Home » Archived » Swordfish » FlightBooking demo not working(IWAB0135E An unexpected error has occurred. 500 javax.xml.ws.WebServiceException)
FlightBooking demo not working [message #642747] Thu, 02 December 2010 10:26 Go to next message
Hi everybody,
I have the problem that running my 'CompositeProvider' throws these Exceptions:
Exception in thread "JMX Connector Thread [service:jmx:rmi:///jndi/rmi://localhost:4711/jmxrmi]" org.springframework.jmx.JmxException: Could not start JMX connector server after delay; nested exception is java.io.IOException: Cannot bind to URL [rmi://localhost:4711/jmxrmi]: javax.naming.NameAlreadyBoundException: jmxrmi [Root exception is java.rmi.AlreadyBoundException: jmxrmi]
    at org.springframework.jmx.support.ConnectorServerFactoryBean$1.run(ConnectorServerFactoryBean.java:157)
Caused by: java.io.IOException: Cannot bind to URL [rmi://localhost:4711/jmxrmi]: javax.naming.NameAlreadyBoundException: jmxrmi [Root exception is java.rmi.AlreadyBoundException: jmxrmi]
    at javax.management.remote.rmi.RMIConnectorServer.newIOException(Unknown Source)
    at javax.management.remote.rmi.RMIConnectorServer.start(Unknown Source)
    at org.springframework.jmx.support.ConnectorServerFactoryBean$1.run(ConnectorServerFactoryBean.java:154)
Caused by: javax.naming.NameAlreadyBoundException: jmxrmi [Root exception is java.rmi.AlreadyBoundException: jmxrmi]
    at com.sun.jndi.rmi.registry.RegistryContext.bind(Unknown Source)
    at com.sun.jndi.toolkit.url.GenericURLContext.bind(Unknown Source)
    at javax.naming.InitialContext.bind(Unknown Source)
    at javax.management.remote.rmi.RMIConnectorServer.bind(Unknown Source)
    ... 2 more
Caused by: java.rmi.AlreadyBoundException: jmxrmi
    at sun.rmi.registry.RegistryImpl.bind(Unknown Source)
    at sun.rmi.registry.RegistryImpl_Skel.dispatch(Unknown Source)
    at sun.rmi.server.UnicastServerRef.oldDispatch(Unknown Source)
    at sun.rmi.server.UnicastServerRef.dispatch(Unknown Source)
    at sun.rmi.transport.Transport$1.run(Unknown Source)
    at sun.rmi.transport.Transport.serviceCall(Unknown Source)
    at sun.rmi.transport.tcp.TCPTransport.handleMessages(Unknown Source)
    at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(Unknown Source)
    at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(Unknown Source)
    at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
    at java.lang.Thread.run(Unknown Source)
    at sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServer(Unknown Source)
    at sun.rmi.transport.StreamRemoteCall.executeCall(Unknown Source)
    at sun.rmi.server.UnicastRef.invoke(Unknown Source)
    at sun.rmi.registry.RegistryImpl_Stub.bind(Unknown Source)
    ... 6 more
and therefor the WS test of 'FlightBookingProvider' ends in a:
500
This is bothering me a lot since 'FlightReservation' and 'PaymentProcessing' did work just fine on there own.
I also made sure to add '-DrmiRegistryPort=4711' is added to the arguments of 'CompositeProvider' and that the endpoint in the spring file of 'FlightBookingProvider' is pointing to 'http://localhost:8198/FlightBooking_Service/'
Re: FlightBooking demo not working [message #642752 is a reply to message #642747] Thu, 02 December 2010 10:36 Go to previous messageGo to next message
Hi Christian,
actually the NameAlreadyBoundException has no effect on the functioning of the service, but results in the osgi instance not starting up JMX only.
I expect you have started
- one instance / run config containing providers for reservation and payment processing
- one containing consumers for reservation, payment processing and the provider for booking
- try to access the flight booking service using the web services explorer
Is that correct?
Cheers
Jürgen
Re: FlightBooking demo not working [message #642783 is a reply to message #642752] Thu, 02 December 2010 11:46 Go to previous messageGo to next message
Hi Jürgen,
thanks for this super quick reply first of all.
