Re: [Xpand] Call Template for Null Object [message #644258 is a reply to message #644185] |
Fri, 10 December 2010 09:41 |
Gerd Kainz Messages: 23 Registered: May 2010 |
Junior Member |
Hi Sven,
thanks for your hint. It's working if I handover some useless data instead of null. But than I also need to change the data type from Void to something else. That's just a workaround. It doesn't solve the bug (in my opinion) behind.
Some times it makes sense to call a function (handing over all data as parameters) instead of a method (using one special element as this object).
Is there a special reason for the check against a null object, which breaks the usage of a function like call?
Gerd
[Updated on: Fri, 10 December 2010 10:05] Report message to a moderator
FUDForum. Page generated in 0.03131 seconds
