1053">
<property name="dataSet">OrderDataSet</property>
<structure>
<expression name="expression" type="javascript">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<property name="name">SUM_QUANTITY</property>
<text-property name="displayName">SUM_QUANTITY</text-property>
<property name="dataType">float</property>
<simple-property-list name="aggregateOn">
<value>OrderNumber</value>
</simple-property-list>
<property name="aggregateFunction">SUM</property>
<list-property name="arguments">
<structure>
<property name="name">Expression</property>
<expression name="value" type="javascript">row["QUANTITYORDERED"]</expression>
</structure>
</list-property>
</structure>
</list-property>
sortCondition.setKey("row[\"ORDERNUMBER\"]");
<column id="1067"/>
<column id="1068"/>
<header>
<row id="1069">
<cell id="1070">
<label id="1072">
<text-property name="text">Order Details Table (Example 1)</text-property>
</label>
</cell>
<cell id="1071"/>
</row>
<row id="1054">
<cell id="1055">
<label id="1056">
<text-property name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="1057">
<label id="1058">
<text-property name="text">QUANTITYORDERED</text-property>
</label>
</cell>
</row>
</header>
<group id="1073">
<property name="groupName">OrderNumber</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr" type="javascript">row["ORDERNUMBER"]</expression>
<structure name="toc">
<expression name="expressionValue" type="javascript">row["ORDERNUMBER"]</expression>
</structure>
<property name="repeatHeader">true</property>
<property name="hideDetail">false</property>
<property name="pageBreakAfter">auto</property>
<property name="pageBreakBefore">auto</property>
<property name="pageBreakInside">auto</property>
<header>
<row id="1074">
<cell id="1075">
<data id="1080">
<property name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="1076">
<data id="1081">
<property name="resultSetColumn">SUM_QUANTITY</property>
</data>
</cell>
</row>
</header>
</group>
<footer>
<row id="1064">
<cell id="1065"/>
<cell id="1066"/>
</row>
</footer>
</table>
<table name="OrderTest" id="1082">
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="name">QUANTITYORDERED2</property>
<structure>
<expression name="value" type="javascript">row["ORDERNUMBER"]</expression>
</structure>
</list-property>
</structure>
</list-property>
<column id="1096"/>
<column id="1097"/>
<header>
<row id="1098">
<cell id="1099">
<label name="Order2" id="1101">
<text-property name="text">Order Details Table (Example 2)</text-property>
</label>
</cell>
<cell id="1100"/>
</row>
<row id="1083">
<cell id="1084">
<label id="1085">
</label>
</cell>
<cell id="1086">
<label id="1087">
</label>
</cell>
</row>
</header>
<group id="1102">
</structure>
<header>
<row id="1103">
<cell id="1104">
<data id="1109">
</data>
</cell>
<cell id="1105">
<data id="1110">
<property name="resultSetColumn">QUANTITYORDERED2</property>
</data>
</cell>
</row>
</header>
</group>
</table>
</body>
</report>
Re: User Defined Sort On Grouped Data [message #646556 is a reply to message #646376] |
Mon, 27 December 2010 17:10 |
Take a look at
http://www.birt-exchange.org/org/devshare/designing-birt-rep orts/1308-grouping-and-table-sorting-using-de-api/
Jason
> id="1">
> .api.elements);
> ]]></method>
> <data-sources>
> <property
> </property>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> from customers
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:criteria/>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> ]]></method>
> <column id="1046"/>
> <column id="1047"/>
> <header>
> <row id="1049">
> <cell id="1050">
> <label id="1052">
> </label>
> </cell>
> <cell id="1051"/>
> </row>
> <row id="1033">
> <cell id="1034">
> <label id="1035">
> </label>
> </cell>
> <cell id="1036">
> <label id="1037">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="1038">
> <cell id="1039">
> <data id="1040">
> ]]></method>
> </data>
> </cell>
> <cell id="1041">
> <data id="1042">
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="1043">
> <cell id="1044"/>
> <cell id="1045"/>
> </row>
> </footer>
> </table>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> </list-property>
> ]]></method>
> <column id="1067"/>
> <column id="1068"/>
> <header>
> <row id="1069">
> <cell id="1070">
> <label id="1072">
> </label>
> </cell>
> <cell id="1071"/>
> </row>
> <row id="1054">
> <cell id="1055">
> <label id="1056">
> </label>
> </cell>
> <cell id="1057">
> <label id="1058">
> </label>
> </cell>
> </row>
> </header>
> <group id="1073">
> </structure>
> <header>
