Home » Modeling » GMF (Graphical Modeling Framework) » gmfgraph -> Node -> Content Pane
gmfgraph -> Node -> Content Pane [message #645125] |
Wed, 15 December 2010 11:21  |
Originally posted by: marius.groeger.googlemail.com
in a figure (rectangle) I have a simple GridLayout and two children, the
label and another rectangle. Now I want children of this element to live
inside that nested rectangle (I think this is what Alex Shatalin meant
in [1])
| Label |
| | Container | |
| | for | |
| | Children | |
I thought I could tell the generator this via the Node -> Content Pane
attribute. This accepts a child accessor, which I created for my nested
rectangle. However the diagram still wants to place children in the main
rectangle. If I add this to createNodeFigure() in my EditPart:
contentPane = setupContentPane(shape);
contentPane = ((MyFigure)contentPane).getFigureContainerArea();
then it actually works! (The nested rectangle uses an XY layout, and
when I move a child I get this strange 'phantom' feedback rectangles
that don't go away, but this is probably a different problem).
So what is the matter with Content Pane - is it supposed to work, and if
so, how?
I do not want to use Compartments, as I had different layout and design
problems with those in the past.
Marius
[1] http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg12818.html
Re: gmfgraph -> Node -> Content Pane [message #645914 is a reply to message #645757] |
Tue, 21 December 2010 02:48   |
Michael,
On 20.12.2010 13:33, Michael Golubev wrote:
> To my understanding it is not supported by the generation yet, so the
> only way to fix it right now is to write @generated NOT code like your one.
> (Personally I would prefer to create @generated NOT version of the
> setupContentPane but thats a peronal preference).
> I am not sure we have the Bugzilla for that though, please feel free to
> submit one.
Thanks for the reply, I was afraid you were in your winter break already :-)
You're right about the location of a fix, I merely did it that way to
show the nesting error.
I don't much like the @generated NOT approach, because even though the
generator preserves those changes, I loose the possibilty to re-generate
everything from scratch. Using Providers is much more elegant I find,
and IMHO also more 'Eclipse style'. But I don't see a way to archive
this without touching the code. Do you have an idea?
I haven't checked this one, but unfortunatly, most of the time I found
the template approach barely usable, because it forces you to pull in
much more stuff than what you actually want to modify. More fine grained
template atoms would be great wrt this.
Marius
Re: gmfgraph -> Node -> Content Pane [message #645941 is a reply to message #645914] |
Tue, 21 December 2010 04:46   |
Eclipse User wrote on Tue, 21 December 2010 08:48 |
You can take a look here: see here
In fact, register a customEditPartProvider via org.eclipse.gmf.runtime.diagram.ui.editpartProviders which will use a CustomEditPartFactory that will redirect to CustomXXXEditPart tha extends XXXEditPart
Do you think to use aspect templates? It often allows you to modify just few lines of the template
see here: http://www.bonitasoft.org/blog/eclipse/customize-your-gmf-ed itor-by-customizing-templates/
[Updated on: Tue, 21 December 2010 04:59] by Moderator
Re: gmfgraph -> Node -> Content Pane [message #645951 is a reply to message #645941] |
Tue, 21 December 2010 05:06   |
>> re-generate everything from scratch. Using Providers is much more
>> elegant I find, and IMHO also more 'Eclipse style'. But I don't see a
>> way to archive this without touching the code. Do you have an idea?
> http://www.bonitasoft.org/websvn/listing.php?repname=Bonita+ Open+Solution&path=/bonita-studio/branches/bonita-studio -5.3.2/plugins/org.bonitasoft.studio.diagram.custom/#path_bo nita-studio_branches_bonita-studio-5.3.2_plugins_org.bonitas oft.studio.diagram.custom_
> extends XXXEditPart
This sounds very interesting! How do I disable the original Edit Part in
this case? Or will the custom provider automatically override the
existing one?
>> grained template atoms would be great wrt this.
> see here:
Yes, of course. It works perfect for the 'additions' hooks. But to give
you an example: I needed to modify the addFixedChild() method for some
of my elements. For this I had to pull in quite a lot of existing
template code.
Marius
Re: gmfgraph -> Node -> Content Pane [message #646017 is a reply to message #645988] |
Tue, 21 December 2010 09:14  |
On 21.12.2010 14:36, Aurelien Pupier wrote:
> The package is exported by default.
> Perhaps you are using an older version?
You are right, of course. In the process of moving toward using Edit
Part Providers, I reviewed my manual post processing and mistook the
reference to the XXX.edit.parts package - I was using it as a marker to
insert another export (XXX.sheet). Sorry to have bothered you with this,
I should have looked closer.
Anyway I'm banging may head against the wall for not earlier have
discovered edit part providers.
Marius
Current Time: Fri Jul 04 07:05:59 EDT 2025
Powered by FUDForum. Page generated in 0.26793 seconds
