Re: VE 1.5 release review [message #642743 is a reply to message #642716] |
Thu, 02 December 2010 15:12 |
Originally posted by: pb158.tlen.pl
W dniu 02.12.2010 14:39, Yves YANG pisze:
> Hi All,
> VE team is pleased to announce the project review of the release 1.5 is
> successful, which supports eclipse Helios. A stable release will be
> published today and accessible via both local and remote installation.
Already installed :) thanks
P.S.
Can you add in future versions of VE JFormattedTextField class to the
palette?
Re: VE 1.5 release review [message #644688 is a reply to message #644504] |
Mon, 13 December 2010 19:01 |
Originally posted by: richkulp.us.NOSPAM.ibm.com
By default on a java file the Java editor is the default editor. But
once you open as a different editor (such as VE), that editor then
becomes the default. It stores this in the workspace, not in a CVS/Team/etc.
When you created the class you probably used a VE wizard so that the
class was opened up with VE immediately, and so VE becomes the default
for that class instance.
So when you are on a new computer you are in a new workspace so it
switches to the default java editor. You can then do Open As -> and
select the VE instead.
Rich Kulp
FUDForum. Page generated in 5.04282 seconds
