Home » Modeling » M2T (model-to-text transformation) » [XPand] strange failure (no viable alternative at input)
[XPand] strange failure (no viable alternative at input) [message #643074] Fri, 03 December 2010 17:42 Go to next message
Originally posted by: toh.fh-zwickau.de
I'm switching from XPand 0.7.2 to the current XPand 1.0.1 and get an error, which is often related with encoding issues:
ERROR | WorkflowRunner | no viable alternative at input 'Â' on line 1
org.eclipse.internal.xtend.xtend.parser.ParseException: no viable alternative at input 'Â' on line 1
Because all templates worked fine under XPand 0.7.2, I played a bit around and tried to isolate the problem. If a have a template like this, everything works fine:
«REM»
Performs the generation of javadoc comments
works not deterministic
«ENDREM»
«IMPORT gcore»
«DEFINE Root FOR MModel -»
«ENDDEFINE»
If I change just the words in the third line of the comment, so the template appears as follows, it doesn't work anymore:
«REM»
i dont understand it
«ENDREM»
«IMPORT gcore»
«ENDDEFINE»
However, I found a general workaround to move the import statement before the comment, so the template is again working correctly:
«IMPORT gcore»
«REM»
«ENDREM»
«ENDDEFINE»
This problem is somehow weird. It seams it has something to do with the multi line comment. Do you have any idea about the reason for this behavior? Personally I can live with the workaround, but interested in the cause of the problem. All templates are utf-8 encoded.
kind regards
tobi
Re: [XPand] strange failure (no viable alternative at input) [message #646008 is a reply to message #643074] Tue, 21 December 2010 09:48 Go to previous messageGo to next message
please try to set the file encoding:
<component class="org.openarchitectureware.xpand2.Generator">
   <metaModel idRef="..." />
   <fileEncoding value="UTF-8" />
Darius
Re: [XPand] strange failure (no viable alternative at input) [message #647747 is a reply to message #646008] Sat, 08 January 2011 09:41 Go to previous messageGo to next message
Hello Darius,
thank you for taking time to answer. The file encoding was already set to "utf-8". Unfortunately the change to "UTF-8" does not solve this strange behavior. But I got your idea that maybe the ' in the comment is causing the problem. I can even write
«REM»
	works not determini'stic
«ENDREM»
«IMPORT gcore»
«ENDDEFINE»
and it works fine. Well I'm not a newbie to xpand so i guess i already checked the common mistakes. I used the helios modeling distro as base but cannot really imagine that dependencies like EMF causing this behavior. It seams to me that something deeper goes wrong.
I already used the
XpandParseFacade
to parse the problematic templates and all parsing succeeds. The
Template
object gives me the correct count of definitions. Maybe I have an error in reasoning or understood something not correctly but it seams that during the interpretation of the templates something goes wrong. Unfortunately I didn't know the xpand code base that much. Maybe you could give me a hint so some classes? So I could spent some more time on this if I have some time.
I already thought about to file a ticket in the bug system but the problem is a bit hard to explain ;-)
kind regards and have a nice weekend
tobias
Re: [XPand] strange failure (no viable alternative at input) [message #647750 is a reply to message #647747] Sat, 08 January 2011 09:51 Go to previous messageGo to next message
Hello Tobias,
can you share a reproducable example?
~Christian
Re: [XPand] strange failure (no viable alternative at input) [message #648518 is a reply to message #647750] Thu, 13 January 2011 05:51 Go to previous messageGo to next message
--------------040902030900040401090603
Content-Type: text/plain; charset=UTF-8; format=flowed
Hello Christian,
Thank you for your quick answer. Sure I can share a reproducible example and I would be glad to receive any feedback, if the problem is reproducible on other installations.
I created a minimal project with the error and zipped the workspace. You will find 5 launch configurations there, 4 to execute workflows showing the problem and one for a junit test. The workflows correspond with the templates, one reports the error, one shows the work around and the other two are working (I used the templates I posted on this mailing list). The project folder customizations contains the templates, the folder config the workflow files.
kind regards
tobias
Content-Type: application/x-zip-compressed;
name="workspace.xpand.problem.zip"
Content-Disposition: attachment;
filename="workspace.xpand.problem.zip"
UEsDBAoAAAAAADhULT4AAAAAAAAAAAAAAAAYAAAAd29ya3NwYWNlLnhwYW5k LnByb2JsZW0v
UEsDBAoAAAAAACBULT4AAAAAAAAAAAAAAAAiAAAAd29ya3NwYWNlLnhwYW5k LnByb2JsZW0v
Lm1ldGFkYXRhL1BLAwQKAAAAAAANVC0+AAAAAAAAAAAAAAAAJwAAAHdvcmtz cGFjZS54cGFu
ZC5wcm9ibGVtLy5tZXRhZGF0YS8ubG9ja1BLAwQUAAAACAAUWi0+YKQd66QG AADpkgAAJgAA
AHdvcmtzcGFjZS54cGFuZC5wcm9ibGVtLy5tZXRhZGF0YS8ubG9n7Jttb9Mw EMdfM2nfwQgk
isSsJG2ztmJIoxQYT0PrECBAlZtcO7PEjmxnG3x6Lmn6RApttw4N8F5sie27 +9/56p/7Yre7
nW734PAN8RzX3XHcHbdKXKdV9VqeRz3fIzvr/WxvQRDxRAPtpzwKD8K9A/Ts OL7T2HGarru9
9ZWdMXoGSnMp9lzqU6fn+pNhEUq1100Fec0DJfU3bSDW5EAEdHvrsZTmlWQh KBJIoQ0TRrfI
YXfvnIuq94DsH7Wf7100/Afk/WTszau9EHpPOttbTxWL4VyqU8LUMI0hNyY7 iZJhGhgi1ZCO
pUOS0IQFp2wINJYhRFwMabFwfYvtrbaMYybCHRyF+ehSk1wo2TmfPDEVnBBM 4zLaQmYYedL6
rMEYnNCfC7PPWeIa7YBeJCgls+hHEF8mm+2t2503x0cf50ykHnLiEbfcR/Um 9Rs+Gr3GTtt/
1sEt6ZKYa41OSQxaY5QWAcFQT0+nSSKV6Q2k6gUyTqQAYXp9KU9jhgkQLlpz YftpcBpzoQ0o
mnJauNOXEtlcKlLIHmqKrkdFrdFyPOpVa8tU7Pe1USwwHwyI8EO2m20p8Nkc pibrsLe4queW
RHKB8gSL6EVmRyHkRioqRzZnHM5vhO7qX6q7tnndIfTTIfYTqRHnJ+11J9Ne 3Z3t2FcsFXhw
6BOpTJAacm/WF2q4MMXvKF8Iij4DAYoZ2FeGDzBBPXLRLTzcKz6U2WFF4CJR KJdLQQKWaghx
JIDE4AAlYwtyzjRREMszCClK6x7vt18SPPNnpQRSAVWpMDwG2saXzthRixyf ADljimdhCSri
Z9DJ60a4JkIaEsKACwi3t24xQ0peJyWfqtX0PTcnnck7hTMWpZh05afxjD8t v35/HddHMAAF
IoBF/suTRZBdZ60gCI9Eam4WBdkXYaU8X8SpV9eKg74WpYHDPzv2mn9XlQ7V r4vkN9YKc6gW
JXGoSiVy/689/lMJHOAYWxilkk+VA7j1m/lxW+dY2vVuZAqdCR4WJVKaLYUp 024aJ+UFp5C1
Az5MFTN5zHlEdTK2TsIuilhZZDDt8sbuFaSUB18zgUBXdAhmP0kiHmSC5lYc f0tAV35tWmx4
rXb9uhasW0FZw1lJWSDx5cKMBHIxRFXF0xFomaoAZjS9ZcrwgCfM4PxvZJWt i4Zy/M2LesX6
EC0JXPU2XY3sS09qIA++LG2v5m42+l0vu5gtiepWlyPzq+zjCSfVKajcY/Y4 2aystW933z0e
3XjdkpvZM4bUSNVxl99+V785Lr5rQzygMcpfdN12MeVWDQNWGzMB2zKNwtwz 9gqB0blzTxMs
XBQqEHP33xeYOHktQ4jIzG13ZrRrmEk1+WRAm2OIk4gZOMbnyv07HvnERb52 diIf/JTVFfeJ
BDL59qW0Jq93vvAhZs/SyDzK37QK8r8hYJ8L0PAdS87QDnILGjCVTyiG9fuS /ZBQwqiMcMG1
+VLe/6+hmW5/vouZms6oLFTA+Rtp3irQ+DapQGV2Sd4btaZ3f13fMgHx/gRE O5IawrLPuuev
7RO3tHg8EANZ9unVvc37rDYu47Nd9FvZoduccrbc6XMnxOhjPvlCGBZ+nkAg 8yag4egJKr9e
ksdsLsoh5dNg4Xg9cooPT8w54O+plyfZp5RnzTENuWTdqHh+82qBxyfgzNxR KvILRX6C/dqm
yLzhzgsof9ftsgFkPoszcfpa9L63kQx+X7d5evn1zYQcQjFWwHpp4Nru6oGn nrvBCYRphLvk
UhA6VYCASiPTZtlEpbRwEm7XvWo43LDf+K+610dEPAByV4ilpt9cAUx/B0Ku wuGa5bDlsOWw
5bDlsOXwTeJw7f/icN1y2HLYcthy2HLYcvgmcbhuOWw5bDlsOWw5bDlsOWw5 /Gc47FsOWw5b
DlsOWw5bDt8kDvuWw5bDlsOWw5bDlsOWw5bD181hv1VtUNd1r53DK9YhL/bq hdgMSbPXXO1v
QFp3VgPUYQL5GTfWCBmbdGUyXPw/wGoE7eYUOYLBWMq809L0iFLO7uaR79Yt 8i3yLfIt8v89
5C9g4PXQarPQblhoW2hbaFto/2jXDk4ACIEggLUkq8LZf2NXhcgyqSKfQBva oWh/3dA+0IY2
tKENbWiHon2gDW1oQxva0IY2tG+gXQPa0IY2tKEN7Uy0a3RDW0SDNrShDW1o p6LdLaJVQRva
0IY2tKEdinZ1Q3tCG9rQhja0oR2K9oQ2tKENbWhDG9rQvoL2gja0oQ1taEM7 FO3VDe0NbWhD
G9rQhnYo2vsN2j9QSwMECgAAAAAAr1ktPgAAAAAAAAAAAAAAACkAAAB3b3Jr c3BhY2UueHBh
bmQucHJvYmxlbS8ubWV0YWRhdGEvLm15bHluL1BLAwQUAAAACAC5Vi0+a2A8 MsEAAAD6AAAA
NwAAAHdvcmtzcGFjZS54cGFuZC5wcm9ibGVtLy5tZXRhZGF0YS8ubXlseW4v LnRhc2tzLnht
bC56aXAL8GZmEWHgAMIdYbp2DEiAB4hLEouzczKLS/QqcnM2b1x/4myghreu 1rkz5zeHGl0x
DgjyOOt9zv/kGe/toVy8hZe3BgRp6Hme8fY8c/K899bQU6fDN23fzOmpc+7b SR29QI7mlyZM
