headless build fails - launcher fragment not found [message #643603] |
Tue, 07 December 2010 15:26 |
Thomas Haskes Messages: 147 Registered: July 2009 |
Hi all,
I have set up a headless build for a rcp-product which sometimes fails
claiming that the native (windows) launcher artifact was not found. The
strange thing is that it does not happen all the time. Im using Hudson
to trigger the build process, and looking at the history I see that it
works well for two or three builds, then fails one, two, three times in
a row, then works again for a few builds. I have tried so many things to
figure out what actions could cause the build to fail, but I just
couldn't, it looks totally indeterministic to me, which is why do not
have any idea where I could even begin to look for the error.
Does that sound familiar to one of you guys? Any ideas where I could
have a look at?
Any help would be greatly appreciated, as this behavior is REALLY
annoying. Everytime I want to start a build it fails, and I normally
need two or three attempts until it succeeds.
I'm using eclipse 3.5 for the headless build on the server, compiling
against a target platform that contains the 3.6.1 rcp sdk and delta
pack. I had a look into the packager script and noticed that it is
looking for a directory. I found that on every build that failed the
build/tmp/<appName>/plugins/ - folder does contain the fragment, but as
a jar-archive, not as a directory. Maybe this is a hint.
Here is the last snippet of the build log.
assemble.archive:
customAssembly:
BUILD FAILED
D:\hudson\jobs\Lisa_Rcp_Deploy\workspace\com.tp.releng.deplo y.rcp\rcpAppBuilder.xml:44:
The following error occurred while executing this line:
D:\eclipse35\plugins\org.eclipse.pde.build_3.5.1.R35x_200908 20\scripts\productBuild\productBuild.xml:51:
D:\eclipse35\plugins\org.eclipse.pde.build_3.5.1.R35x_200908 20\scripts\build.xml:129:
D:\eclipse35\plugins\org.eclipse.pde.build_3.5.1.R35x_200908 20\templates\headless-build\customTargets.xml:12:
D:\eclipse35\plugins\org.eclipse.pde.build_3.5.1.R35x_200908 20\scripts\productBuild\allElements.xml:20:
D:\eclipse35\plugins\org.eclipse.pde.build_3.5.1.R35x_200908 20\scripts\genericTargets.xml:192:
D:\hudson\jobs\Lisa_Rcp_Deploy\workspace\com.tp.releng.deplo y.rcp\build\package.org.eclipse.pde.build.container.feature. all.xml:24:
D:\hudson\jobs\Lisa_Rcp_Deploy\workspace\com.tp.releng.deplo y.rcp\build\package.org.eclipse.pde.build.container.feature. all.xml:15:
D:\eclipse35\plugins\org.eclipse.pde.build_3.5.1.R35x_200908 20\scripts\productBuild\allElements.xml:54:
D:\hudson\jobs\Lisa_Rcp_Deploy\workspace\com.tp.releng.deplo y.rcp\build\package.org.eclipse.pde.build.container.feature. win32.win32.x86.xml:100:
D:\hudson\jobs\Lisa_Rcp_Deploy\workspace\com.tp.releng.deplo y.rcp\build\package.org.eclipse.pde.build.container.feature. win32.win32.x86.xml:344:
D:\hudson\jobs\Lisa_Rcp_Deploy\workspace\com.tp.releng.deplo y.rcp\build\tmp\lisa\plugins\org.eclipse.equinox.launcher.wi n32.win32.x86_1.1.1.R36x_v20100810
not found.
FUDForum. Page generated in 0.03911 seconds
