Bundle Classpath Container not populated from Virgo repository [message #642489] |
Wed, 01 December 2010 15:08 |
I am using STS 2.5.1 and the "Bundle Dependencies" are not being populated from the Virgo v2.1 repository. I have found that I can force these to be loaded by adding all bundles in the repository using "Import Bundle" in the Manifest editor. The imports immediately disappear from the Manifest because I have incremental generation enabled, but it has the side effect of populating the Bundle Dependencies. Unfortunately these are all lost on the next incremental generation.
Is this a know issue? Do I have the workflow all wrong?
Btw, I tried this on a clean STS 2.5.1 install to make certain that this is not being caused by clashes with some other plug-in.
There are no errors or warnings being generated in the Eclipse log.
I am running on Mac OS X 10.6.5 using Java 1.6.0_22 and springsource-tool-suite-2.5.1.RELEASE-e3.6.1-macosx-cocoa-x8 6_64
Many thanks,
Joel
[Updated on: Wed, 01 December 2010 15:09] Report message to a moderator
FUDForum. Page generated in 0.03405 seconds
