Re: Cascading parameter issue [message #644911 is a reply to message #644739] |
Tue, 14 December 2010 16:54 |
The latest version of BIRT is 2.6.1 and can be downloaded from:
http://download.eclipse.org/birt/downloads/
Is there any chance you could create a report with the sample database
that shows the issue? or a report that uses a flat file datasource?
This is so we can run it and test it.
Jason
On 12/13/2010 9:56 PM, Neo wrote:
> I found one issue in using Cascading parameter.
> I have a report on Student Fee Categories.
> Now in this Fee Categories of many Schools are stored.
> In general what I used to do is use a Report Parameter SchoolID to
> filter and pass it to the data set query.
> Now suppose I am using cascading parameters for a query. Then From a web
> viewer in this case the School ID that I used to pass from a Report
> Parameter was not accepted. At the same time if I do a preview of the
> report in the BIRT Designer perspective, the School ID is passed.
> I am using Galileo and BIRT 2.3 runtime.
> Is this something that is already.
> If we have the latest BIRT Report Viewer(Tomcat Web deployed) Kindly let
> me know so that I can download it.
> Kind Regards, Neo
Re: Cascading parameter issue [message #645804 is a reply to message #645593] |
Mon, 20 December 2010 16:19 |
Neo
Can you open a bugzilla for this?
Jason
On 12/18/2010 8:33 AM, Neo wrote:
> Hi Jason,
> I found out couple of issues which may boil down to one issue that
> happens sometimes. This is replicating even in the Sample Database.
> 1. The normal Reporting Parameter once if you give a default value to
> it, even when you try to change the default value it won't be updated.
> 2. Also when you update a Report Parameter(Text in this case). This
> won't get updated to Cascading parameter query.
> In this case I have used orderList in which there are two input
> parameters. customer number which comes from the above level cascading
> parameter and the other one ordernumber which comes from a normal Report
> Parameter. When you give a value to the Report Parameter The order
> numbers List won't be updated with this new value of the ordernumber.
> This came up before but now when I try to add the code it dint show up.
> This is the problem I found which is not reproducible as of now.
> Kind Regards,
> Neo.
FUDForum. Page generated in 0.03364 seconds
