Home » Eclipse Projects » Remote Application Platform (RAP) » RAP or E4(Create a Web Application using an existing RCP)
RAP or E4 [message #642910] Fri, 03 December 2010 05:21 Go to next message
i want to create a Web Application using an existing RCP Project,
What are the benefits of using the RAP Technologie ?
or is it better to use the E4 Technologie with RAP ?
pros and cons ?
thx for every help
Hussein
Re: RAP or E4 [message #642924 is a reply to message #642910] Fri, 03 December 2010 06:24 Go to previous messageGo to next message
Hi Hussein,
although it is mostly possible to run e4 applications on RAP [1], I would
not recommend to start a new RAP application with e4 at the moment.
The work on e4 is still in an early state and I don't see much adoption
right now. There is neither public API, nor tooling for the new
programming concepts.
You're asking about the benefits of RAP:
- Code reuse: Web and desktop apps from a single shared codebase
- Modularity: the full power of OSGi for web applications
- Use of Eclipse technology: Use existing technology like EMF, BIRT ...
- Programming model: Use your familiar development environment: Code
assists, automatic refactorings, unit tests, debugging ...
does this suffice to convince you? ;-)
Ralf
[1] http://eclipsesource.com/blogs/2010/08/10/mars-rover-challan ge-
revival/
Ralf Sternberg
Twitter: http://twitter.com/ralfstx
Blog: http://www.eclipsesource.com/blogs/
Professional support for RAP and RCP?
http://www.eclipsesource.com/support/
Re: RAP or E4 [message #642926 is a reply to message #642924] Fri, 03 December 2010 06:38 Go to previous message
Hi Ralf,
Thank you very much for the fast Answer...
i was going to use the RAP from the Start but i bumbed into the E4 and just wanted to be sure to make the right choice! Smile
Previous Topic:Websphere, RAP and Principal
Next Topic:RCP to RAP
Current Time: Fri Sep 26 13:31:12 EDT 2025
Powered by FUDForum. Page generated in 0.03191 seconds