I went to 'run configurations' and first started 'Provider' which contains 'FlightReservation (1.0.0.qualifier)' and 'PaymentProcessing_Service(1.0.0.qualifier)' and then i used 'run confidurations' again to start up 'CompositeProvider' containing all the other stuff.
After that i tried the 'FlightBooking.wsdl' file but it still throws the error.
Christian
Re: FlightBooking demo not working [message #643740 is a reply to message #642783] Wed, 08 December 2010 01:47 Go to previous messageGo to next message
Hi Christian,
sorry for the late reply.
I am not sure about what your problem is so let me just briefly describe what I would look at to get it running:
1. Make sure that the target platform is set correctly.
2. Start up the "low level" providers (FlightReservationProvider, PaymentProcessingProvider) in a run configuration
3. Start up the composite service (FlightReservationConsumer, PaymentProcessingConsumer, FlightBookingProvider). In here you may want to change the JMX port to a separate number (as described in the docs).
4. Verify that all non-fragment bundles have been started in your OSGi instances using the ss console command.
5. Do a short check by pasting the Service URL of the FlightBookingProvider into my WebBrowser - normallly you should be able to get a list of services containing a link that will then display the WSDL of your service...
6. Point WSExplorer to the WSDL URL from the browser and send a request or create a FlightBookingConsumer (including sample code), add a call to the provider there and run this consumer separately ...
HTH
Jürgen
Re: FlightBooking demo not working [message #644072 is a reply to message #643740] Thu, 09 December 2010 05:52 Go to previous message
Hi Jürgen,
sorry for my slowness but I just don't manage to get it running.
After starting the 'CompositeProvider'and typing 'ss', it prints:
Framework is launched.
id    State       Bundle
0    ACTIVE      org.eclipse.osgi_3.6.0.v20100517
                Fragments=13
1    ACTIVE      org.apache.servicemix.jbi.deployer_1.0.0.v201006150915
2    ACTIVE      org.apache.servicemix.nmr.core_1.0.0.v201006150915
3    ACTIVE      org.apache.xbean.spring_3.5.0.v201006150915
4    ACTIVE      org.springframework.osgi.io_1.0.2.v201006150915
5    ACTIVE      org.mortbay.jetty.util_6.1.15.v200905182336
6    ACTIVE      org.apache.xml.resolver_1.2.0.v201005080400
7    ACTIVE      org.eclipse.swordfish.plugins.cxf.support_0.10.0.v201006150915
8    ACTIVE      org.eclipse.swordfish.plugins.resolver.backend.local_0.10.0.v201006150915
9    ACTIVE      org.eclipse.osgi.util_3.2.100.v20100503
10    ACTIVE      javax.xml.soap_1.3.0.v201005080502
11    ACTIVE      org.apache.commons.httpclient_3.1.0.v201005080502
12    ACTIVE      org.apache.servicemix.soap2_2009.1.0.v201006150915
13    RESOLVED    javax.transaction_1.1.1.v201006150915
                Master=0
14    ACTIVE      org.apache.servicemix.nmr.management_1.0.0.v201006150915
15    ACTIVE      org.springframework.aop_2.5.2.v201006150915
16    ACTIVE      org.eclipse.swordfish.core.resolver_0.10.0.v201006150915
17    ACTIVE      org.springframework.osgi.extender_1.0.2.v201006150915
18    ACTIVE      javax.xml.ws_2.1.0.v200902101523
19    ACTIVE      org.eclipse.swordfish.plugins.compression_0.10.0.v201006150915
20    ACTIVE      org.eclipse.swordfish.plugins.tracking_0.10.0.v201006150915
21    ACTIVE      org.apache.servicemix.cxf.transport.nmr_4.0.0.v201006150915
