Home » Eclipse Projects » Equinox » serverside OSGi property org.eclipse.equinox.servlet.bridge.enabled
serverside OSGi property org.eclipse.equinox.servlet.bridge.enabled [message #64891] Tue, 11 April 2006 17:06 Go to next message
We discovered this property and have to explicitly set it to true to
enable proxy servlets...that took some figuring out.
set JAVA_OPTS=-Dorg.eclipse.equinox.servlet.bridge.enabled=true
Is there any reason why the default could not be true if unspecified?
Thanks...Jim
Re: serverside OSGi property org.eclipse.equinox.servlet.bridge.enabled [message #64912 is a reply to message #64891] Tue, 11 April 2006 23:52 Go to previous message
Originally posted by: skaegi.sympatico.ca
Hi Jim,
Yes, I agree for the typical use case this setting should not be necessary.
Less config is a good thing.
So, if not explicitly specified in "launch.ini" then
"org.eclipse.equinox.servlet.bridge.enabled" will be set "true" in the
FrameworkLauncher.
Should be available in tonight's build.
-Simon
"Jim D'Anjou" <danjou@us.ibm.com> wrote in message
news:94c780d95406a3aa78abe239120268f4$1@www.eclipse.org...
> Thanks...Jim
Previous Topic:examples or unit tests for registry
Next Topic:Bundling Berkeley DBXML - Advice from the experts requested
Current Time: Sun Nov 09 12:37:56 EST 2025
Powered by FUDForum. Page generated in 0.03397 seconds