r1o6rNWnLVn2XDxUq4Kh9CnD1pZnqs4tRquDgqeI/BEqNmT5+jbnS2LaLUaG AG92DuFcWeMC
oDumAHGANyOTCAPCrchyPAwoAM3lAd6sbCAxRiC0AtKrwCoAUEsDBAoAAAAA ABNULT4AAAAA
AAAAAAAAAAAyAAAAd29ya3NwYWNlLnhwYW5kLnByb2JsZW0vLm1ldGFkYXRh Ly5teWx5bi9j
b250ZXh0cy9QSwMEFAAAAAgARFQtPo4jyiJ0AQAApQEAAD0AAAB3b3Jrc3Bh Y2UueHBhbmQu
cHJvYmxlbS8ubWV0YWRhdGEvLm15bHluL3JlcG9zaXRvcmllcy54bWwuemlw CvBmZhFh4ABC
5xBdOwYkIADERakF+cWZJflFmanFehW5OW8n3/ViNhRojVc98zdNV2nNpS0K IQItXWHvL98t
lLaarXNySdnvL3n1b7JWR3y8ttvg5Jw5lvGX5PW0hbi/AABpAJb/wTiroCfP QKDNXWFsqeBp
cpNkMBz0JzrMH7B2wbDzBoMYR64jP+/74OBMI+bGFgqmsVwZIg0ielIwY67D VZq25SAxJ1MH
lM6XmwJ0Ps4/+7h9HCdZdnGZ9ECwqXDlLCoYRe9qTK/Rk7EgAGkAlv9amb1k 1VBjJbeOyASW
/oN1WXu3bGQMWOCLjsQK2Ec8vT/oBd7rEF6dL37bu55fR579SWQ7wFcKpKfY pjzqggWRa8ay
BaLgWP99T27iT79hSC7XtAO4W3cP5vi5/BP6mdDdNsaT2Kyv2MDz5K9/+IA3 wJudQ9lN4rcw
IwPDPmYGhgBvRiYRBkSQIssJMKACzAAO8GZlA4kzAiEoNgIZQTwAUEsDBBQA AAAIAK9ZLT7y
TC5kwQAAAPoAAAA2AAAAd29ya3NwYWNlLnhwYW5kLnByb2JsZW0vLm1ldGFk YXRhLy5teWx5
bi90YXNrcy54bWwuemlwC/BmZhFh4ADCdZG6dgxIgAeISxKLs3Myi0v0KnJz Nm9cf+JsoIa3
rta5M+c3hxpdMQ4I8jjrfc7/5Bnv7aFcvIWXtwYEaeh5nvH2PHPyvPfW0FOn wzdt38zpqXPu
20kdvUCO5pcmTK9aOqzVpy1Z9lw8VKuCofQpw9aWZ6rOLUarg4KniPwRKjZk +fo250ti2i1G
hgBvdg7hXFnjAqA7pgBxgDcjkwgDwq3IcjwMKADN5QHerGwgMUYgtALSq8Aq AFBLAwQKAAAA
AABlWi0+AAAAAAAAAAAAAAAAKwAAAHdvcmtzcGFjZS54cGFuZC5wcm9ibGVt Ly5tZXRhZGF0
YS8ucGx1Z2lucy9QSwMECgAAAAAAI1QtPgAAAAAAAAAAAAAAAEgAAAB3b3Jr c3BhY2UueHBh
bmQucHJvYmxlbS8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuYnVj a21pbnN0ZXIu
Y29yZS9QSwMECgAAAAAAQFQtPgAAAAAAAAAAAAAAAFgAAAB3b3Jrc3BhY2Uu eHBhbmQucHJv
YmxlbS8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuYnVja21pbnN0 ZXIuY29yZS9t
YXRlcmlhbGl6YXRpb24vUEsDBAoAAAAAACNULT7ycPEzBAAAAAQAAABfAAAA d29ya3NwYWNl
LnhwYW5kLnByb2JsZW0vLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNl LmJ1Y2ttaW5z
dGVyLmNvcmUvbWF0ZXJpYWxpemF0aW9uLy5zcWZpbGUDAAAAUEsDBBQAAAAI AAtaLT438zIx
xwAAAC0BAAB8AAAAd29ya3NwYWNlLnhwYW5kLnByb2JsZW0vLm1ldGFkYXRh Ly5wbHVnaW5z
L29yZy5lY2xpcHNlLmJ1Y2ttaW5zdGVyLmNvcmUvbWF0ZXJpYWxpemF0aW9u L2FhZmZmZTNl
LWI4ZDktM2E4OC05YTI5LTRkY2ZjMmZmZGYyZY2QsW7DMAxEf0XQHrHdCiNO lqBbt/QDaIlw
1UikIDGxm6+vanTImPnu4R1uf1xzMjeqLQqP9tW9WEPsJUSeR/t5ft+92eNh n8OQUalGTPGO
2rumc9yGHEb7pVoGgGVZHPkUSyMndYbp6i85cusYfJDiCRV3myCJR918pwEa qXZZg38WFqmX
VtCTWwtycKXKlChDIDcTU6O7oxVzSeS+8YbOY92CiioVrGHMNNqn2tZ4yUWY WM8/pVPS5uim
K4dE9vGVv9lw+AVQSwMECgAAAAAAI1QtPgAAAAAAAAAAAAAAAFkAAAB3b3Jr c3BhY2UueHBh
Y29yZS93b3Jrc3BhY2VCaW5kaW5nL1BLAwQKAAAAAAAjVC0+ebj4mQQAAAAE AAAAYAAAAHdv
cmtzcGFjZS54cGFuZC5wcm9ibGVtLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcu ZWNsaXBzZS5i
dWNrbWluc3Rlci5jb3JlL3dvcmtzcGFjZUJpbmRpbmcvLnNxZmlsZQEAAABQ SwMECgAAAAAA
1FstPgAAAAAAAAAAAAAAAEYAAAB3b3Jrc3BhY2UueHBhbmQucHJvYmxlbS8u bWV0YWRhdGEv
LnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvUEsDBAoAAAAA AOlaLT4AAAAA
AAAAAAAAAABPAAAAd29ya3NwYWNlLnhwYW5kLnByb2JsZW0vLm1ldGFkYXRh Ly5wbHVnaW5z
L29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5oaXN0b3J5L1BLAwQKAAAA AAABVi0+AAAA
AAAAAAAAAAAAUQAAAHdvcmtzcGFjZS54cGFuZC5wcm9ibGVtLy5tZXRhZGF0 YS8ucGx1Z2lu
cy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8uaGlzdG9yeS8xL1BLAwQK AAAAAAB4Vy0+
AAAAAAAAAAAAAAAAUgAAAHdvcmtzcGFjZS54cGFuZC5wcm9ibGVtLy5tZXRh ZGF0YS8ucGx1
Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8uaGlzdG9yeS8xMy9Q SwMEFAAAAAgA
xlYtPn+qav+XAAAAywAAAHIAAAB3b3Jrc3BhY2UueHBhbmQucHJvYmxlbS8u bWV0YWRhdGEv
LnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLmhpc3Rvcnkv MTMvMzAwYTVk
ZGFmYjFlMDAxMDFjNTdlMWFjYTA5YzYzMTE1jsEJwzAMRc8tZAeRe7eIA4E6 CaYLmFhJU2oJ
bLVLZYTePFlt04Iu/z/poXQYpdOnOZ9mDCsHH0HuCBsSBis7E/AKD/u2jhdY 2HskiXk7zw6O
SeBFDkMUSw52ac7pUGP3c5Y06HkyN9gWDvjvOtUPowLDLNBPBrRmh0+41D/S 0Q9XBa1glLY2
uSLr83WGxV54ATVUV41fUEsDBAoAAAAAANRbLT4AAAAAAAAAAAAAAABSAAAA d29ya3NwYWNl
LnhwYW5kLnByb2JsZW0vLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNl LmNvcmUucmVz
b3VyY2VzLy5oaXN0b3J5LzE5L1BLAwQKAAAAAADUWy0+AAAAAAAAAAAAAAAA UgAAAHdvcmtz
cGFjZS54cGFuZC5wcm9ibGVtLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNs aXBzZS5jb3Jl
LnJlc291cmNlcy8uaGlzdG9yeS8xYy9QSwMECgAAAAAAT1UtPgAAAAAAAAAA AAAAAHEAAAB3
b3Jrc3BhY2UueHBhbmQucHJvYmxlbS8ubWV0YWRhdGEvLnBsdWdpbnMvb3Jn LmVjbGlwc2Uu
Y29yZS5yZXNvdXJjZXMvLmhpc3RvcnkvMS8xMDBlMTYzNWZhMWUwMDEwMWM1 N2UxYWNhMDlj
NjMxMVBLAwQUAAAACAABVS0+qA50HZ0AAAAPAQAAcQAAAHdvcmtzcGFjZS54 cGFuZC5wcm9i
bGVtLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291 cmNlcy8uaGlz
dG9yeS8xLzgwMTg3YTQzZjkxZTAwMTAxYzU3ZTFhY2EwOWM2MzExdY47DsIw EET7nMIHIA5Q
GtHQQwESvYknwZE/YW0j4PQEIkOadLN6O5+9dLpBiOUZFLR3gq34stglpwzK DH9snclBWgim
wFs4BLw4HtL2ZrxJRk/58/S0F290Pevo5F3yWtLfugnatQZxaNxGSshRk4mf kUfckiaUIxXM
U8u75HRcFF+N2ug+gMM2g/Y0yXHKk2DXGHtRVXmQQlW8AVBLAwQKAAAAAACW Vi0+AAAAAAAA
AAAAAAAAUgAAAHdvcmtzcGFjZS54cGFuZC5wcm9ibGVtLy5tZXRhZGF0YS8u cGx1Z2lucy9v
cmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8uaGlzdG9yeS8yNi9QSwMEFAAA AAgAJ1YtPuep
s2L2AAAA3AEAAHIAAAB3b3Jrc3BhY2UueHBhbmQucHJvYmxlbS8ubWV0YWRh dGEvLnBsdWdp
bnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLmhpc3RvcnkvMjYvYzA0 ODM3ZGRmYTFl
MDAxMDFjNTdlMWFjYTA5YzYzMTGFUctOwzAQPBeJf4h8rwOcUJXQC4UjUugP WM44WKztyI8k
n0+aFxQO3CzP7M5ji+NgKOvgg3a2ZPf8jmWw0tXaNiVLUe0f2fHp9qbonf9U 5PrxvSukM62z
sDGTJEIomfMNhyTdBnAYxU0PnqKmwCuIGp5dxnaFcTXonVzMOkEJJZs+WJbP cPL6CsgxCNMS
+GD0QiryTft/J0MrbP3AX2HhRXSrC6UJpyXjrLck3Yy0/hlKJIqnQVKqEVaa EhTwg/Yb56Gz
G4xJf4XOGKOIiDNCPBwqN5bw8lZl1w24FAlTsst6ET/W6eDlvsH37nxm/q2k yLdLfQFQSwME
CgAAAAAARVgtPgAAAAAAAAAAAAAAAFIAAAB3b3Jrc3BhY2UueHBhbmQucHJv YmxlbS8ubWV0
YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLmhp c3RvcnkvMjgv
UEsDBAoAAAAAAENYLT5BYNIOIQAAACEAAAByAAAAd29ya3NwYWNlLnhwYW5k LnByb2JsZW0v
Lm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2Vz Ly5oaXN0b3J5
LzI4L2EwOTE2YTJmZmMxZTAwMTAxYzU3ZTFhY2EwOWM2MzExDQoJCWRlLmdl bmVzZXouZXhh
bXBsZS5qYXZhLmNhcgoJUEsDBAoAAAAAACxYLT4AAAAAAAAAAAAAAABSAAAA d29ya3NwYWNl
b3VyY2VzLy5oaXN0b3J5LzJiL1BLAwQKAAAAAAAqWC0+QWDSDiEAAAAhAAAA cgAAAHdvcmtz
LnJlc291cmNlcy8uaGlzdG9yeS8yYi8yMDVjZDIxM2ZjMWUwMDEwMWM1N2Ux YWNhMDljNjMx
MQ0KCQlkZS5nZW5lc2V6LmV4YW1wbGUuamF2YS5jYXIKCVBLAwQKAAAAAAAd Vy0+AAAAAAAA
cmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8uaGlzdG9yeS8yYy9QSwMEFAAA AAgAxlYtPn+q
av+XAAAAywAAAHIAAAB3b3Jrc3BhY2UueHBhbmQucHJvYmxlbS8ubWV0YWRh dGEvLnBsdWdp
bnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLmhpc3RvcnkvMmMvYjAz YWY5NzRmYjFl
MDAxMDFjNTdlMWFjYTA5YzYzMTE1jsEJwzAMRc8tZAeRe7eIA4E6CaYLmFhJ U2oJbLVLZYTe
PFlt04Iu/z/poXQYpdOnOZ9mDCsHH0HuCBsSBis7E/AKD/u2jhdY2HskiXk7 zw6OSeBFDkMU
Sw52ac7pUGP3c5Y06HkyN9gWDvjvOtUPowLDLNBPBrRmh0+41D/S0Q9XBa1g lLY2uSLr83WG
xV54ATVUV41fUEsDBAoAAAAAAOlaLT4AAAAAAAAAAAAAAABSAAAAd29ya3Nw YWNlLnhwYW5k
LnByb2JsZW0vLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmNvcmUu cmVzb3VyY2Vz
Ly5oaXN0b3J5LzJkL1BLAwQUAAAACACreig+liBUBDQOAACMUQAAcgAAAHdv cmtzcGFjZS54
cGFuZC5wcm9ibGVtLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5j b3JlLnJlc291
cmNlcy8uaGlzdG9yeS8yZC8zMDUzMGUyM2ZmMWUwMDEwMWM1N2UxYWNhMDlj NjMxMcxaaY/z
NBD+jsR/sIrEIUHr+1huEEJIIBAvAr5Z3sRtA2lSEne7y69n7PTYbtkmb7oc K21349jjmWce
j8fjfvTp/apEd75pi7r6eEKmeIJ8ldV5US0+nnz+6stvvpl8+smbb3y0yOrG 33z3XZ37Et2v
ipvDGBrHgJSqvYH2jyfLENY3s9l2u53Wq8W0bhazX7/75tClPe2yZakHxZhA t29fZUu/ch8U
VRtclfn9qDT7YdzCV771f05zP1v54FZRpxn0gO6VW0G/3E/3ffy9W61LP/3N 3blp5poosfh6
U+QfT7z3lmAuuFQEY0aYJUxwJi2ZgMUIfVRvK59/Wa9WvgrHYZYQK6xkHFMi 4EEpwwX8YsMs
Y8okAchVVR1cSAh9vgnLurlZeLB0+vZb959/+GXjXfD5DcNTzKdYIaJusOne /VSE0t/s+nWT
754ms04vsAwG/+Cy393C70y+da2f9CipuRJKWym00tgSqjs7L1jKLba3co6p J9CfUE6MoYxi
ZoUQShorNT61Naur4MB9yJUlCkuPQLEigy458m0L4gsX24FeLQo1yn2bNcWt Rw59Cc6Z7RXK
Ste2xbzwDQLG3ISHNdi44+CX8d3e1TCqz2xDmCLaakU1puBjM0F3RVvcFmUR Hj6erDe3ZZFN
ULtZ+yZNdC7GwCiiKWXcSi6FUZZIPkGRZI0riz+T8YPHJSMv4k6t+OrzH26B 3NRqpzBVDsRp
QqkkVMEHmEEJ1pZz8YRrCEiOCsAfVvWyyEqPtkVYonm9adB26X3ZJmfkTXHn W1RXyUlN7fIp