22    ACTIVE      PaymentProcessingConsumer_1.0.0.qualifier
23    ACTIVE      javax.servlet_2.5.0.v200910301333
24    ACTIVE      org.apache.servicemix.soap_2009.1.0.v201006150915
25    ACTIVE      javax.annotation_1.1.1.v201006150915
26    ACTIVE      com.ctc.wstx_3.2.8.v201006150915
27    ACTIVE      org.apache.xbean.classloader_3.5.0.v201006150915
28    ACTIVE      javax.xml.stream_1.0.1.v201004272200
29    ACTIVE      org.eclipse.swordfish.plugins.resolver.backend.base_0.10.0.v201006150915
30    ACTIVE      org.springframework.core_2.5.2.v201006150915
31    ACTIVE      org.apache.servicemix.kernel.jaas.boot_1.1.0.v201006150915
32    ACTIVE      org.eclipse.swordfish.core.planner_0.10.0.v201006150915
33    ACTIVE      org.apache.cxf_2.1.3.v201006150915
34    ACTIVE      javax.jbi_1.2.0.v201006150915
35    ACTIVE      javax.xml_1.3.4.v201005080400
36    ACTIVE      org.apache.neethi_2.0.4.1
37    ACTIVE      org.apache.servicemix.kernel.jaas.modules_1.1.0.v201006150915
38    RESOLVED    org.eclipse.swordfish.compatibility.wsdl4j_0.10.0.v201006150915
                Master=87
39    ACTIVE      org.eclipse.swordfish.core.configuration_0.10.0.v201006150915
40    ACTIVE      org.eclipse.swordfish.api_0.10.0.v201006150915
41    ACTIVE      javax.jws_2.0.0.v201005080400
42    ACTIVE      org.apache.servicemix.cxf.binding.nmr_4.0.0.v201006150915
43    ACTIVE      org.mortbay.jetty.client_6.1.15.v201006150915
44    ACTIVE      org.apache.servicemix.cxf.transport.osgi_4.0.0.v201006150915
45    ACTIVE      org.apache.servicemix.jbi.runtime_1.0.0.v201006150915
46    RESOLVED    org.mortbay.jetty.security_6.1.15.v201006150915
                Master=52
47    ACTIVE      org.apache.servicemix.http_2009.1.0.v201006150915
48    ACTIVE      org.apache.servicemix.nmr.spring_1.0.0.v201006150915
49    ACTIVE      org.eclipse.osgi.services_3.2.100.v20100503
50    ACTIVE      javax.activation_1.1.0.v201005080500
51    ACTIVE      org.springframework.osgi.core_1.0.2.v201006150915
52    ACTIVE      org.mortbay.jetty.server_6.1.15.v200905151201
                Fragments=46
53    ACTIVE      org.eclipse.equinox.http.servlet_1.1.0.v20100503
54    ACTIVE      org.eclipse.swordfish.plugins.planner.policy_0.10.0.v201006150915
55    ACTIVE      org.eclipse.swordfish.core.util.smx_0.10.0.v201006150915
56    ACTIVE      org.apache.servicemix.nmr.osgi_1.0.0.v201006150915
57    ACTIVE      org.eclipse.equinox.preferences_3.3.0.v20100503
58    ACTIVE      org.springframework.context_2.5.2.v201006150915
59    ACTIVE      org.apache.servicemix.kernel.management_1.1.0.v201006150915
60    ACTIVE      javax.mail_1.4.0.v201005080615
61    ACTIVE      org.apache.cxf.transport.jbi_2.1.3.v201006150915
62    ACTIVE      org.eclipse.equinox.http.jetty_2.0.0.v20100503
63    ACTIVE      org.eclipse.swordfish.plugins.resolver.backend.remote_0.10.0.v201006150915
64    ACTIVE      org.apache.servicemix.kernel.jaas.config_1.1.0.v201006150915
65    ACTIVE      FlightReservationConsumer_1.0.0.qualifier
66    ACTIVE      org.apache.cxf.binding.jbi_2.1.3.v201006150915
67    ACTIVE      org.eclipse.swordfish.core_0.10.0.v201006150915
68    ACTIVE      org.apache.servicemix.common_2009.1.0.v201006150915
69    ACTIVE      org.eclipse.equinox.cm_1.0.100.v20090520-1800
70    ACTIVE      org.apache.axiom_1.2.4.v201006150915
71    ACTIVE      org.eclipse.swordfish.core.event_0.10.0.v201006150915
