Home » Eclipse Projects » EclipseLink » ORA-24816 on insert with LOB
ORA-24816 on insert with LOB [message #645980] Tue, 21 December 2010 08:10 Go to next message
Hi guys,
When we try to insert a record we get the following error:
Internal Exception: java.sql.SQLException: ORA-24816: Expanded non LONG bind data supplied after actual LONG or LOB column.
A bit of googling learns that the LOB column should be used last in the order of insert columns. (Although I am not sure what to do with multipe LOB coumns). Reference: http://forums.oracle.com/forums/thread.jspa?threadID=415560
Now I am not sure where this should be arranged, in EclipseLink, or the Oracle driver.
Anyone able to help me on this one?
Kind Regards,
Re: ORA-24816 on insert with LOB [message #647121 is a reply to message #645980] Tue, 04 January 2011 11:38 Go to previous messageGo to next message
What Oracle JDBC driver/version are you using? The thin driver on older versions had a 4k limit. EclipseLink supports using a locator for Lobs to work around this. Ensure your Lob is mapped as a Lob and you are using the correct OracleXXPlatform.
Re: ORA-24816 on insert with LOB [message #1721775 is a reply to message #645980] Sat, 30 January 2016 01:24 Go to previous message
This is an old post but it is the #1 result for this problem which is still occurring. I created a bug report and document a possible work around by overriding the insert statement that eclipselink uses in https://bugs.eclipse.org/bugs/show_bug.cgi?id=486883
Previous Topic:EclipseLink on Android?
Next Topic:Merge with Null being ignored
Current Time: Thu Nov 06 02:48:39 EST 2025
Powered by FUDForum. Page generated in 0.03499 seconds