oH9UDLBIEofBbCg1WGMhqTVScKpi49/DvNqUoVjDv6kVVsqmKv7YwBSh2QCD Gx82TfVTcsNd
XeQdWOPh4owxLqxRWlJmuTinawsTZ6FuUD1PWCTqoaxj43HutWsAieCbHSKr +7YPEVBBcmwZ
0yI1AvHyovFZN3VR1ZvQi0ciJPSFngefDHZA0v8q9IzERtoYOgiBP/QUvZW7 L1abVUSuXXuf
nyI2O0B2EUf3ux8CpJBWYcU5NFI8GshXoYHQ899gqSkBWRLDJwYsn2wSBcrr 6p2Afq/qLSxU
F1BEBhr7QIW2gzXPL+C03icXYrvAWhtFKdFWURVDlZJ03BJ2Revzr+4zv44K PDMXA69iYxkz
UhkruEAJvUfdMCcYU6kwAwcpoQ22QvLTEPFFXZfeVf1R4lwJQ4QRmAvDrFKK gcGg1qlP3i7D
h8uwKj9J2y9C6dm7fP+MUBtcE9pHr2fd+2PDbZ0/PO2f4oyvFkXlD1HHNSku r+oYlouAQg3P
Nbxq0Lp0mX88x1FmejyqeDlk5UXKqgbQQFApLFFcSwM04KOX2zdV8AvfnKy3 Ycw7teTo8oF+
FYQIaaliAiwQ2LyuX4d7NJr7PioeebGJSy2HfCLLfNvON2X58D5KntzCwkBz V7ZjvNlhsHPl
QBcazKWUgKc4cWEnaogPj0tslA8vx6h1U6eU6zzF+zwEyAo34ZDRw07zKu4w PbmexJIILq1W
oI2ylDPI64JvfN2JP89ohVQKSyM1sIRxgoH1+knUA3e64F+P8demLZQoyQBL wZWWlnN1SuB9
2txFkv02nPbgGFAcEPFEhd2h4fW00AJjE3N9gg3HxDKCn2xZFUBbuRLdlm7/ +2S3emz64xfB
LRY+/9mVG4/u4POIooNz52z2maseXh0cN8Wzz/ZkgdPmrEdSXGGDRJEThu6b RxG0qr+f/5LS
60sU1TEN5ZwaaalQUvHIwWfolvsURxIw/zL7iMFCgeIaUyGAffJp0rypQmJe tVnd+pQ5d0eL
8Xi2bZ0VSf6PdXlAtYUtzF8EVBIssSJUWMWZZFYMXLwJsOcOjCAJBAoObcYS SWLsW9dtEfx3
T8W4o+I96mHKpbL86sgQFaRWEYIJA988SVkaPweqV5lHoU4uShDmnX9e2j2A g6+e1B3oCQKa
AnyCSKO51ZrqeBzS5HV89IxMrqnCzGolGVaWCTrMR5c1hBYVFcRHYZcHcJic UhgBe931OP5Q
unAG5tH/aWbBYXJGLDGSSW05HQHmmUwmgaXaUiywBjANgAlRtfGLpGkXYobh e1lpYwTFDJQ+
AfjSCKkFjjjT6wBOuXYvtIIwbWBOwsC9VmD8AtByQxjVMZRqBu5S0DurV9H0 EdBeUBr4aKSx
3JijtB4zDTWYgJnkKmi7wN9bg9OaU5iTMp7ISwdBy//pMH2uoRaxyAAaPpJ2 eQRjgmkGI9i1
oZ1hw4SOmQHV4EpuLoT2qm5WrtxX9Oqqy/kuBHhoOBZVX7vMmlKbg5OHOmRc oZUy4GnKfaMn
KDbxyH+osg4e9HwtJFu6anEprUgSseDJGooVlpaMKIX0lSrOT+iV3yake3Uz BscnTpUSlo08
nw/H/4DgMKx6Dq59awHHoyRR2DBLTTz/MEKuPr+ONGJ4ha2py8t+o0wbiTlT lgpKKZj/QvW1
MYWzVFufjTrq5EXH2d5wIDTG2DIad3MLnLrmXD0vaxdGKtyufQZBLkve6jme CSa4FsYayqnm
sXGQ1h9crDePBXrTuG7eg9LPOFtqGYupwC5DVEw2XqKEgXI/dzBgd6omOP5c lSusHk5uYAdu
qyNOdL1XgM+lCvzKVGFo+nMVjG3W+O1FHmOmuBGYRRhBAxzTw2E8fh5HEMoJ Y3FrMDGFhEY5
IuM601DG6psGYTqCcn2q8nN37XnAZ+i17N/HYnfbhsZlYb9EUvLyTDGRc6V0 PKHHAqRJF2da
o7/vBspwaWms8hkLRDrJcV5Y9jUXzpgyQbWWFoRxqc+LgD8ti/aA0u7ydOcC VKT6ZIdZ92Ze
N8iVx28ALB2McVV3HY3eja9339i4gfbmfXRbu/A+ckW6Bamg0j6dTt+bJovG VzaxEEpRCt4n
mnNiOeenRiUmXqhhjr1gAyAlxzFAc8asEoNI97+/cBt7z6QNi5UxY4xWEtCQ L37P1O+AvlS1
X30uuKFRlro6Rx2v//As1a9dUYUe2wzWLNW3BNESW6WuP/5AId7fd/cFsaGd koscyuqybvq1
3FfhkpLjz0Hnyp25oh+i8VQyBEthmBWKSa5AlhxLpZc35fqbu999762dEpRo S41QRljKhxXx
XzrlHk47xWMZkxH9VzNXuhM3DIRfZd9g4zl8SP3TA6RKlah6/LZ6LC0qLQgW VX37jh22JrhZ
GzulCxJSgmOPncx45ptv7Jws14xr1fy+WqOcbQE9VgYAUaMDj5Yca89KtYs+ M4JijYhesSHj
kfQkjIiv5+Ky2dELdv7qVNgQf+h/Ecr58DHz92pQjdyidYNGYIhDzGudYesB h8eCjV6OjNmy
gE6zXBl2wRkAhP+OHWVLVrKj5dm5gTUqD4jdW3KP/P3G88XR8dP3r97510dv Xp68KNDklIaY
E1NMAFhALJsgAK0DnUKm82nX/PRM7NZ40azUR5JFvl2kezHcWxnrJuUWqi1O Pu+aECjvGRyB
Zs+IxODRTFkY0eIGAlfi2t599TJ8IAffzuj44urnh6vPxbnEyNg7UkhaRlTz PUZDWprA4EJG
j6QjJOkO57t7JnTyGglB0TA4bx0SBgl5maj9VZZKrkv7zrzsBl2TdKfELeN3 WBKDjQWrAlQM
hj2x6ndYuhChCaxWmbF+NFitPwlfyytY5lM8EQORlrNO2Jl9Ptqapw+eedsH HP4WxWZFwb4w
WsueyPV/uIvpf06BqKQrLGgEvm1+lUbXYMCiBySnwTO5A9T9ApniAHS/kyCS 82AWUv6jjClS
xerop5mmr3ZJimQ/QbJJjS6vi1qEpAi9DYAjee7bQT/+kqbrHqM5LysY1swW tUcCwoC7w+Fr
fMbxOTiNb+YtJXrWMhp/LFvOOwkSI36eOX81CHmJ5pJjPENWO/i3NusmSOR1 wHczRKQmT1Qw
SA1QMpGxygzy4x0OjmUYcAcHJUcprWHFntApZTyj+pdYcnmNurDk6OLJfCyz N6a19GP5qeRw
SD8A+EIsWYb/VSVPS197Ob+XTz5aSOPBWALtGfgxCT6rurRfcz6vPHsmAuUd cTQoYBbP55UX
vKQ4ZfHtoMGCZ7Dd4GG7/Lm29Ie1N9uT0+ObzXm+0dVmjP/tRjdzssFlqJgs sF1IDVaDXLGz
ZDyU4L58voqlQwbLzgeCgJExlJ052uD64rscWPD5c6RwT44ziP+JAq8uhLFw tpEKwBEglAJ6
afBlE8oAc/ZCWcDwawMApq0HTaiDgsFUwLHftp4doeFYVTKEnvF+vdmVvMdr yYF8+rrdnAvq
+W3s9n6V/HoyaIlEUf/xvs0pT2V20mJB2WFXrk03q8QQO/mxL0rAAa0lpQ15 Z1gN5Mlwp2uW
nakC6IGcRut1ArXmvDQpKisI7BQxOPQOrGP2ZPVCJypUr8+46oX9Je/NESMa h6iVx4BbaRG+
jdNcWua+WeW7zsND6nOpttl+LSqrXFvyqIm082i6ycGdJzQoIBDBLHsyhDG9 P+wruh1nORr3
qG5pFfPqi3aSdXEZDUXqBOPA4NEtxbFuIHps5ManorxWK6M8IQ9oPXXAPsnL GiWec5DWE6di
dzcBFJn61rN+Nz+q651WlVzndb2AZT6tCFhND24eOS9xTeOWinVnBu1Jw8jQ temiVW2i7I5w
0SupFKZqSesBcZlZLRa+qksD9AiY43dJwDJ0t3pQZWKuw9E0nX0/20pQHqOI IPXOhCXRk0mb
eSIZkd0z6c78U2P5THpk3368t5spfCZX861TVJye2N2ZfyoBzumh8Ub99MbL fe0jAJ/ax8td
+4kPe9v8QzwZJQflyt659Dndl8YOJa6SMbJ9Yab19Z7WT9YTgcd7k3h1lcqJ oluQwul1Revn
AYyMLZ+s756pKDd+A1BLAwQKAAAAAADUWy0+AAAAAAAAAAAAAAAAUgAAAHdv cmtzcGFjZS54
cmNlcy8uaGlzdG9yeS8zMC9QSwMECgAAAAAA0FQtPgAAAAAAAAAAAAAAAFIA AAB3b3Jrc3Bh
Y2UueHBhbmQucHJvYmxlbS8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlw c2UuY29yZS5y
ZXNvdXJjZXMvLmhpc3RvcnkvMzMvUEsDBBQAAAAIAMxULT4j6xCYpwAAACAB AAByAAAAd29y
a3NwYWNlLnhwYW5kLnByb2JsZW0vLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5l Y2xpcHNlLmNv
cmUucmVzb3VyY2VzLy5oaXN0b3J5LzMzL2UwNGM5ZGUxZjgxZTAwMTAxYzU3 ZTFhY2EwOWM2
MzExdY67DoJAFER7voJQy4IUFkto7LXQxH6BAZfsA/dB1K83ulmxsbs3Z+Zk DkzxAdblFxjL
taLplpTJ3qteII/wy6pIjkyCpj3ICAWLJ8GdyVmE3zCnTUyeH7LVgnd/GxNb GOmYWau15WoU
cFrRxhmPqPqZ+B55ws1zgzxQmmozkskr7jbJ50Yn+GxBIIe6DYYlGJqsIjtS ZqtY9drQ9Orc
TIsiLuxRJC9QSwMECgAAAAAAN1ctPgAAAAAAAAAAAAAAAFIAAAB3b3Jrc3Bh Y2UueHBhbmQu
cHJvYmxlbS8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5y ZXNvdXJjZXMv
Lmhpc3RvcnkvMzUvUEsDBBQAAAAIANBULT4xJI1DmgAAAAkBAAByAAAAd29y a3NwYWNlLnhw
YW5kLnByb2JsZW0vLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmNv cmUucmVzb3Vy
Y2VzLy5oaXN0b3J5LzM1LzAwYjRiNzE3ZjkxZTAwMTAxYzU3ZTFhY2EwOWM2 MzExdY4xDsIw
EAT7vMIPIA5QGtHQQwESvYmX4Mg+h7ONgNcjiExo6O40u6vZarJnxFQfwdEG UmIh59Umk3Go
C/yyZSE77aGEgexAiHhK3LUf3PizToFL8vDwp+Bs+7fR65uWreapuoqWOocU SK0TZ5SpH8W3
5B7XbBn1SJUI3Mk+k02z6nOjdXaIkPDnaYFMYCUuKQ2qaYqKQVO9AFBLAwQK AAAAAAA0Vy0+
QWDSDiEAAAAhAAAAcgAAAHdvcmtzcGFjZS54cGFuZC5wcm9ibGVtLy5tZXRh ZGF0YS8ucGx1
Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8uaGlzdG9yeS8zNS9m MDMzN2I5MWZi
MWUwMDEwMWM1N2UxYWNhMDljNjMxMQ0KCQlkZS5nZW5lc2V6LmV4YW1wbGUu amF2YS5jYXIK
CVBLAwQKAAAAAABiVy0+AAAAAAAAAAAAAAAAUgAAAHdvcmtzcGFjZS54cGFu ZC5wcm9ibGVt
Ly5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNl cy8uaGlzdG9y
eS8zYS9QSwMEFAAAAAgASlctPmELC+w4AQAAfwIAAHIAAAB3b3Jrc3BhY2Uu eHBhbmQucHJv
YmxlbS8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNv dXJjZXMvLmhp
c3RvcnkvM2EvODA3MzkxYmZmYjFlMDAxMDFjNTdlMWFjYTA5YzYzMTGFUstO wzAQPBeJf4h8
rwOcUJXQC6GnClT6A5YzCVH9kr1pU74ekiamrZB6sWzP7Hhnx9my0yrZw4fG mpw98geWwEhb
NqbOWUvV/JktX+7vsoP1u0rZw+9+lkmrnTUwlEglQsiZ9TWHVI0L4NAV1wfw lhoV+AaihGd9
2SzTtoT6VJaSvVAtcjZcsCQ9wa1vLoAUndBOgXe6GUlZGt++3UnnhCmf+AoG XpCNXYDEutf/
t4ZgSk5Hh3AMBD3YKXS1nooGkXOVDyF3osbUeQlewyDgm/eUwQivpfXgq34d 6dF0GoVO56pR
KMYEJs0hh1jh/Csq0SoqOqnaEmGiVUIFnNGucR72JsIYpjNBW2inBGGLQIX3 1i8WG2speXvf
JJch2ZYUaByCE/Q1SQQv5zXMn7HIvEotS+Nn+gFQSwMECgAAAAAAJFgtPgAA AAAAAAAAAAAA
AFIAAAB3b3Jrc3BhY2UueHBhbmQucHJvYmxlbS8ubWV0YWRhdGEvLnBsdWdp bnMvb3JnLmVj
bGlwc2UuY29yZS5yZXNvdXJjZXMvLmhpc3RvcnkvNDkvUEsDBBQAAAAIAHRX LT5xQeETmgAA
AM4AAAByAAAAd29ya3NwYWNlLnhwYW5kLnByb2JsZW0vLm1ldGFkYXRhLy5w bHVnaW5zL29y
Zy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5oaXN0b3J5LzQ5L2QwNTA5NjBh ZmMxZTAwMTAx
YzU3ZTFhY2EwOWM2MzExNY5RCsIwEES/LfQOS/+9RVMomLYELxDSbY2aLCSL HqpH8C8nMwkK
+zMzO49JhxIyfdrmtGDYKLgIfEPY0WPQbMkDbXDXL72SAUPOoeeYv/O9KTwi eGJYkTE4621k
a9omHWLqf9iiRrnM6gq7oYB/rxfDOAlQlOvDrEBKWvEJ5zolHcN4EdAxRu6q ky2vXW7nsNBL
XoIqKqvKL1BLAwQKAAAAAAA4VC0+AAAAAAAAAAAAAAAAUgAAAHdvcmtzcGFj ZS54cGFuZC5w
cm9ibGVtLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJl c291cmNlcy8u
aGlzdG9yeS80Yi9QSwMEFAAAAAgAOFQtPtm7Vg0tAQAAcwQAAHIAAAB3b3Jr c3BhY2UueHBh
bmQucHJvYmxlbS8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuY29y ZS5yZXNvdXJj
ZXMvLmhpc3RvcnkvNGIvMTBlYTUxMzhmODFlMDAxMDFjNTdlMWFjYTA5YzYz MTG9lD9PwzAQ
xWeQ+A5VdhzYGNxUAsQGqlSQWK/2kbiK/8h22ohPT+zcUARpGVAm+z3f8+9k W+arXreLPfqg
rFkWt+ymWKARVipTL4u316fru2JVXV1y5+0ORXzEILxycage3AtuQGMlkdVo MOAnwx60a5Ht
YA9MgM8LHqL1vEy1OSSs1mhixUuaZZcIIYvym9p2qpUbhyIpkg9DFIzMDvVh fc1QtMqFoQEZ