72    ACTIVE      org.apache.commons.logging_1.1.1.v201005080502
73    ACTIVE      org.apache.commons.codec_1.3.0.v20100518-1140
74    ACTIVE      FlightBookingProvider_1.0.0.qualifier
75    ACTIVE      org.apache.servicemix.jbi.osgi_1.0.0.v201006150915
76    ACTIVE      org.objectweb.asm_3.1.0.v200803061910
77    ACTIVE      org.eclipse.equinox.event_1.2.0.v20100503
78    ACTIVE      org.aopalliance_1.0.0.v200905130917
79    ACTIVE      org.eclipse.swordfish.core.util_0.10.0.v201006150915
80    ACTIVE      org.eclipse.swordfish.compatibility.cxf.minimal_0.10.0.v201006150915
81    ACTIVE      org.eclipse.equinox.util_1.0.200.v20100503
82    ACTIVE      org.apache.ant_1.7.1.v20100518-1145
83    ACTIVE      org.apache.servicemix.document_1.0.0.v201006150915
84    ACTIVE      org.apache.servicemix.kernel.filemonitor_1.1.0.v201006150915
85    ACTIVE      org.apache.servicemix.utils_1.1.0.v201006150915
86    ACTIVE      org.mortbay.management_6.1.15.v201006150915
87    ACTIVE      javax.wsdl_1.6.2.v201005080631
                Fragments=38
88    ACTIVE      org.springframework.beans_2.5.2.v201006150915
89    ACTIVE      org.eclipse.swordfish.plugins.resolver.policy_0.10.0.v201006150915
90    ACTIVE      org.apache.servicemix.nmr.api_1.0.0.v201006150915
91    ACTIVE      com.sun.xml.bind_2.1.12.v201003251730
92    ACTIVE      org.eclipse.swordfish.plugins.ws.wsdlgenerator_0.10.0.v201006150915
93    ACTIVE      org.apache.ws.commons.schema_1.4.2.v201003051240
94    ACTIVE      org.eclipse.equinox.common_3.6.0.v20100503
95    ACTIVE      javax.xml.bind_2.1.9.v201005080401
osgi>
Then I copied the URI from the cfx-enpoint.xml of 'FlightBookingProvider' into my browser (http://localhost:8198/FlightBooking_Service/) and it says:
HTTP ERROR 404
Problem accessing /FlightBooking_Service/. Reason:
Unable to find requested resource
I altered the Arguments of 'CompositeProvider' the following:
-Declipse.ignoreApp=true
-Dosgi.noShutdown=true
-Dservicemix.base=.
-Dorg.osgi.service.http.port=9002
As you can see I also use another http-port just to be on the save side but it didn't change the result.
Running the 'FlightBooking.wsdl' ends up in the following errors:
09.12.2010 11:47:27 org.eclipse.swordfish.plugins.planner.policy.PolicyBasedFilterStrategy filter
INFO: Filtering the interceptors with the followng list of policy based hints: []
INFO: Dropped interceptor org.eclipse.swordfish.plugins.compression.ConsumerRequestCompressionInterceptor@f8395f from the list of valid interceptors.
INFO: Dropped interceptor org.eclipse.swordfish.plugins.compression.ConsumerResponseDecompressionInterceptor@1381960 from the list of valid interceptors.
INFO: Dropped interceptor org.eclipse.swordfish.plugins.compression.ProviderRequestDecompressionInterceptor@e99ce5 from the list of valid interceptors.
INFO: Dropped interceptor org.eclipse.swordfish.plugins.compression.ProviderResponseCompressionInterceptor@1eb904d from the list of valid interceptors.
INFO: Dropped interceptor org.eclipse.swordfish.internal.core.interceptor.CxfDecoratingInterceptor@1a503f from the list of valid interceptors.
09.12.2010 11:47:27 org.eclipse.swordfish.samples.flightbooking.FlightBookingImpl bookFlight
INFO: Executing operation bookFlight
09.12.2010 11:47:27 org.apache.cxf.configuration.spring.ConfigurerImpl getBeanName
INFO: Could not determine bean name for instance of class org.apache.servicemix.cxf.transport.nmr.NMRConduit.