> <row id="1074">
> <cell id="1075">
> <data id="1080">
> </data>
> </cell>
> <cell id="1076">
> <data id="1081">
> </data>
> </cell>
> </row>
> </header>
> </group>
> <footer>
> <row id="1064">
> <cell id="1065"/>
> <cell id="1066"/>
> </row>
> </footer>
> </table>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> </list-property>
> <column id="1096"/>
> <column id="1097"/>
> <header>
> <row id="1098">
> <cell id="1099">
> </label>
> </cell>
> <cell id="1100"/>
> </row>
> <row id="1083">
> <cell id="1084">
> <label id="1085">
> </label>
> </cell>
> <cell id="1086">
> <label id="1087">
> </label>
> </cell>
> </row>
> </header>
> <group id="1102">
> </structure>
> <header>
> <row id="1103">
> <cell id="1104">
> <data id="1109">
> </data>
> </cell>
> <cell id="1105">
> <data id="1110">
> </data>
> </cell>
> </row>
> </header>
> </group>
> </table>
> </body>
> </report>
Re: User Defined Sort On Grouped Data [message #646654 is a reply to message #646618] |
Wed, 29 December 2010 16:26 |
David,
Yes this can be done. First add aggregates to header and delete detail
row. Then use script to add a sort key to the group. Take a look at
the attached example.
Jason
id="1">
<method
name="beforeFactory">< ![CDATA[importPackage(Packages.org.eclipse.birt.report.model .api);
importPackage(Packages.java.util);
//First Table
delm = reportContext.getDesignHandle().findElement("mytable");
tgh = delm.getGroups().get(0);
//tgh.setSortDirection(params["sortorder"].value);
//Use this if you want to chage the group expression
//tgh.setKeyExpr("row[\"PRODUCTCODE\"]");
importPackage(Packages.com.ibm.icu.util);
var lc = new ULocale("fr_FR");
sc = StructureFactory.createSortKey();
sc.setKey("row[\""+params["SortOn"].value+"\"]");
sc.setDirection(params["SortOrder"].value);
sc.setLocale(lc);
ph = tgh.getPropertyHandle(TableHandle.SORT_PROP);
ph.addItem(sc);
]]></method>
<parameters>
<scalar-parameter name="SortOn" id="57">
<property name="valueType">static</property>
<property name="distinct">true</property>
<list-property name="selectionList">
<structure>
<property name="value">qtyorderedAggregation</property>
<property name="label">Sum Quantity Ordered</property>
</structure>
<structure>
<property name="value">Aggregation</property>
<property name="label">Count Line Numbers</property>
</structure>
<structure>
<property
name="value">sumpriceeachAggregation</property>
<property name="label">Sum Price Each</property>
</structure>
</list-property>
<property name="paramType">simple</property>
<property name="controlType">list-box</property>
<property name="mustMatch">true</property>
<property name="fixedOrder">true</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="SortOrder" id="118">
<structure>
<property name="value">asc</property>
<property name="label">Ascending</property>
</structure>
<structure>
<property name="value">desc</property>
<property name="label">Descending</property>
</structure>
</list-property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
id="7">
<list-property name="privateDriverProperties">
<ex-property>
<name>contentBidiFormatStr</name>
<value>ILYNN</value>
</ex-property>
<ex-property>
<name>metadataBidiFormatStr</name>
</ex-property>
</list-property>
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
name="Data Set" id="8">
<structure>
<text-property
<text-property
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
<text-property
name="heading">PRODUCTCODE</text-property>
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
<text-property name="heading">PRICEEACH</text-property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
<text-property
name="heading">ORDERLINENUMBER</text-property>
</structure>
</list-property>
<list-property name="filter">
<structure>
<property name="operator">lt</property>
<expression name="expr"
<simple-property-list name="value1">
<value>10205</value>
</structure>
</list-property>
<structure>
</structure>
<structure>
<property name="name">PRODUCTCODE</property>
</structure>
<structure>
<property name="position">3</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<structure>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails]]></xml-property>
<model:DesignValues
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
<design:criteria/>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
<style name="table-header" id="99">
<property name="backgroundColor">#6078BF</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
<property name="color">#FFFFFF</property>
<property name="paddingTop">0px</property>