mbB+7CQHkFqgBPi6S+xAujw2kj6m/J3rJLJnMOoDQ7yfF7sRDWqYEdpHNJKF BjxK1qlRz8vv
YwJTC1n/C58cenIJHTuPuZrEidc2rvNyHKcy+crWbVcr83I6YB0a8KJREUUy DzCAthCQWThM
Z89f1fsajJze4PxZ/8zmOR0VL3/9NL4AUEsDBAoAAAAAAOJZLT4AAAAAAAAA AAAAAABSAAAA
d29ya3NwYWNlLnhwYW5kLnByb2JsZW0vLm1ldGFkYXRhLy5wbHVnaW5zL29y Zy5lY2xpcHNl
LmNvcmUucmVzb3VyY2VzLy5oaXN0b3J5LzRkL1BLAwQUAAAACADcWS0+WARD NbYBAABjBgAA
cgAAAHdvcmtzcGFjZS54cGFuZC5wcm9ibGVtLy5tZXRhZGF0YS8ucGx1Z2lu cy9vcmcuZWNs
aXBzZS5jb3JlLnJlc291cmNlcy8uaGlzdG9yeS80ZC8zMDUyYjRmY2ZkMWUw MDEwMWM1N2Ux
YWNhMDljNjMxMc1S32vbMBB+TqH/w+EnB4qgey2D/Upho4QRErZX1b7E2mTJ O52bwtj/vlNk
pyV2U0oLLRZYOun77ru77/TE1I0nhl/6Rivj1aWxeDEaXaAukYZ3o3GHrFaL K4nexVtnWK1J
17j19Ft9DAGJ77/wtFFYWNMEVMYxktNW3Tbale+UDqyWWDdWc9L3KKLRJAnU z3j6HveXutDl
ATiJ+oRrT6M3SwxJYtNeW1NAYXUI8E1K7MXEF/D39GQiK7UCSBATqR743psZ kSd4Dxvkz5Ek
n6p+e+UjLAUWGHxLBebZ8hAshXE2fZD7hzTVuM0LpZD1IbVFdl3xN96UEJBX TT4FrshvA8xu
C2zYeLfrwb8OGQkPcCyhQb6HeCaxUw63cGe8fH/Oh7Ur9qvFV2GT7yLik7mU 3v3mnuettXlG
aT6h8q0twXmGawQnV9kZUAL2EoFFwaF31Dqmp7OhgNjXnbbpsfw9bFwBj0Bn f1ptQ57FxOB0
vYfWmosqO6pELvvDXNcSOMLPFVLPHSWdQ4lr40yciGQ577i+7IPRXBbdhith ffLge7M+a/5D
ule3Qafj7bihE/RqppD1H1BLAwQKAAAAAAAtVy0+AAAAAAAAAAAAAAAAUgAA AHdvcmtzcGFj
ZS54cGFuZC5wcm9ibGVtLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBz ZS5jb3JlLnJl
c291cmNlcy8uaGlzdG9yeS81ZC9QSwMEFAAAAAgAllYtPjEBfKEzAQAAegIA AHIAAAB3b3Jr
c3BhY2UueHBhbmQucHJvYmxlbS8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVj bGlwc2UuY29y
ZS5yZXNvdXJjZXMvLmhpc3RvcnkvNWQvMDA2MTNmODZmYjFlMDAxMDFjNTdl MWFjYTA5YzYz
MTGFUktOwzAUXIPEHSLv6wArVCV0Q+mqApVewHImIap/sp/blNND0sS0FRKb KPZ8/MbjYtFp
le3hQ2tNyR74PctgpK1a05QsUj17Yovnu9viYP2uVvbw839TSKudNTCUSSVC KJn1DYdUrQvg
0DXXB/BIrQp8A1HBs152U2hbQX0oS9leqIiSDRssy09w9O0FkKMT2inwTrcj qcjT2f9P0jlh
qke+goEXZNMUILHu/f/UEEzF6egQjoGghzhLXa8n0WBy7vIu5E40mCavwBsY BHzxnjIE4Y20
HnzVf0d6Cp0no9O6bhWWYwMnz7GHpHD+BbWIipadVLFCmGi1UAFntGuch71J MIbbmaAttFOC
sEWg+XxjLWWvb5vssh8bSYHG/E7Q56QOXs4amN9MiXlVWJGnd/QNUEsDBBQA AAAIAAN2KD40
7n0tWAIAAIMGAAByAAAAd29ya3NwYWNlLnhwYW5kLnByb2JsZW0vLm1ldGFk YXRhLy5wbHVn
aW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5oaXN0b3J5LzVkLzgw MGJmZjc4ZmIx
ZTAwMTAxYzU3ZTFhY2EwOWM2MzExtVWxbtswEJ1boP/Aai1EtZkCwW7QFkmm IEXidOhSENTJ
ZkORBHmK7Xx9jpIoC45gIEMWwRTee/fu3dFaXOwazZ7AB2XNMvvGv2YMjLSV Mutl1mKdn2cX
3z99XGytf6y13dLvD4vPec48iIrhBhjsnPUIFWsbfcYaW4FmtdLAhCGAFybU 1jdMIVMGLRPs
GgzcX/4doHneSUrbOGvAEKqiwiS1JliA54xJLUJYZhXw4RUXlXAInkcYf6DH IJlFqd5epTxI
tH7PthslN0xag0KZMG85+SByf3oSuoVl1h1yghewE43TEEtmrOihztvY6Gtw 8tkDpqRFMTaa
kox0VQmEaO0oHLGOnpERqbGGfWH/xZNgwYFUtZKxqYCeIBjmc0zScyE6LTBO JvBenacR8z89
y/ohzyC9cpjarKAsB42yHEXKslcpy18HU9T0WxRic6Qz8unV/d6g2J0IL4BX ZPd5Lj1WzIYy
Un4CFYabs9Xb4rlP/JTP6yUgkXFjdo064d+3JjrvByuJzKIBL1BZc3SDIqyT 7y7SsAq29RJ6
4nGzqSnr1xykVi6QGUeaZzzm5CcTbgDFTZSe5SCYiuPeQdgHhIZDU/PLpr5J pE5kqvJbyEex
TplMU42Qrge+lpQ9v47PAT5uSzEKHfK9HP6UkubD6io/Hxm2RQ2nGiaAa5Hf drjk1wncJD3O
i4nNNLuYMZfCF8HLONSDxb5if4CuSFJaAVEFwgoCluWdtciubu/YIN219U77 /KNG8O+8zv9E
LDJZanKjLbnUFunmI5kKiYy+hdlWF8Xkc/ICUEsDBAoAAAAAANRbLT4AAAAA AAAAAAAAAABS
AAAAd29ya3NwYWNlLnhwYW5kLnByb2JsZW0vLm1ldGFkYXRhLy5wbHVnaW5z L29yZy5lY2xp
cHNlLmNvcmUucmVzb3VyY2VzLy5oaXN0b3J5LzYxL1BLAwQKAAAAAADUWy0+ AAAAAAAAAAAA
AAAAUgAAAHdvcmtzcGFjZS54cGFuZC5wcm9ibGVtLy5tZXRhZGF0YS8ucGx1 Z2lucy9vcmcu
ZWNsaXBzZS5jb3JlLnJlc291cmNlcy8uaGlzdG9yeS82NS9QSwMECgAAAAAA OVotPgAAAAAA
AAAAAAAAAFIAAAB3b3Jrc3BhY2UueHBhbmQucHJvYmxlbS8ubWV0YWRhdGEv LnBsdWdpbnMv
b3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLmhpc3RvcnkvNjcvUEsDBBQA AAAIADBaLT7y
rtKCEwIAAJ8LAAByAAAAd29ya3NwYWNlLnhwYW5kLnByb2JsZW0vLm1ldGFk YXRhLy5wbHVn
aW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5oaXN0b3J5LzY3LzUw MzU1MzVmZmUx
ZTAwMTAxYzU3ZTFhY2EwOWM2MzEx1VPdatswFL5uoe9w8JUTikp3GwbdTwqD EkZw2G5V+yTW
JkuedNwUxt59R3aclDgJARfqEhNLR/p+rPPp6lIVpXUEv+STFMqKe6VxcrA6 R5mh664drBsk
sZg/cHVXr4wisXSywLV1v8Un79HRyx3WrQSmWpUehTKEzkgtnktpsg9CehIJ FqWWhJOzEKV0
LCB+htn3ML6Xqcz2wI2pz7i07uBKgr6xWFaPWqWQauk9BDplVq2fsAn+Xl1e 8NOcBrgJj/kA
gF7smTpnHXyEFdKXwBOPRDt8sAHWFObobeVSjKNkH8zfRtHoKPcPPlf21Uei 5Tiu1FPkXP7E
2p4SzLBT4eeuaTOPNs18sioDj7Qo4xFQ7uzaw/Q5xZKUNXVD/zXIm/GY/2EM Sa781ixkFj0Y
SxDyDOscDbjKGJZmNqyrS23XDfRuX6Au3wRfwfOeK+JSpzXHXF6EUBlcw+6a xtt53I2JILuY
f2M2/k0CvrmKQtavmaVZpXUcuSbKPreVzurvfEQwvBRdg2uArUUgdrB/08Qy yLvrroHQutrb
6JR+CzvsgA5Ap38qqX0cBWEwsthCC0lpHp10wovtZCYLLpzgpxxdyx0s3UKG S2VU6Air3G64
vm6LIb8azYpyZm1jdX7jN4Hu1f8u3ZvHYONjOGnYGBp8KF4vDwOIwpBS8M4C kFjbIwNdsgHE
gF0MKQls583CwM9/UEsDBAoAAAAAAEpXLT4AAAAAAAAAAAAAAABSAAAAd29y a3NwYWNlLnhw
Y2VzLy5oaXN0b3J5LzZmL1BLAwQUAAAACACWVi0+MQF8oTMBAAB6AgAAcgAA AHdvcmtzcGFj
c291cmNlcy8uaGlzdG9yeS82Zi9lMDA5YmZhNWZiMWUwMDEwMWM1N2UxYWNh MDljNjMxMYVS
S07DMBRcg8QdIu/rACtUJXRD6aoClV7AciYhqn+yn9uU00PSxLQVEpso9nz8 xuNi0WmV7eFD
a03JHvg9y2CkrVrTlCxSPXtii+e72+Jg/a5W9vDzf1NIq501MJRJJUIomfUN h1StC+DQNdcH
8EitCnwDUcGzXnZTaFtBfShL2V6oiJINGyzLT3D07QWQoxPaKfBOtyOpyNPZ /0/SOWGqR76C
gRdk0xQgse79/9QQTMXp6BCOgaCHOEtdryfRYHLu8i7kTjSYJq/AGxgEfPGe MgThjbQefNV/
R3oKnSej07puFZZjAyfPsYekcP4FtYiKlp1UsUKYaLVQAWe0a5yHvUkwhtuZ oC20U4KwRaD5
fGMtZa9vm+yyHxtJgcb8TtDnpA5ezhqY30yJeVVYkad39A1QSwMECgAAAAAA 1FstPgAAAAAA
AAAAAAAAAFEAAAB3b3Jrc3BhY2UueHBhbmQucHJvYmxlbS8ubWV0YWRhdGEv LnBsdWdpbnMv
b3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLmhpc3RvcnkvNy9QSwMECgAA AAAA1FstPgAA
AAAAAAAAAAAAAFIAAAB3b3Jrc3BhY2UueHBhbmQucHJvYmxlbS8ubWV0YWRh dGEvLnBsdWdp
bnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLmhpc3RvcnkvNzIvUEsD BAoAAAAAANRb
LT4AAAAAAAAAAAAAAABSAAAAd29ya3NwYWNlLnhwYW5kLnByb2JsZW0vLm1l dGFkYXRhLy5w
bHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5oaXN0b3J5Lzcz L1BLAwQKAAAA
AADUWy0+AAAAAAAAAAAAAAAAUgAAAHdvcmtzcGFjZS54cGFuZC5wcm9ibGVt Ly5tZXRhZGF0
YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8uaGlzdG9y eS83NC9QSwME
CgAAAAAA1FstPgAAAAAAAAAAAAAAAFIAAAB3b3Jrc3BhY2UueHBhbmQucHJv YmxlbS8ubWV0
YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLmhp c3RvcnkvNzUv
UEsDBAoAAAAAADBaLT4AAAAAAAAAAAAAAABSAAAAd29ya3NwYWNlLnhwYW5k LnByb2JsZW0v
Lzc2L1BLAwQUAAAACAATWi0+0KcMj+UBAABBCwAAcgAAAHdvcmtzcGFjZS54 cGFuZC5wcm9i
dG9yeS83Ni9mMGI1OTc1NGZlMWUwMDEwMWM1N2UxYWNhMDljNjMxMdVTbWvb MBD+3EL/g/An
B4qg+xoGe0thUMIICdtX1b7E2mSddzo3hbH/vlNsJyVxQkcKdYkg0knPi3WP ri5tWSGx+mke
jLaob62DcW91BiYHOtzrrXtgvZjdSXVXr71lvSRTwhrpl/4YAhA/PYG00pA5 WwXQ1jOQN04/
Vsbn77QJrOdQVs4wjJ+FqAyJgP4RV9/i/NZkJt8DN6Y+wRKpd2cOobFY1ffO ZipzJgQV6axf
dX7iIfXn6vJCRnMbisYylwtQ/OTMhAhJvVcr4M+RJx3pbnqHEdYUZhCwpgzS ZL4Plm/jZHSU
+7vcq/g6R6LjOK50pshz+eeIZ0oIw05FxoemzTJrm/mANlcBeFGlI8UF4Tqo yWMGFVv0m4b+
bZGRdQ/HUjq4vGM8F7HtHtZq95DS7To9bKRmXMy+Cpv8xhHfPBZtNn9T5Gnt XJpQE7ZQYO1y
5ZHVPSgvW8m1ogbYWVQsDvbfgl5GebruMbAC3ngbndLvYP0OuAc6+V0bF9Ik Citvyi20NJwV
yUknstktpqaUwgl+LoA67mjpRuWwtN7GjojKTcv1ZVuMCXPgV1wI6/83vo3c Gf3vo3v1GLQ+
hpOG1tDgQ/FyeRhAFIaUgjcWgDniy2VAyAYQA3ExpCSInVcLg4x/UEsDBAoA AAAAADdVLT4A
AAAAAAAAAAAAAABSAAAAd29ya3NwYWNlLnhwYW5kLnByb2JsZW0vLm1ldGFk YXRhLy5wbHVn
aW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5oaXN0b3J5LzgwL1BL AwQUAAAACAAo
VS0++LJ0qLEAAABaAQAAcgAAAHdvcmtzcGFjZS54cGFuZC5wcm9ibGVtLy5t ZXRhZGF0YS8u
cGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8uaGlzdG9yeS84 MC9jMDM0Y2E1
NWY5MWUwMDEwMWM1N2UxYWNhMDljNjMxMXWPvQ7CMAyE9z5FH4CmwBjEwg4D SOyhPUpQ/nBc
RHl6CigFVbDZ99nn81o5fUTkYg+K2juZz8Q0W7WuNigSHNg8kY2ykHkN0cAh 4i5wUzaYd0+K
PaXJXWcP3ujq78ZZXZWoFH1WF1G7xoD7i0umFsnqK+Iz5BaXVhOKN5W5p0ac W6d5kr1qVEaH
CAF77GtPGOm3oFw91hi/NcFdQOwiwz4Nh0g98iTzE3OQZZl+q1FmD1BLAwQK AAAAAABBVi0+
Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8uaGlzdG9yeS84My9Q SwMEFAAAAAgA
N1UtPqm4AfnEAAAAlAEAAHIAAAB3b3Jrc3BhY2UueHBhbmQucHJvYmxlbS8u bWV0YWRhdGEv
LnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLmhpc3Rvcnkv ODMvODBmOTBk
N2RmYTFlMDAxMDFjNTdlMWFjYTA5YzYzMTF1kE1SwzAMhfc5RQ5AHOjSDBv2 sIAZ9iJ+Td2x