09.12.2010 11:47:27 org.eclipse.swordfish.plugins.cxf.support.NMROutputStream sendOutputMessage
INFO: {ResponseContext={}, RequestContext={java.lang.reflect.Method=public abstract java.lang.String org.eclipse.swordfish.samples.flightreservation.FlightReservation.reserveFlight(org.eclipse.swordfish.samples.flightreservation.FlightData), org.apache.cxf.jaxws.context.WrappedMessageContext.SCOPES={org.apache.cxf.message.Message.ENDPOINT_ADDRESS=APPLICATION}, org.apache.cxf.message.Message.ENDPOINT_ADDRESS=nmr:FlightReservationService}}
INFO: [MessageInfo INPUT{http://www.eclipse.org/swordfish/samples/FlightReservation/}reserveFlight]
INFO: true
INFO: public abstract java.lang.String org.eclipse.swordfish.samples.flightreservation.FlightReservation.reserveFlight(org.eclipse.swordfish.samples.flightreservation.FlightData)
INFO: true
INFO: false
INFO: {SOAPAction=["http://www.eclipse.org/swordfish/samples/FlightReservation/reserveFlight"]}
INFO: [null]
INFO: UTF-8
INFO: nmr:FlightReservationService
INFO: {}
INFO: {org.apache.cxf.message.Message.ENDPOINT_ADDRESS=APPLICATION}
INFO: org.apache.cxf.service.model.BindingMessageInfo@1bcfbeb
INFO: text/xml
INFO: []
09.12.2010 11:47:27 org.eclipse.swordfish.plugins.cxf.support.NMROutputStream createNMRMessageExchange
INFO: Invoking serviceinterface org.eclipse.swordfish.samples.flightreservation.FlightReservation
INFO: Create messageExchange{http://www.eclipse.org/swordfish/samples/FlightReservation/}FlightReservationService
INFO: Exchange endpoint {http://www.eclipse.org/swordfish/samples/FlightReservation/}FlightReservationService
INFO: setup message contents on Message []
INFO: service for exchange {http://www.eclipse.org/swordfish/samples/FlightReservation/}FlightReservationService
INFO: Sending message
null
09.12.2010 11:47:27 org.apache.servicemix.nmr.management.ManagementEndpointRegistry exchangeSent
WARNUNG: No managed endpoint registered with id: b42ce6aa-771d-4480-94b0-4ca1c7d54e9a
09.12.2010 11:47:27 org.apache.servicemix.common.AsyncBaseLifeCycle processExchangeInTx
SCHWERWIEGEND: Error processing exchange org.apache.servicemix.jbi.runtime.impl.InOutImpl@10bbf6d
org.apache.servicemix.soap.SoapFault: Unrecognized element: html at [1,1]. Expecting 'Envelope'.
    at org.apache.servicemix.soap.marshalers.SoapReader.readSoapUsingStax(SoapReader.java:167)
    at org.apache.servicemix.soap.marshalers.SoapReader.read(SoapReader.java:89)
    at org.apache.servicemix.soap.marshalers.SoapReader.read(SoapReader.java:76)
    at org.apache.servicemix.http.processors.ProviderProcessor.process(ProviderProcessor.java:165)
    at org.apache.servicemix.soap.SoapEndpoint.process(SoapEndpoint.java:368)
    at org.apache.servicemix.common.AsyncBaseLifeCycle.doProcess(AsyncBaseLifeCycle.java:627)
    at org.apache.servicemix.common.AsyncBaseLifeCycle.processExchange(AsyncBaseLifeCycle.java:581)
    at org.apache.servicemix.common.AsyncBaseLifeCycle.processExchangeInTx(AsyncBaseLifeCycle.java:478)
    at org.apache.servicemix.common.AsyncBaseLifeCycle$2.run(AsyncBaseLifeCycle.java:347)
09.12.2010 11:47:27 org.eclipse.swordfish.plugins.planner.policy.PolicyAssertionHintExtractor extractHints
WARNUNG: Couldn't extract hints from terminated (status == DONE) message exchange!
