Home » Archived » Eclipse Communications Framework (ECF) » Could not start the server with a different port and group(Could not start with a different port. The server by default starts with 3232 and server (group).)
Could not start the server with a different port and group [message #645210] |
Wed, 15 December 2010 18:15  |
I am using eclipse helios.Installed the latest ECF plugin.
I could start the server using eclipse.exe -console -application org.eclipse.ecf.server.generic.Server.
I am following the instructions in http://wiki.eclipse.org/ECF_Servers page.
I tried to start to server with a different port ( I used the one in the page eclipse.exe -console -application org.eclipse.ecf.provider.AppGenericServer 3285 mygroup ecf.eclipse.org 20000 )
Is there another way to start the server with a different port and group , with eclipse.exe -application command ?
Thanks and regards,
Aykut Yararbas
aykutyararbas@yahoo.com
I got an error and log file created ;
_-------------------------------------_ LOG_ under /eclipse/configurations/1233.....log
!SESSION 2010-12-15 15:09:40.929 -----------------------------------------------
eclipse.buildId=M20100909-0800
java.version=1.6.0_21
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product -application org.eclipse.ecf.provider.AppGenericServer 3285 mygroup ecf.eclipse.org 20000
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product -console -application org.eclipse.ecf.provider.AppGenericServer 3285 mygroup ecf.eclipse.org 20000
!ENTRY org.eclipse.osgi 4 0 2010-12-15 15:09:42.390
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ecf.provider.AppGenericServer" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.ant.ui.antRunner, org.eclipse.datatools.connectivity.console.profile.StorageFi leEditor, org.eclipse.ecf.example.clients.chatroomrobot, org.eclipse.ecf.example.clients.chatsorobot, org.eclipse.ecf.example.clients.chatrobot, org.eclipse.ecf.examples.eventadmin.app.EventAdminManager, org.eclipse.ecf.examples.eventadmin.app.EventAdminClient, org.eclipse.ecf.examples.remoteservices.hello.consumer.Hello Consumer, org.eclipse.ecf.examples.remoteservices.hello.ds.consumer.He lloConsumerDS, org.eclipse.ecf.examples.remoteservices.hello.ds.host.HelloH ostDS, org.eclipse.ecf.examples.remoteservices.hello.host.HelloHost , org.eclipse.ecf.examples.updatesite.server.updateSiteServer, org.eclipse.ecf.presence.bot.chatRoomRobot, org.eclipse.ecf.presence.bot.imRobot, org.eclipse.ecf.server.generic.Server, org.eclipse.ecf.server.generic.Client, org.eclipse.emf.codegen.CodeGen, org.eclipse.emf.codegen.JMerger, org.eclipse.emf.codegen.ecore.Generator, org.eclipse.emf.importer.ecore.Ecore2GenModel, org.eclipse.emf.importer.java.Java2GenModel, org.eclipse.emf.importer.rose.Rose2GenModel, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.director.app.application, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.metadata.generator.EclipseGenerator, org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.EclipseGenerator, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher , org.eclipse.equinox.p2.reconciler.application, org.eclipse.equinox.p2.repository.repo2runnable, org.eclipse.equinox.p2.repository.metadataverifier, org.eclipse.equinox.p2.artifact.repository.mirrorApplication , org.eclipse.equinox.p2.metadata.repository.mirrorApplication , org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.jdt.apt.core.aptBuild, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.pde.build.Build, org.eclipse.pde.junit.runtime.uitestapplication, org.eclipse.pde.junit.runtime.legacytestapplication, org.eclipse.pde.junit.runtime.coretestapplication, org.eclipse.pde.junit.runtime.coretestapplicationnonmain, org.eclipse.pde.junit.runtime.nonuithreadtestapplication, org.eclipse.ui.ide.workbench, org.eclipse.update.core.standaloneUpdate, org.eclipse.update.core.siteOptimizer, org.eclipse.wst.jsdt.core.JavaCodeFormatter, org.eclipse.wst.server.preview.preview.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
[Updated on: Wed, 15 December 2010 18:17] by Moderator
Re: Could not start the server with a different port and group [message #645325 is a reply to message #645210] |
Thu, 16 December 2010 11:08   |
> lloConsumerDS,
> tarter.java:369)
> tarter.java:179)
Hi Aykut,
I assume you use an ECF version newer than 2.0. Thus the application cmd
line parameter is named "org.eclipse.ecf.server.generic.Server" instead
of "org.eclipse.ecf.provider.AppGenericServer".
HTH
Markus
Current Time: Thu Sep 25 19:06:32 EDT 2025
Powered by FUDForum. Page generated in 0.03324 seconds