ZSPL0HB6KB1TphN20vv086QHYr9F0eEFUnxi29+Y6+6+sgsYGvxlm0YeKcL2 DmYGo+DT4EAx
h1MupEla5fMSX1Pw078de3onM5GcW2+L5zlAE9s7lYo26o/Fo8knvFUvGE7U 9klms6/s9ar7
iTEFnwsM4vY7ToIL/ZCJ3aWmWNeMLhllKYp4HLiyIn7AVPWhrLONCVR52p2P YZfE9jvVbMex
fcVh7L4AUEsDBAoAAAAAAFBWLT4AAAAAAAAAAAAAAABSAAAAd29ya3NwYWNl LnhwYW5kLnBy
b2JsZW0vLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucmVz b3VyY2VzLy5o
aXN0b3J5Lzg0L1BLAwQUAAAACABBVi0+FOaezNMAAACxAQAAcgAAAHdvcmtz cGFjZS54cGFu
ZC5wcm9ibGVtLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3Jl LnJlc291cmNl
cy8uaGlzdG9yeS84NC8yMDUxMTM4ZmZhMWUwMDEwMWM1N2UxYWNhMDljNjMx MXWQTVLDMAyF
9zlFDkAU6DIMG/awgBn2wnl13LFlY8vQcHpaSijTCTvpffp50gOL26Jo94Jc XJShvaHr5r7K
6NEt8JdtFvLIAUM7giwEBZ+EPYfkT3lmjXmpfJ7Da/TO/Nux43cmw/nceluc WA89bLzTXLGM
+mPxaPIJb9VldCc6tDFb2lVxetV8xzDepQJC2B7imHGh7xPLeKkp1jXSOaHM RRGOA1dWhA9Q
VefLOtuQ5ypm+qGc2EwgE0OIUshHa53Y86Uyxjy0k2oa+n552Yi++QJQSwME CgAAAAAA1Fst
PgAAAAAAAAAAAAAAAFIAAAB3b3Jrc3BhY2UueHBhbmQucHJvYmxlbS8ubWV0 YWRhdGEvLnBs
dWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLmhpc3RvcnkvOTYv UEsDBAoAAAAA
AFtWLT4AAAAAAAAAAAAAAABSAAAAd29ya3NwYWNlLnhwYW5kLnByb2JsZW0v Lm1ldGFkYXRh
Ly5wbHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5oaXN0b3J5 LzliL1BLAwQU
AAAACABQVi0+7efK9NgAAADNAQAAcgAAAHdvcmtzcGFjZS54cGFuZC5wcm9i bGVtLy5tZXRh
ZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8uaGlz dG9yeS85Yi9j
MGI0Yjc5YmZhMWUwMDEwMWM1N2UxYWNhMDljNjMxMXWQu1LDQAxFe3+FPwDL kNIMDT0UMEMv
1jf2ZvbFrhZsvh6HZJNMxumke/S40gs7vUWS5gMxae+6+oHuq+fseoOmwBPb FPLKFl3dgwY4
JPwSJrbBHPLI4mOpfJ/tpzda3ezY8TeT4nhufUzaDQaybHySmFFGXVjcm3zD V9YRzYF2tY8D
7bLTclf9x1BGhwSC3S6xj7jSp8Cuv9YE6xrJHJDmJLD7gSsr7A8oizZpnW3I cHZqPFIOrEaQ
8tZ6l8j4YViOvuWcJqvPX3C9j109ioSubcs7e7TVH1BLAwQKAAAAAADUWy0+ AAAAAAAAAAAA
ZWNsaXBzZS5jb3JlLnJlc291cmNlcy8uaGlzdG9yeS9hMC9QSwMECgAAAAAA 1FstPgAAAAAA
b3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLmhpc3RvcnkvYTEvUEsDBAoA AAAAAKBZLT4A
aW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5oaXN0b3J5L2EyL1BL AwQUAAAACACJ
WS0+8LabK0gCAABPCAAAcgAAAHdvcmtzcGFjZS54cGFuZC5wcm9ibGVtLy5t ZXRhZGF0YS8u
cGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8uaGlzdG9yeS9h Mi81MGVmZDdi
MmZkMWUwMDEwMWM1N2UxYWNhMDljNjMxMcVUUWvbMBB+bqH/QfjJgSLTwF4W BtvaFDZKGOkC
e1Xti6PNlrzTOck69t93suJEZEnXMsiISKQ73fd9p0/KxbmuG4skvqqlktrK W13B6GB0CqoA
/DN3MG6A5Gx6x9FdvDWa5BxVDSuL3+Q75wAp3mGxlJBXunEgtSFAoyq5bpQp hlI5kp+hbipF
MHpWRaOQCeQXv/rk57cqV8VecRD1HuYWD2WY0gWJTftQ6VzklXJOfOQWezF+ h/h5cX7GIxyF
wBHPuXuB1pJ4I0qga1+XDmQ/vbN+ZwhMwdkWc0iTGHOMaJF7oWTg4e4JtSlF busajAdNbl5n
Dog46rISDDh4lKWmrADZLz0Yd1Y76U3J/Ncrzvfbs20+i/K0EeGy60DWiYg0 UKRyX8jGjMw7
7BqV77QUsIylwVoxCnTCZK6wS6Aii1neOrK1flSkrcmiM9kp4fE2mMazjTVL qwvBQmZNOhC0
QLtyYrzOofEwnUO/NpUeaq+OODRlt46VniF3amAldi8h3a7TzmhJdjb9wAD8 GfmScMGl6n4m
liZtVaUJhjviFratCmEsiQcQhlPJpcBQ2LcsiEn376+ce0a8DJwlUKdg8BRl b9hhUjpQOv7e
qsqliecSRtXb0lpRvkj2yRmkX0xUzYEnIGkB2MN5FVeigLk22h81A19tsG62 Qf9sKjAlLRj1
ryZG1+VFZlJUdxL7YsITmxdTH7Hu/ofjXdK2JBvUhiqTHrXl/5kd/qBe5HMe Sk5iceA6sbs9
67+8yWHsk2PM4XOc4vEbUEsDBAoAAAAAALVWLT4AAAAAAAAAAAAAAABSAAAA d29ya3NwYWNl
b3VyY2VzLy5oaXN0b3J5L2E2L1BLAwQUAAAACACgeig+vrmMGYEAAACgAAAA cgAAAHdvcmtz
LnJlc291cmNlcy8uaGlzdG9yeS9hNi81MGUzNmIwMGZiMWUwMDEwMWM1N2Ux YWNhMDljNjMx
MTWMwQ2DMBRDz0ViBy/QLQgShwCKukBEPjRVky8lv12KEXrLZA2ilXyx/eyy G6XLp20uM6WV
U8iQO2GjSMmK5whe8bBv63jBwiFQlFzpKg/HUfCKjlIWGx28tE3Z1dj9Pg83 6HkyN2wLJ/pn
neqHUcEwC/rJQGt29MS19uf+BA77BVBLAwQKAAAAAAAcWC0+AAAAAAAAAAAA AAAAUgAAAHdv
cmtzcGFjZS54cGFuZC5wcm9ibGVtLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcu ZWNsaXBzZS5j
b3JlLnJlc291cmNlcy8uaGlzdG9yeS9hZC9QSwMEFAAAAAgALVctPvro5pc6 AQAAgQIAAHIA
AAB3b3Jrc3BhY2UueHBhbmQucHJvYmxlbS8ubWV0YWRhdGEvLnBsdWdpbnMv b3JnLmVjbGlw
c2UuY29yZS5yZXNvdXJjZXMvLmhpc3RvcnkvYWQvNzAyZmUzMDJmYzFlMDAx MDFjNTdlMWFj
YTA5YzYzMTGFUstuwjAQPFOp/xD5jtP2VKGkXEo5oVYUqWfLmaQRfsneQOjX l4TEBVSJi2V7
Zsc7O87mrVbJDj7U1uTskT+wBEbaojZVzhoqp89s/nJ/l+2t35bK7o/7SSat dtbAUCKVCCFn
1lccUtUugEOXXO/BG6pV4GuIAp51ZZNM2wLqU1lKdkI1yFl/wZL0BDe+vgBS tEI7Bd7qeiBl
aXz7dietE6Z44ksYeEE2dgESq07/3xqCKTgdHMIhEHRvZ6HL1VjUi5yrfAi5 FRXGzgvwCgYB
P7yj9EZ4Ja0HX3brQI+m0yh0Ope1wmJIYNTsc4gVzr+iFI2iRStVUyCMtFKo gDPaNc7DzkQY
/XRGaAPtlCBsEOjrGPXx8dlsbS0lb+/r5DIm25ACDWNwgr5HkeDltIL5sxaZ V7llafxOv1BL
AwQKAAAAAACkVC0+AAAAAAAAAAAAAAAAUgAAAHdvcmtzcGFjZS54cGFuZC5w cm9ibGVtLy5t
ZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8u aGlzdG9yeS9h
ZS9QSwMEFAAAAAgAq3ooPpYgVAQ0DgAAjFEAAHIAAAB3b3Jrc3BhY2UueHBh bmQucHJvYmxl
bS8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJj ZXMvLmhpc3Rv
cnkvYWUvMzA2OTU5YWZmODFlMDAxMDFjNTdlMWFjYTA5YzYzMTHMWmmP8zQQ /o7Ef7CKxCFB
6/tYbhBCSCAQLwK+Wd7EbQNpUhJ3u8uvZ+z02G7ZJm+6HCttd+PY45lnHo/H 43706f2qRHe+
aYu6+nhCpniCfJXVeVEtPp58/urLb76ZfPrJm298tMjqxt98912d+xLdr4qb wxgax4CUqr2B
9o8nyxDWN7PZdrud1qvFtG4Ws1+/++bQpT3tsmWpB8WYQLdvX2VLv3IfFFUb XJX5/ag0+2Hc
wle+9X9Ocz9b+eBWUacZ9IDulVtBv9xP9338vVutSz/9zd25aeaaKLH4elPk H0+895ZgLrhU
BGNGmCVMcCYtmYDFCH1Ubyuff1mvVr4Kx2GWECusZBxTIuBBKcMF/GLDLGPK JAHIVVUdXEgI
fb4Jy7q5WXiwdPr2W/eff/hl413w+Q3DU8ynWCGibrDp3v1UhNLf7Pp1k++e JrNOL7AMBv/g
st/dwu9MvnWtn/QoqbkSSlsptNLYEqo7Oy9Yyi22t3KOqSfQn1BOjKGMYmaF EEoaKzU+tTWr
q+DAfciVJQpLj0CxIoMuOfJtC+ILF9uBXi0KNcp9mzXFrUcOfQnOme0VykrX tsW88A0CxtyE
hzXYuOPgl/Hd3tUwqs9sQ5gi2mpFNabgYzNBd0Vb3BZlER4+nqw3t2WRTVC7 WfsmTXQuxsAo
oill3EouhVGWSD5BkWSNK4s/k/GDxyUjL+JOrfjq8x9ugdzUaqcwVQ7EaUKp JFTBB5hBCdaW
c/GEawhIjgrAH1b1sshKj7ZFWKJ5vWnQdul92SZn5E1x51tUV8lJTe3yKaB/ VAywSBKHwWwo
NVhjIak1UnCqYuPfw7zalKFYw7+pFVbKpir+2MAUodkAgxsfNk31U3LDXV3k HVjj4eKMMS6s
UVpSZrk4p2sLE2ehblA9T1gk6qGsY+Nx7rVrAIngmx0iq/u2DxFQQXJsGdMi NQLx8qLxWTd1
UdWb0ItHIiT0hZ4Hnwx2QNL/KvSMxEbaGDoIgT/0FL2Vuy9Wm1VErl17n58i NjtAdhFH97sf
AqSQVmHFOTRSPBrIV6GB0PPfYKkpAVkSwycGLJ9sEgXK6+qdgH6v6i0sVBdQ RAYa+0CFtoM1
zy/gtN4nF2K7wFobRSnRVlEVQ5WSdNwSdkXr86/uM7+OCjwzFwOvYmMZM1IZ K7hACb1H3TAn
GFOpMAMHKaENtkLy0xDxRV2X3lX9UeJcCUOEEZgLw6xSioHBoNapT94uw4fL sCo/SdsvQunZ
u3z/jFAbXBPaR69n3ftjw22dPzztn+KMrxZF5Q9RxzUpLq/qGJaLgEINzzW8 atC6dJl/PMdR
Zno8qng5ZOVFyqoG0EBQKSxRXEsDNOCjl9s3VfAL35yst2HMO7Xk6PKBfhWE CGmpYgIsENi8
rl+HezSa+z4qHnmxiUsth3wiy3zbzjdl+fA+Sp7cwsJAc1e2Y7zZYbBz5UAX GsyllICnOHFh
J2qID49LbJQPL8eodVOnlOs8xfs8BMgKN+GQ0cNO8yruMD25nsSSCC6tVqCN spQzyOuCb3zd
iT/PaIVUCksjNbCEcYKB9fpJ1AN3uuBfj/HXpi2UKMkAS8GVlpZzdUrgfdrc RZL9Npz24BhQ
HBDxRIXdoeH1tNACYxNzfYINx8Qygp9sWRVAW7kS3ZZu//tkt3ps+uMXwS0W Pv/ZlRuP7uDz
iKKDc+ds9pmrHl4dHDfFs8/2ZIHT5qxHUlxhg0SRE4bum0cRtKq/n/+S0utL FNUxDeWcGmmp
UFLxyMFn6Jb7FEcSMP8y+4jBQoHiGlMhgH3yadK8qUJiXrVZ3fqUOXdHi/F4 tm2dFUn+j3V5
QLWFLcxfBFQSLLEiVFjFmWRWDFy8CbDnDowgCQQKDm3GEkli7FvXbRH8d0/F uKPiPephyqWy
/OrIEBWkVhGCCQPfPElZGj8HqleZR6FOLkoQ5p1/Xto9gIOvntQd6AkCmgJ8 gkijudWa6ngc
0uR1fPSMTK6pwsxqJRlWlgk6zEeXNYQWFRXER2GXB3CYnFIYAXvd9Tj+ULpw BubR/2lmwWFy
RiwxkkltOR0B5plMJoGl2lIssAYwDYAJUbXxi6RpF2KG4XtZaWMExQyUPgH4 0gipBY440+sA
Trl2L7SCMG1gTsLAvVZg/ALQckMY1TGUagbuUtA7q1fR9BHQXlAa+GiksdyY o7QeMw01mICZ
5Cpou8DfW4PTmlOYkzKeyEsHQcv/6TB9rqEWscgAGj6SdnkEY4JpBiPYtaGd YcOEjpkB1eBK
bi6E9qpuVq7cV/Tqqsv5LgR4aDgWVV+7zJpSm4OThzpkXKGVMuBpyn2jJyg2 8ch/qLIOHvR8
LSRbumpxKa1IErHgyRqKFZaWjCiF9JUqzk/old8mpHt1MwbHJ06VEpaNPJ8P x/+A4DCseg6u
fWsBx6MkUdgwS008/zBCrj6/jjRieIWtqcvLfqNMG4k5U5YKSimY/0L1tTGF s1Rbn4066uRF
x9necCA0xtgyGndzC5y65lw9L2sXRircrn0GQS5L3uo5ngkmuBbGGsqp5rFx kNYfXKw3jwV6
07hu3oPSzzhbahmLqcAuQ1RMNl6ihIFyP3cwYHeqJjj+XJUrrB5ObmAHbqsj TnS9V4DPpQr8
ylRhaPpzFYxt1vjtRR5jprgRmEUYQQMc08NhPH4eRxDKCWNxazAxhYRGOSLj OtNQxuqbBmE6
gnJ9qvJzd+15wGfotezfx2J324bGZWG/RFLy8kwxkXOldDyhxwKkSRdnWqO/ 7wbKcGlprPIZ
C0Q6yXFeWPY1F86YMkG1lhaEcanPi4A/LYv2gNLu8nTnAlSk+mSHWfdmXjfI lcdvACwdjHFV
dx2N3o2vd9/YuIH25n10W7vwPnJFugWpoNI+nU7fmyaLxlc2sRBKUQreJ5pz Yjnnp0YlJl6o
YY69YAMgJccxQHPGrBKDSPe/v3Abe8+kDYuVMWOMVhLQkC9+z9TvgL5UtV99 LrihUZa6Okcd
r//wLNWvXVGFHtsM1izVtwTRElulrj/+QCHe33f3BbGhnZKLHMrqsm76tdxX 4ZKS489B58qd
