NoSuchMethodError - Display#setAppVersion on a vanilla RCP [message #645678] |
Sun, 19 December 2010 19:25 |
Aashish Patil Messages: 3 Registered: July 2009 |
Note: Please ignore - problem solved (see reply for solution)
Environment:
Fresh Eclipse 3.6.1 IDE RCP + RAP
OSX - Snow Leopard with Java 1.6.0_22
Deleted my old Eclipse directory and then installed this one pointing to old workspace.
No additional plugins installed
Created a vanilla RCP application template (With a view)
Did not add any code to the created project
Should work and show me a sample view
Instead when I click on "Launch Eclipse Application" from plugin.xml, I get the mentioned error error (full stack trace pasted at the end).
Tried deleting the project and different RCP templates. No luck- same result.
My older RCP project that used to work just fine in the previous version is also now broken and shows the same error.
Stack Trace:
!SESSION 2010-12-19 11:12:13.359 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_22
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=cocoa, NL=en_US
Framework arguments: -product com.aashishpatil.notesnmore.product
Command-line arguments: -product com.aashishpatil.notesnmore.product -data /Users/aashishpatil/Documents/workspace/../runtime-notesnmor e.product -dev file:/Users/aashishpatil/Documents/workspace/.metadata/.plug ins/org.eclipse.pde.core/notesnmore.product/dev.properties -os macosx -ws cocoa -arch x86
!ENTRY org.eclipse.osgi 4 0 2010-12-19 11:12:14.914
!MESSAGE Application error
!STACK 1
java.lang.NoSuchMethodError: org.eclipse.swt.widgets.Display.setAppVersion(Ljava/lang/Str ing;)V
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:692)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
at com.aashishpatil.notesnmore.NotesNMoreApp.start(NotesNMoreAp p.java:88)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
[Updated on: Sun, 19 December 2010 19:52] Report message to a moderator
FUDForum. Page generated in 0.02725 seconds
