Stacktraces while parsing heap [message #646174] |
Wed, 22 December 2010 14:50 |
Guus der Kinderen Messages: 1 Registered: December 2010 |
Junior Member |
While parsing a heap dump, using a freshly downloaded version of MemoryAnalyzer, I suddenly get a couple of stacktraces, after which parsers stop. What is going on here? Are the indeces generated so far usable?
Guus
guus@heapdump:~/mat$ sudo ./ParseHeapDump.sh /home/data/heap.bin.orig
Task: Parsing heap.bin.orig
[Task: Parsing /home/data/heap.bin.orig
Subtask: Scanning /home/data/heap.bin.orig
[INFO] Heap /home/data/heap.bin.orig contains 52,686,500 objects
Subtask: Extracting objects from /home/data/heap.bin.orig
[................................................................................Task: Removing unreachable objects
Subtask: Searching for unreachable objects
Subtask: Calculate Retained Size
Subtask: Re-indexing objects
Subtask: Re-indexing classes
Subtask: Writing /home/data/heap.bin.idx.index
Subtask: Writing /home/data/heap.bin.o2c.index
Subtask: Writing /home/data/heap.bin.a2s.index
Subtask: Re-indexing outbound index
Subtask: Writing /home/data/heap.bin.inbound.index
Subtask: Writing /home/data/heap.bin.outbound.index
Subtask: Writing /home/data/heap.bin.o2hprof.index
[.........Task: Calculating Dominator Tree
Subtask: Dominator Tree calculation
Subtask: Depth-first search
Subtask: Computing dominators
Subtask: Calculate retained sizes
Subtask: Create dominators index file
!SESSION 2010-12-22 14:03:38.475 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0_19
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -application org.eclipse.mat.api.parse /home/data/heap.bin.orig
Command-line arguments: -os linux -ws gtk -arch x86_64 -consolelog -application org.eclipse.mat.api.parse /home/data/heap.bin.orig
!ENTRY org.eclipse.mat.dtfj 4 0 2010-12-22 14:10:05.581
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.mat.dtfj.InitDTFJ.stop() of bundle org.eclipse.mat.dtfj.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:860)
at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:474)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:546)
at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1098)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.decFWSL(StartLevelManager.java:593)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:261)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.java:216)
at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend(InternalSystemBundle.java:266)
at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:685)
at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:583)
at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:409)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:200)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: java.lang.NoClassDefFoundError: com/ibm/dtfj/image/CorruptDataException
at org.eclipse.mat.dtfj.InitDTFJ.stop(InitDTFJ.java:70)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:840)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:833)
... 19 more
Root exception:
FUDForum. Page generated in 0.03828 seconds