uaIfovFUMgRLYZgVikmuQJYcS6WXN+X6m7vffe+tnRKUaEuNUEZYyocV8V86 5R5OO8VjGZMR
/VczV7oTNwyEX2XfYOM5fEj90wOkSpWoevy2eiwtKi0IFlV9+44dtia4WRs7 pQsSUoJjj53M
eOabb+ycLNeMa9X8vlqjnG0BPVYGAFGjA4+WHGvPSrWLPjOCYo2IXrEh45H0 JIyIr+fistnR
C3b+6lTYEH/ofxHK+fAx8/dqUI3conWDRmCIQ8xrnWHrAYfHgo1ejozZsoBO s1wZdsEZAIT/
jh1lS1ayo+XZuYE1Kg+I3Vtyj/z9xvPF0fHT96/e+ddHb16evCjQ5JSGmBNT TABYQCybIACt
A51CpvNp1/z0TOzWeNGs1EeSRb5dpHsx3FsZ6yblFqotTj7vmhAo7xkcgWbP iMTg0UxZGNHi
BgJX4treffUyfCAH387o+OLq54erz8W5xMjYO1JIWkZU8z1GQ1qawOBCRo+k IyTpDue7eyZ0
8hoJQdEwOG8dEgYJeZmo/VWWSq5L+8687AZdk3SnxC3jd1gSg40FqwJUDIY9 sep3WLoQoQms
VpmxfjRYrT8JX8srWOZTPBEDkZazTtiZfT7amqcPnnnbBxz+FsVmRcG+MFrL nsj1f7iL6X9O
gaikKyxoBL5tfpVG12DAogckp8EzuQPU/QKZ4gB0v5MgkvNgFlL+o4wpUsXq 6KeZpq92SYpk
P0GySY0ur4tahKQIvQ2AI3nu20E//pKm6x6jOS8rGNbMFrVHAsKAu8Pha3zG 8Tk4jW/mLSV6
1jIafyxbzjsJEiN+njl/NQh5ieaSYzxDVjv4tzbrJkjkdcB3M0SkJk9UMEgN UDKRscoM8uMd
Do5lGHAHByVHKa1hxZ7QKWU8o/qXWHJ5jbqw5OjiyXwsszemtfRj+ankcEg/ APhCLFmG/1Ul
T0tfezm/l08+WkjjwVgC7Rn4MQk+q7q0X3M+rzx7JgLlHXE0KGAWz+eVF7yk OGXx7aDBgmew
3eBhu/y5tvSHtTfbk9Pjm815vtHVZoz/7UY3c7LBZaiYLLBdSA1Wg1yxs2Q8 lOC+fL6KpUMG
y84HgoCRMZSdOdrg+uK7HFjw+XOkcE+OM4j/iQKvLoSxcLaRCsARIJQCemnw ZRPKAHP2QlnA
8GsDAKatB02og4LBVMCx37aeHaHhWFUyhJ7xfr3ZlbzHa8mBfPq63ZwL6vlt 7PZ+lfx6MmiJ
RFH/8b7NKU9ldtJiQdlhV65NN6vEEDv5sS9KwAGtJaUNeWdYDeTJcKdrlp2p AuiBnEbrdQK1
5rw0KSorCOwUMTj0Dqxj9mT1QicqVK/PuOqF/SXvzREjGoeolceAW2kRvo3T XFrmvlnlu87D
Q+pzqbbZfi0qq1xb8qiJtPNousnBnSc0KCAQwSx7MoQxvT/sK7odZzka96hu aRXz6ot2knVx
GQ1F6gTjwODRLcWxbiB6bOTGp6K8ViujPCEPaD11wD7JyxolnnOQ1hOnYnc3 ARSZ+tazfjc/
quudVpVc53W9gGU+rQhYTQ9uHjkvcU3jlop1ZwbtScPI0LXpolVtouyOcNEr qRSmaknrAXGZ
WS0WvqpLA/QImON3ScAydLd6UGVirsPRNJ19P9tKUB6jiCD1zoQl0ZNJm3ki GZHdM+nO/FNj
+Ux6ZN9+vLebKXwmV/OtU1ScntjdmX8qAc7pofFG/fTGy33tIwCf2sfLXfuJ D3vb/EM8GSUH
5creufQ53ZfGDiWukjGyfWGm9fWe1k/WE4HHe5N4dZXKiaJbkMLpdUXr5wGM jC2frO+eqSg3
fgNQSwMECgAAAAAA3FktPgAAAAAAAAAAAAAAAFIAAAB3b3Jrc3BhY2UueHBh bmQucHJvYmxl
cnkvYjAvUEsDBBQAAAAIAGxXLT4yfUclmwAAAM4AAAByAAAAd29ya3NwYWNl LnhwYW5kLnBy
aXN0b3J5L2IwLzUwYTI0NWQ1ZmIxZTAwMTAxYzU3ZTFhY2EwOWM2MzExLY5d CoMwDMefJ3iH
4PtuYQVhVSm7QKnRdVsbaMN2KI+wt55sbRHykP8HvyQdo1xmdYfdUMD0a5u2 SYcSsqyXBcNG
wUXgB8KOHoNmSx5og6f+6JUMGHIOPcfczvOl8IrgiWFFxuCst5GtKUwx9Se2 qF4M4yRAUa4O
swIpacU3XOvZdAzjTUDHGLmrTra8dvm/HBZSyUtQRWVV+QdQSwMEFAAAAAgA oFktPt6nBIVX
AgAAgAgAAHIAAAB3b3Jrc3BhY2UueHBhbmQucHJvYmxlbS8ubWV0YWRhdGEv LnBsdWdpbnMv
b3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLmhpc3RvcnkvYjAvNzBmODAw ZjdmZDFlMDAx
MDFjNTdlMWFjYTA5YzYzMTHFVF1r2zAUfW6h/0H4yYEi08JeFgbr+gEbJYx0 gb2q9o2jzZa8
q+sk69h/35UVJ8LN+sEgIyKR7tU591wdKSfHum4skvimlkpqK290BeO90Smo AvBxbm/cAMnZ
9Jaju3hrNMk5qhpWFr/LC+cAKd5hsZSQV7pxILUhQKMquW6UKc6lciS/QN1U imD8IkSjkAvI
r3712c9vVK6KATiI+gBzi/syXNIFiU17X+lc5JVyTnziFnsxfof4dXJ8xCMc hcAxz7l7gdaS
eCdKoEuPS0eyn95avzMEpuBsizmkScx5jWiRe6Fk5OnuCLUpRW7rGownTa7e Zg6IOOqyEgw4
eJClpqwA2S89GXdWO+lNyfzXG87327NtPovytBHhsstQrBMRaaBI5VDIxozM O+wale+0FLCM
pcFaMQt0wmSusEugIotZ3jqytX5QpK3JojPZKeHxPpjGs401S6sLwUJmTToS tEC7cuJ6nUPj
aTqHfm+QnmqAIw5N2a2/QY+QOzWwEruXkG7XaWe0JDubfmQC/ow9JFxwqbqf iaVJW1VpguGO
uIVtq0IYS+IehOFUciowAPuWhT/e4f2Vc18RT0PNEqhTMArIu5+O3ZG2Jdmw V1SZtNtzBXNt
tO/GXbhb7bjPpzT2Du9XSXug1z9aVbk08eKEUfUWWivKF8lQLZP0i4mqOfAE JS0Aezqv4kwU
226Y+Iy5Bi3ys6rAlLRg1mddj+7Xq9ynCHcQv+OCBzYvLj2w7vmb99iW/2d2 +Ed7lc95gBzE
4lDrwO72Vf/lTZ7HPjnmPH+JUzz+AFBLAwQKAAAAAAATWi0+AAAAAAAAAAAA AAAAUgAAAHdv
b3JlLnJlc291cmNlcy8uaGlzdG9yeS9iNi9QSwMEFAAAAAgABFotPgLP3zTm AQAAPgsAAHIA
c2UuY29yZS5yZXNvdXJjZXMvLmhpc3RvcnkvYjYvMDAwOWFhMzRmZTFlMDAx MDFjNTdlMWFj
YTA5YzYzMTHVU21r2zAQ/txC/4PwJweKoPsaBntLYaOEERK2r6p9ibXJOu90 bgpj/32n2E5K
4oSOFOoRQ6STnhfpHl1d2rJCYvXDPBhtUd9aB+Pe6gxMDnS41lv3wHoxu5Pq rl57y3pJpoQ1
0k/9PgQgfroDaaUhc7YKoK1nIG+cfqyMz99oE1jPoaycYRg/C1EZEgH9Pc6+ xvGtyUy+B25M
fYAlUu/KHEJjsarvnc1U5kwI6oscsTMTd6jfV5cX8jVXoWgsYzm94id7JkRI 6q1aAX+MJOlI
d8M7jLCmMIOANWWQJvN9sByMk9FR7m9yqdavzpHoOI4rnSnyXP454pkSwrBT ke9d02MZtZ18
QJurALyo0pHignAd1OQxg4ot+k1D/7TIyLqHYykdXN4xnovYdg9rtXtF6Xae HjZSMy5mn4VN
fuOIb16KNpu/KfK0di5NqAlbKLB2ufLI6h6Ul6XkWlED7CwqFgf7D0Evozxd 9xhYAW+8jU7p
d7B+B9wDnfyqjQtpEoWVN+UWWhrOiuSkE1nsJlNTSuEEPxdAHXe0dKNyWFpv Y0dE5abl+rQt
xoQ58CsuhPXfG99G7qz+H9K9egxaH8NJQ2to8KF4uTwMIApDSsF/FoA54stl QMgGEANxMaQk
iJ1XC4N8fwFQSwMECgAAAAAApFQtPgAAAAAAAAAAAAAAAFIAAAB3b3Jrc3Bh Y2UueHBhbmQu
Lmhpc3RvcnkvYjcvUEsDBBQAAAAIAGJ2KD6WIFQENA4AAIxRAAByAAAAd29y a3NwYWNlLnhw
Y2VzLy5oaXN0b3J5L2I3LzIwZDg0MGFmZjgxZTAwMTAxYzU3ZTFhY2EwOWM2 MzExzFppj/M0
EP6OxH+wisQhQev7WG4QQkggEC8CvlnexG0DaVISd7vLr2fs9Nhu2SZvuhwr bXfj2OOZZx6P
x+N+9On9qkR3vmmLuvp4QqZ4gnyV1XlRLT6efP7qy2++mXz6yZtvfLTI6sbf fPddnfsS3a+K
m8MYGseAlKq9gfaPJ8sQ1jez2Xa7ndarxbRuFrNfv/vm0KU97bJlqQfFmEC3 b19lS79yHxRV
G1yV+f2oNPth3MJXvvV/TnM/W/ngVlGnGfSA7pVbQb/cT/d9/L1brUs//c3d uWnmmiix+HpT
5B9PvPeWYC64VARjRpglTHAmLZmAxQh9VG8rn39Zr1a+CsdhlhArrGQcUyLg QSnDBfxiwyxj
yiQByFVVHVxICH2+Ccu6uVl4sHT69lv3n3/4ZeNd8PkNw1PMp1ghom6w6d79 VITS3+z6dZPv
niazTi+wDAb/4LLf3cLvTL51rZ/0KKm5EkpbKbTS2BKqOzsvWMottrdyjqkn 0J9QToyhjGJm
hRBKGis1PrU1q6vgwH3IlSUKS49AsSKDLjnybQviCxfbgV4tCjXKfZs1xa1H Dn0JzpntFcpK
17bFvPANAsbchIc12Ljj4Jfx3d7VMKrPbEOYItpqRTWm4GMzQXdFW9wWZREe Pp6sN7dlkU1Q
u1n7Jk10LsbAKKIpZdxKLoVRlkg+QZFkjSuLP5Pxg8clIy/iTq346vMfboHc 1GqnMFUOxGlC
qSRUwQeYQQnWlnPxhGsISI4KwB9W9bLISo+2RViieb1p0HbpfdkmZ+RNcedb VFfJSU3t8img
f1QMsEgSh8FsKDVYYyGpNVJwqmLj38O82pShWMO/qRVWyqYq/tjAFKHZAIMb HzZN9VNyw11d
5B1Y4+HijDEurFFaUma5OKdrCxNnoW5QPU9YJOqhrGPjce61awCJ4JsdIqv7 tg8RUEFybBnT
IjUC8fKi8Vk3dVHVm9CLRyIk9IWeB58MdkDS/yr0jMRG2hg6CIE/9BS9lbsv VptVRK5de5+f
IjY7QHYRR/e7HwKkkFZhxTk0UjwayFehgdDz32CpKQFZEsMnBiyfbBIFyuvq nYB+r+otLFQX
UEQGGvtAhbaDNc8v4LTeJxdiu8BaG0Up0VZRFUOVknTcEnZF6/Ov7jO/jgo8 MxcDr2JjGTNS
GSu4QAm9R90wJxhTqTADBymhDbZC8tMQ8UVdl95V/VHiXAlDhBGYC8OsUoqB waDWqU/eLsOH
y7AqP0nbL0Lp2bt8/4xQG1wT2kevZ937Y8NtnT887Z/ijK8WReUPUcc1KS6v 6hiWi4BCDc81
vGrQunSZfzzHUWZ6PKp4OWTlRcqqBtBAUCksUVxLAzTgo5fbN1XwC9+crLdh zDu15OjygX4V
hAhpqWICLBDYvK5fh3s0mvs+Kh55sYlLLYd8Ist82843ZfnwPkqe3MLCQHNX tmO82WGwc+VA
FxrMpZSApzhxYSdqiA+PS2yUDy/HqHVTp5TrPMX7PATICjfhkNHDTvMq7jA9 uZ7EkggurVag
jbKUM8jrgm983Yk/z2iFVApLIzWwhHGCgfX6SdQDd7rgX4/x16YtlCjJAEvB lZaWc3VK4H3a
3EWS/Tac9uAYUBwQ8USF3aHh9bTQAmMTc32CDcfEMoKfbFkVQFu5Et2Wbv/7 ZLd6bPrjF8Et
Fj7/2ZUbj+7g84iig3PnbPaZqx5eHRw3xbPP9mSB0+asR1JcYYNEkROG7ptH EbSqv5//ktLr
SxTVMQ3lnBppqVBS8cjBZ+iW+xRHEjD/MvuIwUKB4hpTIYB98mnSvKlCYl61 Wd36lDl3R4vx
eLZtnRVJ/o91eUC1hS3MXwRUEiyxIlRYxZlkVgxcvAmw5w6MIAkECg5txhJJ Yuxb120R/HdP
xbij4j3qYcqlsvzqyBAVpFYRggkD3zxJWRo/B6pXmUehTi5KEOadf17aPYCD r57UHegJApoC
fIJIo7nVmup4HNLkdXz0jEyuqcLMaiUZVpYJOsxHlzWEFhUVxEdhlwdwmJxS GAF73fU4/lC6
cAbm0f9pZsFhckYsMZJJbTkdAeaZTCaBpdpSLLAGMA2ACVG18YukaRdihuF7 WWljBMUMlD4B
+NIIqQWOONPrAE65di+0gjBtYE7CwL1WYPwC0HJDGNUxlGoG7lLQO6tX0fQR 0F5QGvhopLHc
mKO0HjMNNZiAmeQqaLvA31uD05pTmJMynshLB0HL/+kwfa6hFrHIABo+knZ5 BGOCaQYj2LWh
nWHDhI6ZAdXgSm4uhPaqblau3Ff06qrL+S4EeGg4FlVfu8yaUpuDk4c6ZFyh lTLgacp9oyco
NvHIf6iyDh70fC0kW7pqcSmtSBKx4MkaihWWlowohfSVKs5P6JXfJqR7dTMG xydOlRKWjTyf
D8f/gOAwrHoOrn1rAcejJFHYMEtNPP8wQq4+v440YniFranLy36jTBuJOVOW CkopmP9C9bUx
hbNUW5+NOurkRcfZ3nAgNMbYMhp3cwucuuZcPS9rF0Yq3K59BkEuS97qOZ4J JrgWxhrKqeax
cZDWH1ysN48FetO4bt6D0s84W2oZi6nALkNUTDZeooSBcj93MGB3qiY4/lyV K6weTm5gB26r
I050vVeAz6UK/MpUYWj6cxWMbdb47UUeY6a4EZhFGEEDHNPDYTx+HkcQyglj cWswMYWERjki
4zrTUMbqmwZhOoJyfaryc3ftecBn6LXs38did9uGxmVhv0RS8vJMMZFzpXQ8 occCpEkXZ1qj
v+8GynBpaazyGQtEOslxXlj2NRfOmDJBtZYWhHGpz4uAPy2L9oDS7vJ05wJU pPpkh1n3Zl43
yJXHbwAsHYxxVXcdjd6Nr3ff2LiB9uZ9dFu78D5yRboFqaDSPp1O35smi8ZX NrEQSlEK3iea
c2I556dGJSZeqGGOvWADICXHMUBzxqwSg0j3v79wG3vPpA2LlTFjjFYS0JAv fs/U74C+VLVf
fS64oVGWujpHHa//8CzVr11RhR7bDNYs1bcE0RJbpa4//kAh3t939wWxoZ2S ixzK6rJu+rXc
V+GSkuPPQefKnbmiH6LxVDIES2GYFYpJrkCWHEullzfl+pu7333vrZ0SlGhL jVBGWMqHFfFf
OuUeTjvFYxmTEf1XM1e6EzcMhF9l32DjOXxI/dMDpEqVqHr8tnosLSotCBZV ffuOHbYmuFkb