09.12.2010 11:47:27 org.apache.cxf.phase.PhaseInterceptorChain doIntercept
INFO: Interceptor has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: Could not send Message.
    at org.apache.cxf.interceptor.MessageSenderInterceptor$MessageSenderEndingInterceptor.handleMessage(MessageSenderInterceptor.java:64)
    at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:220)
    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:466)
    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:299)
    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:251)
    at org.apache.cxf.frontend.ClientProxy.invokeSync(ClientProxy.java:73)
    at org.apache.cxf.jaxws.JaxWsClientProxy.invoke(JaxWsClientProxy.java:124)
    at $Proxy154.reserveFlight(Unknown Source)
    at org.eclipse.swordfish.samples.flightbooking.FlightBookingImpl.bookFlight(FlightBookingImpl.java:51)
    at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:136)
    at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:82)
    at org.apache.cxf.jaxws.JAXWSMethodInvoker.invoke(JAXWSMethodInvoker.java:54)
    at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:68)
    at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:56)
    at org.apache.cxf.workqueue.SynchronousExecutor.execute(SynchronousExecutor.java:37)
    at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:92)
    at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:78)
    at org.apache.servicemix.cxf.transport.nmr.NMRDestination.process(NMRDestination.java:116)
    at org.apache.servicemix.nmr.core.InternalEndpointWrapper.process(InternalEndpointWrapper.java:86)
    at org.apache.servicemix.nmr.core.ChannelImpl.process(ChannelImpl.java:255)
    at org.apache.servicemix.nmr.core.ChannelImpl$1.run(ChannelImpl.java:215)
Caused by: java.io.IOException: Remote service error
    at org.eclipse.swordfish.plugins.cxf.support.NMROutputStream.sendOutputMessage(NMROutputStream.java:102)
    at org.eclipse.swordfish.plugins.cxf.support.NMROutputStream.doClose(NMROutputStream.java:77)
    at org.apache.cxf.io.CachedOutputStream.close(CachedOutputStream.java:167)
    at org.apache.cxf.transport.AbstractConduit.close(AbstractConduit.java:66)
    at org.apache.cxf.interceptor.MessageSenderInterceptor$MessageSenderEndingInterceptor.handleMessage(MessageSenderInterceptor.java:62)
    ... 28 more
javax.xml.ws.WebServiceException: org.apache.cxf.interceptor.Fault: Could not send Message.
    at org.apache.cxf.jaxws.JaxWsClientProxy.invoke(JaxWsClientProxy.java:142)
Caused by: org.apache.cxf.interceptor.Fault: Could not send Message.
    ... 22 more
    ... 28 more
INFO: Application has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: javax.xml.ws.WebServiceException: org.apache.cxf.interceptor.Fault: Could not send Message.
    at org.apache.cxf.service.invoker.AbstractInvoker.createFault(AbstractInvoker.java:119)
    at org.apache.cxf.jaxws.AbstractJAXWSMethodInvoker.createFault(AbstractJAXWSMethodInvoker.java:83)
    at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:107)
Caused by: java.lang.RuntimeException: javax.xml.ws.WebServiceException: org.apache.cxf.interceptor.Fault: Could not send Message.
    at org.eclipse.swordfish.samples.flightbooking.FlightBookingImpl.bookFlight(FlightBookingImpl.java:67)
    ... 14 more
Caused by: javax.xml.ws.WebServiceException: org.apache.cxf.interceptor.Fault: Could not send Message.
    ... 20 more
    ... 22 more
    ... 28 more
2010-12-09 11:47:27.573::WARN:  ERROR:  /FlightBooking_Service/
    ... 14 more
    ... 20 more
    ... 22 more
    ... 28 more
The endpoints of 'FlightReservation' and 'PaymentProcessing' are:
http://localhost:8197/PaymentProcessing_Service/
Sorry for the long message but I just thought I give u everything I get.
Thanks so much for your help.
Christian
Previous Topic:IWAB0135E An unexpected error has occurred. 500 javax.xml.ws.WebServiceException
Next Topic:Need help to implement Federated SOA using Swordfish
Current Time: Thu Sep 25 01:27:16 EDT 2025
Powered by FUDForum. Page generated in 0.03912 seconds
