Re: [Teneo] GMF -mindmap example problem [message #64776 is a reply to message #64704] |
Mon, 18 December 2006 21:01 |
Yes this is an issue because the HibernateResource sends out notifications when loading content from
the database. This can be disabled by passing the DISABLE_NOTIFY option when loading a resource.
Which is not directly possible in the way the resource is used here (the load action is called
implicitly). I have entered a bugzilla for this and will look at this issue later.
As an intermediate workaround you can replace the part in the try catch (line 117 in
MindmapInitDiagramFileAction.java) with the following code:
Resource res = new HibernateResource(URI
.createPlatformResourceURI(mySelectedModelFile
.getFullPath().toString()));
HashMap options = new HashMap();
options.put(XMLResource.OPTION_DISABLE_NOTIFY, "true");
res.load(options);
resourceSet.getResources().add(res);
// Resource resource = resourceSet.getResource(URI
// .createPlatformResourceURI(mySelectedModelFile
// .getFullPath().toString()), true);
diagramRoot = (EObject) res.getContents().get(0);
Note that the old call to resourceSet.getResource is commented out.
gr. Martin
Kirill A. balod wrote:
> Hello,
> I have tried to repeat a tutorial which is described at
> http://www.elver.org/hibernate/gmftutorial/tutorial1.html . And have got
> "java.lang.IllegalStateException: Cannot modify resource set without a write
> transaction" from the action "Initialize mindmap_diagram diagram file"
> Any ideas?
> Thanks
> Kirill
> Exception:
> transaction
> at
> org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ssertWriting(TransactionChangeRecorder.java:295)
> at
> org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ppendNotification(TransactionChangeRecorder.java:257)
> at
> org.eclipse.emf.transaction.impl.TransactionChangeRecorder.p rocessResourceNotification(TransactionChangeRecorder.java:22 7)
> at
> org.eclipse.emf.transaction.impl.TransactionChangeRecorder.n otifyChanged(TransactionChangeRecorder.java:193)
> at
> org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:230)
> at
> org.eclipse.emf.common.notify.impl.NotificationImpl.dispatch (NotificationImpl.java:1029)
> at
> org.eclipse.emf.teneo.resource.StoreResource.addToContent(St oreResource.java:284)
> at
> org.eclipse.emf.teneo.resource.StoreResource.load(StoreResou rce.java:269)
> at
> org.eclipse.emf.teneo.resource.StoreResource.getContents(Sto reResource.java:398)
> at
> org.eclipse.emf.transaction.impl.TransactionChangeRecorder.s etTarget(TransactionChangeRecorder.java:128)
> at
> org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList.didAdd(BasicNotifierImpl.java:71)
> at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList. java:620)
> at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:6 00)
> at
> org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList.add(BasicNotifierImpl.java:119)
> at
> org.eclipse.emf.ecore.change.util.ChangeRecorder.addAdapter( ChangeRecorder.java:697)
> at
> org.eclipse.emf.ecore.change.util.ChangeRecorder.notifyChang ed(ChangeRecorder.java:352)
> at
> org.eclipse.emf.transaction.impl.TransactionChangeRecorder.n otifyChanged(TransactionChangeRecorder.java:173)
> at
> at
> org.eclipse.emf.common.notify.impl.NotifyingListImpl.dispatc hNotification(NotifyingListImpl.java:260)
> at
> org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:292)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createRe source(ResourceSetImpl.java:411)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandCr eateResource(ResourceSetImpl.java:233)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:384)
> at
> mindmap.diagram.part.MindmapInitDiagramFileAction.run(Mindma pInitDiagramFileAction.java:117)
> at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
> MindmapInitDiagramFileAction.java :
> 111 TransactionalEditingDomain editingDomain =
> GMFEditingDomainFactory.INSTANCE
> 112 .createEditingDomain();
> 113 ResourceSet resourceSet = editingDomain.getResourceSet();
> 114
> 115 EObject diagramRoot = null;
> 116 try {
> 117 Resource resource = resourceSet.getResource(URI
> 118 .createPlatformResourceURI(mySelectedModelFile
> 119 .getFullPath().toString(), true), true);
> 120 diagramRoot = (EObject) resource.getContents().get(0);
> Configuration:
> emf-sdo-xsd-SDK-M200611161441.zip
> emft-ocl-SDK-1.0.0.zip
> emft-query-SDK-1.0.1.zip
> emft-teneo-SDK-I200611290220.zip
> emft-transaction-SDK-1.0.1.zip
> emft-validation-SDK-1.0.1.zip
> GEF-SDK-3.2.1.zip
> GMF-sdk-experimental-N20061115.zip
> GMF-sdk-N20061115.zip
> hibernate-3.2.1.ga.zip
> uml2-SDK-2.0.2.zip
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] GMF -mindmap example problem [message #597048 is a reply to message #64704] |
res.load(options);
gr. Martin
> Hello,
> Any ideas?
> Thanks
> Kirill
> Exception:
> transaction
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 114
> 116 try {
> Configuration:
> GEF-SDK-3.2.1.zip
> uml2-SDK-2.0.2.zip
The Netherlands
FUDForum. Page generated in 0.02715 seconds