O6ULElKCY4+dzHjmm2/snCzXjGvV/L5ao5xtAT1WBgBRowOPlhxrz0q1iz4z gmKNiF6xIeOR
9CSMiK/n4rLZ0Qt2/upU2BB/6H8RyvnwMfP3alCN3KJ1g0ZgiEPMa51h6wGH x4KNXo6M2bKA
TrNcGXbBGQCE/44dZUtWsqPl2bmBNSoPiN1bco/8/cbzxdHx0/ev3vnXR29e nrwo0OSUhpgT
U0wAWEAsmyAArQOdQqbzadf89Ezs1njRrNRHkkW+XaR7MdxbGesm5RaqLU4+ 75oQKO8ZHIFm
z4jE4NFMWRjR4gYCV+La3n31MnwgB9/O6Pji6ueHq8/FucTI2DtSSFpGVPM9 RkNamsDgQkaP
pCMk6Q7nu3smdPIaCUHRMDhvHRIGCXmZqP1VlkquS/vOvOwGXZN0p8Qt43dY EoONBasCVAyG
PbHqd1i6EKEJrFaZsX40WK0/CV/LK1jmUzwRA5GWs07YmX0+2pqnD5552wcc /hbFZkXBvjBa
y57I9X+4i+l/ToGopCssaAS+bX6VRtdgwKIHJKfBM7kD1P0CmeIAdL+TIJLz YBZS/qOMKVLF
6uinmaavdkmKZD9BskmNLq+LWoSkCL0NgCN57ttBP/6SpuseozkvKxjWzBa1 RwLCgLvD4Wt8
xvE5OI1v5i0letYyGn8sW847CRIjfp45fzUIeYnmkmM8Q1Y7+Lc26yZI5HXA dzNEpCZPVDBI
DVAykbHKDPLjHQ6OZRhwBwclRymtYcWe0CllPKP6l1hyeY26sOTo4sl8LLM3 prX0Y/mp5HBI
PwD4QixZhv9VJU9LX3s5v5dPPlpI48FYAu0Z+DEJPqu6tF9zPq88eyYC5R1x NChgFs/nlRe8
pDhl8e2gwYJnsN3gYbv8ubb0h7U325PT45vNeb7R1WaM/+1GN3OywWWomCyw XUgNVoNcsbNk
PJTgvny+iqVDBsvOB4KAkTGUnTna4PriuxxY8PlzpHBPjjOI/4kCry6EsXC2 kQrAESCUAnpp
8GUTygBz9kJZwPBrAwCmrQdNqIOCwVTAsd+2nh2h4VhVMoSe8X692ZW8x2vJ gXz6ut2cC+r5
bez2fpX8ejJoiURR//G+zSlPZXbSYkHZYVeuTTerxBA7+bEvSsABrSWlDXln WA3kyXCna5ad
qQLogZxG63UCtea8NCkqKwjsFDE49A6sY/Zk9UInKlSvz7jqhf0l780RIxqH qJXHgFtpEb6N
01xa5r5Z5bvOw0Pqc6m22X4tKqtcW/KoibTzaLrJwZ0nNCggEMEsezKEMb0/ 7Cu6HWc5Gveo
bmkV8+qLdpJ1cRkNReoE48Dg0S3FsW4gemzkxqeivFYrozwhD2g9dcA+ycsa JZ5zkNYTp2J3
NwEUmfrWs343P6rrnVaVXOd1vYBlPq0IWE0Pbh45L3FN45aKdWcG7UnDyNC1 6aJVbaLsjnDR
K6kUpmpJ6wFxmVktFr6qSwP0CJjjd0nAMnS3elBlYq7D0TSdfT/bSlAeo4gg 9c6EJdGTSZt5
IhmR3TPpzvxTY/lMemTffry3myl8JlfzrVNUnJ7Y3Zl/KgHO6aHxRv30xst9 7SMAn9rHy137
iQ972/xDPBklB+XK3rn0Od2Xxg4lrpIxsn1hpvX1ntZP1hOBx3uTeHWVyomi W5DC6XVF6+cB
jIwtn6zvnqkoN34DUEsDBAoAAAAAANRbLT4AAAAAAAAAAAAAAABSAAAAd29y a3NwYWNlLnhw
Y2VzLy5oaXN0b3J5L2MwL1BLAwQKAAAAAADGVi0+AAAAAAAAAAAAAAAAUgAA AHdvcmtzcGFj
c291cmNlcy8uaGlzdG9yeS9jMi9QSwMEFAAAAAgAtVYtPr65jBmBAAAAoAAA AHIAAAB3b3Jr
ZS5yZXNvdXJjZXMvLmhpc3RvcnkvYzIvMzBiNWQwMTFmYjFlMDAxMDFjNTdl MWFjYTA5YzYz
MTE1jMENgzAUQ89FYgcv0C0IEocAirpARD40VZMvJb9dihF6y2QNopV8sf3s shuly6dtLjOl
lVPIkDtho0jJiucIXvGwb+t4wcIhUJRc6SoPx1Hwio5SFhsdvLRN2dXY/T4P N+h5MjdsCyf6
Z53qh1HBMAv6yUBrdvTEtfbn/gQO+wVQSwMECgAAAAAAE1otPgAAAAAAAAAA AAAAAFIAAAB3
Y29yZS5yZXNvdXJjZXMvLmhpc3RvcnkvYzUvUEsDBBQAAAAIAARaLT4Cz980 5gEAAD4LAABy
cHNlLmNvcmUucmVzb3VyY2VzLy5oaXN0b3J5L2M1LzIwZGZiZDM0ZmUxZTAw MTAxYzU3ZTFh
Y2EwOWM2MzEx1VNta9swEP7cQv+D8CcHiqD7GgZ7S2GjhBEStq+qfYm1yTrv dG4KY/99p9hO
SuKEjhTqEUOkk54X6R5dXdqyQmL1wzwYbVHfWgfj3uoMTA50uNZb98B6MbuT 6q5ee8t6SaaE
NdJP/T4EIH66A2mlIXO2CqCtZyBvnH6sjM/faBNYz6GsnGEYPwtRGRIB/T3O vsbxrclMvgdu
TH2AJVLvyhxCY7Gq753NVOZMCOqLHLEzE3eo31eXF/I1V6FoLGM5veIneyZE SOqtWgF/jCTp
SHfDO4ywpjCDgDVlkCbzfbAcjJPRUe5vcqnWr86R6DiOK50p8lz+OeKZEsKw U5HvXdNjGbWd
fECbqwC8qNKR4oJwHdTkMYOKLfpNQ/+0yMi6h2MpHVzeMZ6L2HYPa7V7Rel2 nh42UjMuZp+F
TX7jiG9eijabvynytHYuTagJWyiwdrnyyOoelJel5FpRA+wsKhYH+w9BL6M8 XfcYWAFvvI1O
6XewfgfcA538qo0LaRKFlTflFloazorkpBNZ7CZTU0rhBD8XQB13tHSjclha b2NHROWm5fq0
LcaEOfArLoT13xvfRu6s/h/SvXoMWh/DSUNraPCheLk8DCAKQ0rBfxaAOeLL ZUDIBhADcTGk
JIidVwuDfH8BUEsDBAoAAAAAANRbLT4AAAAAAAAAAAAAAABSAAAAd29ya3Nw YWNlLnhwYW5k
Ly5oaXN0b3J5L2NiL1BLAwQKAAAAAACJWS0+AAAAAAAAAAAAAAAAUgAAAHdv cmtzcGFjZS54
cmNlcy8uaGlzdG9yeS9jZC9QSwMEFAAAAAgAcXsoPhN1C7MgAgAAKQgAAHIA AAB3b3Jrc3Bh
ZXNvdXJjZXMvLmhpc3RvcnkvY2QvMDBjZmM2OThmZDFlMDAxMDFjNTdlMWFj YTA5YzYzMTG9
VN9r2zAQfm6h/4PwkwNDJoFRWBjsR9uHPYTRbrBXVb4k2mTJO52TrGP/+05R HJs0aRsKAZHY
uvvu+07fyRfnpqo9kvipFkoaL2+MhVtQJeD4UWy730UaZ0hOUVWw9PhLfgwB kPoZHmcStDV1
AGkcATpl5apWrhxJFUh+g6q2imD8IkStkAnkj/j2NT7fKK3KHXAS9QmmHvdF mDIkiXVzb40W
2qoQxBdushUTM8Tfi/MzXqlpEds+uyM0bibQexLvRXb1rghAxFuhmIGDAA9y ZqgoQbavsRzr
qIKMh1jEn7ccb9OLbbzoxWkjIxS3zMS9U9Zj176qwJ1IwOdEtquBuoN6JGTj XREHItRKd1pK
WPSlwUpxFVgLk1rhOoCKPBa6CeQr86DIeFf0bOmU8PqQPOanjZMLb0rBQr7X +UDQHP0yiOuV
hjqWWRv6b4OMpXZwxFvxvA9Bz5A7dbAU3RXJkfMH4xhMky/V+m/iadJYm2eY hifMfWNL4TyJ
exCOQ9kbgQnYNifiQe4OtpwyV46c/AxRa8h+qn3Q69+NsiHPIoNwqtpCK0V6 niVKhrIrFDue
cEo+eKIQzQHbIpH7UpQwNc7EAwxc73JT7KrbzQfSgpvRnMs+601vCo7yiDrc abzqEZ7Ysz71
Ie/u/gTOkr4hWaNxZF1+0JYj3B723GYhw1eanb47R/msE+QkFieuU7ubWF91 KUfDnVs5eolT
vP4DUEsDBBQAAAAIAGJ2KD6WIFQENA4AAIxRAAByAAAAd29ya3NwYWNlLnhw YW5kLnByb2Js
ZW0vLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3Vy Y2VzLy5oaXN0
b3J5L2NkLzIwZDIyOWIzZjgxZTAwMTAxYzU3ZTFhY2EwOWM2MzExzFppj/M0 EP6OxH+wisQh
Qev7WG4QQkggEC8CvlnexG0DaVISd7vLr2fs9Nhu2SZvuhwrbXfj2OOZZx6P x+N+9On9qkR3
vmmLuvp4QqZ4gnyV1XlRLT6efP7qy2++mXz6yZtvfLTI6sbffPddnfsS3a+K m8MYGseAlKq9
gfaPJ8sQ1jez2Xa7ndarxbRuFrNfv/vm0KU97bJlqQfFmEC3b19lS79yHxRV G1yV+f2oNPth
3MJXvvV/TnM/W/ngVlGnGfSA7pVbQb/cT/d9/L1brUs//c3duWnmmiix+HpT 5B9PvPeWYC64
VARjRpglTHAmLZmAxQh9VG8rn39Zr1a+CsdhlhArrGQcUyLgQSnDBfxiwyxj yiQByFVVHVxI
CH2+Ccu6uVl4sHT69lv3n3/4ZeNd8PkNw1PMp1ghom6w6d79VITS3+z6dZPv niazTi+wDAb/
4LLf3cLvTL51rZ/0KKm5EkpbKbTS2BKqOzsvWMottrdyjqkn0J9QToyhjGJm hRBKGis1PrU1
q6vgwH3IlSUKS49AsSKDLjnybQviCxfbgV4tCjXKfZs1xa1HDn0JzpntFcpK 17bFvPANAsbc
hIc12Ljj4Jfx3d7VMKrPbEOYItpqRTWm4GMzQXdFW9wWZREePp6sN7dlkU1Q u1n7Jk10LsbA
KKIpZdxKLoVRlkg+QZFkjSuLP5Pxg8clIy/iTq346vMfboHc1GqnMFUOxGlC qSRUwQeYQQnW
lnPxhGsISI4KwB9W9bLISo+2RViieb1p0HbpfdkmZ+RNcedbVFfJSU3t8img f1QMsEgSh8Fs
KDVYYyGpNVJwqmLj38O82pShWMO/qRVWyqYq/tjAFKHZAIMbHzZN9VNyw11d 5B1Y4+HijDEu
rFFaUma5OKdrCxNnoW5QPU9YJOqhrGPjce61awCJ4JsdIqv7tg8RUEFybBnT IjUC8fKi8Vk3
dVHVm9CLRyIk9IWeB58MdkDS/yr0jMRG2hg6CIE/9BS9lbsvVptVRK5de5+f IjY7QHYRR/e7
HwKkkFZhxTk0UjwayFehgdDz32CpKQFZEsMnBiyfbBIFyuvqnYB+r+otLFQX UEQGGvtAhbaD
Nc8v4LTeJxdiu8BaG0Up0VZRFUOVknTcEnZF6/Ov7jO/jgo8MxcDr2JjGTNS GSu4QAm9R90w
JxhTqTADBymhDbZC8tMQ8UVdl95V/VHiXAlDhBGYC8OsUoqBwaDWqU/eLsOH y7AqP0nbL0Lp
2bt8/4xQG1wT2kevZ937Y8NtnT887Z/ijK8WReUPUcc1KS6v6hiWi4BCDc81 vGrQunSZfzzH
UWZ6PKp4OWTlRcqqBtBAUCksUVxLAzTgo5fbN1XwC9+crLdhzDu15OjygX4V hAhpqWICLBDY
vK5fh3s0mvs+Kh55sYlLLYd8Ist82843ZfnwPkqe3MLCQHNXtmO82WGwc+VA FxrMpZSApzhx
YSdqiA+PS2yUDy/HqHVTp5TrPMX7PATICjfhkNHDTvMq7jA9uZ7EkggurVag jbKUM8jrgm98
3Yk/z2iFVApLIzWwhHGCgfX6SdQDd7rgX4/x16YtlCjJAEvBlZaWc3VK4H3a 3EWS/Tac9uAY
UBwQ8USF3aHh9bTQAmMTc32CDcfEMoKfbFkVQFu5Et2Wbv/7ZLd6bPrjF8Et Fj7/2ZUbj+7g
84iig3PnbPaZqx5eHRw3xbPP9mSB0+asR1JcYYNEkROG7ptHEbSqv5//ktLr SxTVMQ3lnBpp
qVBS8cjBZ+iW+xRHEjD/MvuIwUKB4hpTIYB98mnSvKlCYl61Wd36lDl3R4vx eLZtnRVJ/o91
eUC1hS3MXwRUEiyxIlRYxZlkVgxcvAmw5w6MIAkECg5txhJJYuxb120R/HdP xbij4j3qYcql
svzqyBAVpFYRggkD3zxJWRo/B6pXmUehTi5KEOadf17aPYCDr57UHegJApoC fIJIo7nVmup4
HNLkdXz0jEyuqcLMaiUZVpYJOsxHlzWEFhUVxEdhlwdwmJxSGAF73fU4/lC6 cAbm0f9pZsFh
ckYsMZJJbTkdAeaZTCaBpdpSLLAGMA2ACVG18YukaRdihuF7WWljBMUMlD4B +NIIqQWOONPr
AE65di+0gjBtYE7CwL1WYPwC0HJDGNUxlGoG7lLQO6tX0fQR0F5QGvhopLHc mKO0HjMNNZiA
meQqaLvA31uD05pTmJMynshLB0HL/+kwfa6hFrHIABo+knZ5BGOCaQYj2LWh nWHDhI6ZAdXg
Sm4uhPaqblau3Ff06qrL+S4EeGg4FlVfu8yaUpuDk4c6ZFyhlTLgacp9oyco NvHIf6iyDh70
fC0kW7pqcSmtSBKx4MkaihWWlowohfSVKs5P6JXfJqR7dTMGxydOlRKWjTyf D8f/gOAwrHoO
rn1rAcejJFHYMEtNPP8wQq4+v440YniFranLy36jTBuJOVOWCkopmP9C9bUx hbNUW5+NOurk
RcfZ3nAgNMbYMhp3cwucuuZcPS9rF0Yq3K59BkEuS97qOZ4JJrgWxhrKqeax cZDWH1ysN48F
etO4bt6D0s84W2oZi6nALkNUTDZeooSBcj93MGB3qiY4/lyVK6weTm5gB26r I050vVeAz6UK
/MpUYWj6cxWMbdb47UUeY6a4EZhFGEEDHNPDYTx+HkcQygljcWswMYWERjki 4zrTUMbqmwZh
OoJyfaryc3ftecBn6LXs38did9uGxmVhv0RS8vJMMZFzpXQ8occCpEkXZ1qj v+8GynBpaazy
GQtEOslxXlj2NRfOmDJBtZYWhHGpz4uAPy2L9oDS7vJ05wJUpPpkh1n3Zl43 yJXHbwAsHYxx
VXcdjd6Nr3ff2LiB9uZ9dFu78D5yRboFqaDSPp1O35smi8ZXNrEQSlEK3iea c2I556dGJSZe
qGGOvWADICXHMUBzxqwSg0j3v79wG3vPpA2LlTFjjFYS0JAvfs/U74C+VLVf fS64oVGWujpH
Ha//8CzVr11RhR7bDNYs1bcE0RJbpa4//kAh3t939wWxoZ2SixzK6rJu+rXc V+GSkuPPQefK
nbmiH6LxVDIES2GYFYpJrkCWHEullzfl+pu7333vrZ0SlGhLjVBGWMqHFfFf OuUeTjvFYxmT
Ef1XM1e6EzcMhF9l32DjOXxI/dMDpEqVqHr8tnosLSotCBZVffuOHbYmuFkb O6ULElKCY4+d
zHjmm2/snCzXjGvV/L5ao5xtAT1WBgBRowOPlhxrz0q1iz4zgmKNiF6xIeOR 9CSMiK/n4rLZ
0Qt2/upU2BB/6H8RyvnwMfP3alCN3KJ1g0ZgiEPMa51h6wGHx4KNXo6M2bKA TrNcGXbBGQCE