<property name="paddingLeft">0px</property>
<property name="paddingBottom">0px</property>
<property name="paddingRight">0px</property>
</style>
<style name="table-footer" id="100">
</style>
<style name="table-detail" id="101">
<property name="backgroundColor">#E6ECFF</property>
<property name="fontSize">x-small</property>
<property name="color">#000080</property>
</style>
<style name="table-group-header-1" id="102">
<property name="backgroundColor">#809FFF</property>
</style>
<style name="table-group-footer-1" id="103">
<property name="backgroundColor">#C0C0C0</property>
</style>
<style name="special-header" id="104">
<property name="fontSize">medium</property>
</style>
<style name="crosstab-detail" id="105">
</style>
<style name="crosstab-header" id="106">
</style>
<style name="mydata" id="107">
<property name="color">orange</property>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<table name="mytable" id="9">
<property name="width">7.947916666666667in</property>
<property name="dataSet">Data Set</property>
<structure>
<text-property
</structure>
<structure>
<text-property
type="javascript">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
type="javascript">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
<structure>
<property name="name">qtyorderedAggregation</property>
<text-property
name="displayName">sumQTY</text-property>
<value>NewTableGroup1</value>
<structure>
</structure>
</list-property>
</structure>
<structure>
<property
name="name">sumpriceeachAggregation</property>
<text-property
name="displayName">sumPrice</text-property>
<structure>
type="javascript">row["PRICEEACH"]</expression>
</structure>
</list-property>
</structure>
<structure>
<property name="name">Aggregation</property>
<text-property
name="displayName">countLineNumber</text-property>
<property name="aggregateFunction">COUNT</property>
<structure>
type="javascript">row["ORDERLINENUMBER"]</expression>
</structure>
</list-property>
</structure>
</list-property>
<column id="38">
<property name="width">1.3020833333333333in</property>
</column>
<column id="39">
<property name="width">1.1875in</property>
</column>
<column id="40">
<property name="width">1.6041666666666667in</property>
</column>
<column id="41">
<property name="width">1.5416666666666667in</property>
</column>
<column id="42">
<property name="width">2.3125in</property>
</column>
<header>
<row id="58">
<cell id="59">
<property name="colSpan">5</property>
<property name="rowSpan">1</property>
<label id="64">
<text-property name="text">This table's
group sorting is modified in the before factory</text-property>
</label>
</cell>
</row>
<row id="10">
<cell id="11">
<label id="12">
<text-property
</label>
</cell>
<cell id="13">
<label id="14">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="15">
<label id="16">
<text-property
</label>
</cell>
<cell id="17">
<label id="18">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="19">
<label id="20">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<group id="43">
<property name="groupName">NewTableGroup1</property>
<property name="sortDirection">desc</property>
</structure>
<header>
<row id="44">
<cell id="45">
<data id="56">
<property
</data>
</cell>
<cell id="46"/>
<cell id="47">
<data id="115">
<property
name="resultSetColumn">qtyorderedAggregation</property>
</data>
</cell>
<cell id="48">
<data id="116">
<structure name="numberFormat">
<property
name="category">Fixed</property>
<property
name="pattern">#,##0.00{RoundingMode=HALF_UP}</property>
</structure>
<property
name="resultSetColumn">sumpriceeachAggregation</property>
</data>
</cell>
<cell id="49">
<data id="117">
<property
name="resultSetColumn">Aggregation</property>
</data>
</cell>
</row>
</header>
<footer>
<row id="50">
<cell id="51"/>
<cell id="52"/>
<cell id="53"/>
<cell id="54"/>
<cell id="55"/>
</row>
</footer>
</group>
<footer>
<row id="32">
<cell id="33"/>
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
<cell id="37"/>
</row>
</footer>
</table>
</body>
</report>
On 12/29/2010 5:52 AM, TicTac wrote:
> Thanks for your reply Jason.
> In table 1, with the group "NewTableGroup1", is it possible to sort on
> any column, while keeping the original grouping intact? If I wished to
> see only the group header with aggregated values (no underlying detail
> shown).
> For example:
> Col1 | Col2 | Col3 |Col4
> ORDERNUMBER | SUM(QUANTITYORDERED) | SUM(PRICEEACH) |
> COUNT(ORDERLINENUMBER)
> Is it possible to order by "Col2" while still grouping by "Col1"?
> Thanks again.
> David
FUDForum. Page generated in 0.04104 seconds