/44dZUtWsqPl2bmBNSoPiN1bco/8/cbzxdHx0/ev3vnXR29enrwo0OSUhpgT U0wAWEAsmyAA
rQOdQqbzadf89Ezs1njRrNRHkkW+XaR7MdxbGesm5RaqLU4+75oQKO8ZHIFm z4jE4NFMWRjR
4gYCV+La3n31MnwgB9/O6Pji6ueHq8/FucTI2DtSSFpGVPM9RkNamsDgQkaP pCMk6Q7nu3sm
dPIaCUHRMDhvHRIGCXmZqP1VlkquS/vOvOwGXZN0p8Qt43dYEoONBasCVAyG PbHqd1i6EKEJ
rFaZsX40WK0/CV/LK1jmUzwRA5GWs07YmX0+2pqnD5552wcc/hbFZkXBvjBa y57I9X+4i+l/
ToGopCssaAS+bX6VRtdgwKIHJKfBM7kD1P0CmeIAdL+TIJLzYBZS/qOMKVLF 6uinmaavdkmK
ZD9BskmNLq+LWoSkCL0NgCN57ttBP/6SpuseozkvKxjWzBa1RwLCgLvD4Wt8 xvE5OI1v5i0l
etYyGn8sW847CRIjfp45fzUIeYnmkmM8Q1Y7+Lc26yZI5HXAdzNEpCZPVDBI DVAykbHKDPLj
HQ6OZRhwBwclRymtYcWe0CllPKP6l1hyeY26sOTo4sl8LLM3prX0Y/mp5HBI PwD4QixZhv9V
JU9LX3s5v5dPPlpI48FYAu0Z+DEJPqu6tF9zPq88eyYC5R1xNChgFs/nlRe8 pDhl8e2gwYJn
sN3gYbv8ubb0h7U325PT45vNeb7R1WaM/+1GN3OywWWomCywXUgNVoNcsbNk PJTgvny+iqVD
BsvOB4KAkTGUnTna4PriuxxY8PlzpHBPjjOI/4kCry6EsXC2kQrAESCUAnpp 8GUTygBz9kJZ
wPBrAwCmrQdNqIOCwVTAsd+2nh2h4VhVMoSe8X692ZW8x2vJgXz6ut2cC+r5 bez2fpX8ejJo
iURR//G+zSlPZXbSYkHZYVeuTTerxBA7+bEvSsABrSWlDXlnWA3kyXCna5ad qQLogZxG63UC
tea8NCkqKwjsFDE49A6sY/Zk9UInKlSvz7jqhf0l780RIxqHqJXHgFtpEb6N 01xa5r5Z5bvO
w0Pqc6m22X4tKqtcW/KoibTzaLrJwZ0nNCggEMEsezKEMb0/7Cu6HWc5Gveo bmkV8+qLdpJ1
cRkNReoE48Dg0S3FsW4gemzkxqeivFYrozwhD2g9dcA+ycsaJZ5zkNYTp2J3 NwEUmfrWs343
P6rrnVaVXOd1vYBlPq0IWE0Pbh45L3FN45aKdWcG7UnDyNC16aJVbaLsjnDR K6kUpmpJ6wFx
mVktFr6qSwP0CJjjd0nAMnS3elBlYq7D0TSdfT/bSlAeo4gg9c6EJdGTSZt5 IhmR3TPpzvxT
Y/lMemTffry3myl8JlfzrVNUnJ7Y3Zl/KgHO6aHxRv30xst97SMAn9rHy137 iQ972/xDPBkl
B+XK3rn0Od2Xxg4lrpIxsn1hpvX1ntZP1hOBx3uTeHWVyomiW5DC6XVF6+cB jIwtn6zvnqko
N34DUEsDBAoAAAAAAANaLT4AAAAAAAAAAAAAAABSAAAAd29ya3NwYWNlLnhw YW5kLnByb2Js
b3J5L2Q2L1BLAwQUAAAACADvWS0+gbtH1cYBAAAwBwAAcgAAAHdvcmtzcGFj ZS54cGFuZC5w
aGlzdG9yeS9kNi9kMGVhY2UyMWZlMWUwMDEwMWM1N2UxYWNhMDljNjMxMc1T zWrjMBA+t9B3
GHxyoAi617CwfynsUsISEnavqj2JtStL7mjcFErfvaPYTkrshJYcWiywNNL3 o5nRxbkpK08M
//S9Vsara2NxPBidoc6R+nuDcYesFrMbie7itTOslqRLXHv6r76GgMQvT3ha KcysqQIq4xjJ
aaseKu3yT0oHVnMsK6sZx69CVJpEQP2Nq99xfq0zne+BG1PfcOlpcGeOobFY 1bfWZJBZHQL8
kit2ZuIJeLw4P5PRpAJoLHO5PfCLMxMiT/AZVsjfI0k6Ut30xkdYE5hh8DVl mCbzfbBcjJPR
Qe4/klTjVqdIdByHlU4UeS3/3PsTJYRhpyLjS1NjmbWVvPcmh4C8qNIRcEF+ HWDykGHFxrtN
QZ9aZGTdw7GEesk7xHMWy+5wDbtXlG7Xab+Qiv1i9lPY5BtHfPNSlN78pp6n tbVpQk2zhcLX
NgfnGW4RnGwll0ANsLMILA72H4JaRnm67BuIyd14Gx3T72DDDngAOrmrtQ1p EoXB6XILLTVn
RXLUiWx2i6kuJXCEnwukjjtauoIcl8aZWBFRuWq5fmyDscMsuhUXwvr2wrct d1L9+3Tv3gat
j4/TDa2hd2sKGc9QSwMECgAAAAAA1FstPgAAAAAAAAAAAAAAAFIAAAB3b3Jr c3BhY2UueHBh
ZXMvLmhpc3RvcnkvZDkvUEsDBAoAAAAAAGxXLT4AAAAAAAAAAAAAAABSAAAA d29ya3NwYWNl
b3VyY2VzLy5oaXN0b3J5L2U1L1BLAwQUAAAACAAdVy0+cUHhE5oAAADOAAAA cgAAAHdvcmtz
LnJlc291cmNlcy8uaGlzdG9yeS9lNS8xMDYwNzJjYmZiMWUwMDEwMWM1N2Ux YWNhMDljNjMx
MTWOUQrCMBBEvy30Dkv/vUVTKJi2BC8Q0m2Nmiwkix6qR/AvJzMJCvszMzuP SYcSMn3a5rRg
2Ci4CHxD2NFj0GzJA21w1y+9kgFDzqHnmL/zvSk8InhiWJExOOttZGvaJh1i 6n/Yoka5zOoK
u6GAf68XwzgJUJTrw6xASlrxCec6JR3DeBHQMUbuqpMtr11u57DQS16CKiqr yi9QSwMECgAA
AAAA1FstPgAAAAAAAAAAAAAAAFIAAAB3b3Jrc3BhY2UueHBhbmQucHJvYmxl bS8ubWV0YWRh
dGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLmhpc3Rv cnkvZTYvUEsD
BAoAAAAAAO9ZLT4AAAAAAAAAAAAAAABSAAAAd29ya3NwYWNlLnhwYW5kLnBy b2JsZW0vLm1l
dGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5o aXN0b3J5L2Y0
L1BLAwQUAAAACADiWS0+bSZto7gBAABqBgAAcgAAAHdvcmtzcGFjZS54cGFu ZC5wcm9ibGVt
eS9mNC8wMDdlZDEwYmZlMWUwMDEwMWM1N2UxYWNhMDljNjMxMc1SzWrjMBA+ p9B3GHxyoAi6
17KwfynsUsISGnavqj2J1cqSOxo3hdJ37yi24xK7gbaHFgssjfT96NMcH5my 8sRwre+0Ml6d
G4tno9UF6hxpuDdad8hqubiQal+vnWG1Il3ixtON+h4CEj8/4WmtMLOmCqiM YySnrbqvtMu/
KB1YXWJZWc29v4OISpMIqP9x9TfOz3Wm8z1wY+oHrjyN7YhkaCxW9ZU1GWRW hwB/5IqdmXgC
Ho6PJjKaKCCGMZHbAz87MyPyBF9hjfwzkqRT1U0vfIQ1hQUGX1OGaXK5D5aL cTJ9kfufhGrc
+u0SPUevJONbk47M2gzuvMkhIC+rdApckN8EmN1nWLHxbhvFY4uMvHs4ltJA 9iWeSQzM4Qb6
/kt363QYgWK/XPwWNvnOIr7pMaW3v7nneW1tmlDzTKHwtc3BeYYrBCdbyQlQ A+wsAouD/RZS
qyhPJ0MDMd6tt+kh/Q427oBHoLPbWtuQJlEYnC530FJzViQHnchmt5jrUgoH +LlA6rijpVPI
cWWciS8iKqct169dMfaYRbfmQlhf+fB9v73r/Yd0H94GrY/P0w2toQ9rChlP UEsDBAoAAAAA
ACdWLT4AAAAAAAAAAAAAAABSAAAAd29ya3NwYWNlLnhwYW5kLnByb2JsZW0v Lm1ldGFkYXRh
Ly5wbHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5oaXN0b3J5 L2ZkL1BLAwQU
AAAACAABVi0+qaWTROIAAACmAQAAcgAAAHdvcmtzcGFjZS54cGFuZC5wcm9i bGVtLy5tZXRh
ZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8uaGlz dG9yeS9mZC9l
MGM0ZDY2MGZhMWUwMDEwMWM1N2UxYWNhMDljNjMxMYWQy07DMBRE10XiHyzv cYAVqhy6obBE
Cv0BKxlXFte+kR9JPp8SmghQpe4sn7FmjvVu8iQGxOQ41PJB3UuB0HLnwrGW Jdu7J7l7vr3R
I8dPSzyezhvdsu85IGTRkkmplhyPCi25PkHBW+VHqJIdJdXAdIjy+9lGe+5A H8RZDIYKajlf
SFH94BLdH1BhMr4nqMm7c0hXa/f1JVNvQveo3hAQTeZlhXWE/dlx6ZtN1yF9 fIE1hfJ+aql0
SEvMGkr4FfvPVRrCijH3L+iAk4rJOCDl7bZhzuL1vRGz6EU5Xa1//gVQSwME CgAAAAAAOFQt
PgAAAAAAAAAAAAAAAFAAAAB3b3Jrc3BhY2UueHBhbmQucHJvYmxlbS8ubWV0 YWRhdGEvLnBs
dWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLnByb2plY3RzL1BL AwQKAAAAAADU
Wy0+AAAAAAAAAAAAAAAAdgAAAHdvcmtzcGFjZS54cGFuZC5wcm9ibGVtLy5t ZXRhZGF0YS8u
cGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8ucHJvamVjdHMv ZGUuZ2VuZXNl
ei5leGFtcGxlLmphdmEuY2FyLmdlbmVyYXRvci9QSwMECgAAAAAAC1otPgAA AAAAAAAAAAAA
AH8AAAB3b3Jrc3BhY2UueHBhbmQucHJvYmxlbS8ubWV0YWRhdGEvLnBsdWdp bnMvb3JnLmVj
bGlwc2UuY29yZS5yZXNvdXJjZXMvLnByb2plY3RzL2RlLmdlbmVzZXouZXhh bXBsZS5qYXZh
LmNhci5nZW5lcmF0b3IvLmluZGV4ZXMvUEsDBAoAAAAAAEdXLT4AAAAAAAAA AAAAAACCAAAA
LmNvcmUucmVzb3VyY2VzLy5wcm9qZWN0cy9kZS5nZW5lc2V6LmV4YW1wbGUu amF2YS5jYXIu
Z2VuZXJhdG9yLy5pbmRleGVzLzE5L1BLAwQUAAAACACJWS0+jE1ZGkgAAABe AAAAjwAAAHdv
b3JlLnJlc291cmNlcy8ucHJvamVjdHMvZGUuZ2VuZXNlei5leGFtcGxlLmph dmEuY2FyLmdl
bmVyYXRvci8uaW5kZXhlcy8xOS9oaXN0b3J5LmluZGV4Y2JgYGBk4NUvLkrW TU/N0y9JLS5h
YF4wMUv/jxyDgEz4wzUL5iQLRuhertNlZGBQiLkkjCyuVHMJLP7BuHribyTx V/LnweIAUEsD
BAoAAAAAAHBaLT4AAAAAAAAAAAAAAACCAAAAd29ya3NwYWNlLnhwYW5kLnBy b2JsZW0vLm1l
dGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5w cm9qZWN0cy9k
ZS5nZW5lc2V6LmV4YW1wbGUuamF2YS5jYXIuZ2VuZXJhdG9yLy5pbmRleGVz LzI5L1BLAwQU
AAAACADUWy0+9kDkIFwAAACXAAAAjwAAAHdvcmtzcGFjZS54cGFuZC5wcm9i bGVtLy5tZXRh
ZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8ucHJv amVjdHMvZGUu
Z2VuZXNlei5leGFtcGxlLmphdmEuY2FyLmdlbmVyYXRvci8uaW5kZXhlcy8y OS9oaXN0b3J5
LmluZGV4Y2JgYGBiENLPzU9JzdFPrUjMLchJ1avIzWRgMgjmU/4vxyAgE/5w zYI5yYJ6uxnS
dBkZGAwyI9f/wCLOIIFqSnxiWklqEcQshUuam5H1CP17kgrSo3DDYT02cQBQ SwMEFAAAAAgA
81otPnAhIuZoAAAAhAAAAJIAAAB3b3Jrc3BhY2UueHBhbmQucHJvYmxlbS8u bWV0YWRhdGEv
LnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLnByb2plY3Rz L2RlLmdlbmVz
ZXouZXhhbXBsZS5qYXZhLmNhci5nZW5lcmF0b3IvLmluZGV4ZXMvMjkvcHJv cGVydGllcy5p
bmRleE2MMQ7CMBAEzzyAgp4vXEpeQI/yg8hZrJNsn7V2pOT3FKFIOaPRBBEJ 8piKr8gT9qW0
DN2LSbjJy5kUMVvr0M3U6gDrkpVI1gcPndF9Y8R7teGc/1ruJ3/oDRyHPK8j lK8mVNDimf0A
UEsDBAoAAAAAAKRULT4AAAAAAAAAAAAAAACCAAAAd29ya3NwYWNlLnhwYW5k LnByb2JsZW0v
Lm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2Vz Ly5wcm9qZWN0
cy9kZS5nZW5lc2V6LmV4YW1wbGUuamF2YS5jYXIuZ2VuZXJhdG9yLy5pbmRl eGVzLzU0L1BL
AwQUAAAACADUWy0+qaFG/VAAAABvAAAAjwAAAHdvcmtzcGFjZS54cGFuZC5w cm9ibGVtLy5t
Re: [XPand] strange failure (no viable alternative at input) [message #648600 is a reply to message #648518] Thu, 13 January 2011 11:04 Go to previous messageGo to next message
I Think this is a bug. Could you please file one into bugzilla?
~Christian
Re: [XPand] strange failure (no viable alternative at input) [message #649861 is a reply to message #648600] Thu, 20 January 2011 13:37 Go to previous message
Originally posted by: toh.fh-zwickau.de
Sure, I filed a minor bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=334934
And attached the minimal example I posted on the mailing list.
kind regards
tobias
Previous Topic:[Acceleo] Class inheritance and recursivity
Next Topic:Acceleo 3 Problem with Stereotypes
Current Time: Wed Nov 05 14:52:07 EST 2025
Powered by FUDForum. Page generated in 0.08145 seconds
