Home » Eclipse Projects » Mylyn » Is there a list of mediawiki markup tags supported for wikitext
Is there a list of mediawiki markup tags supported for wikitext [message #642466] Wed, 01 December 2010 08:18 Go to next message
We have started to use Myln Wikitekt and FOP to automagically generate some documentation.
We have a mediawiki server that we convert documents from to XSL-FO with Mylyn wikitext and then to PDF using Apache FOP. This is wrapped up on a Hudson build server.
Then I get into some trial and error on different Mediawiki markups that are supported by wikitext.
I have tied to read documentation, but can't find a list of which markups are supported.
Is there such a list?
So far it seems that at least <code>, and [[File:....]] is not supported. Also I have problems with the indent markup ':'.
Having a list will help me understand better what I currently can use and not in my wiki pages.
If a markup is not supported I guess it is a matter of looking into the source code and add a patch for the given markup?
Per A.
Re: Is there a list of mediawiki markup tags supported for wikitext [message #644388 is a reply to message #642466] Fri, 10 December 2010 13:42 Go to previous message
Arnold,
Your application of Mylyn WikiText sounds great! Comments below:
On 12/1/2010 5:18 AM, Per Arnold Blaasmo wrote:
> some documentation.
Here's the list:
* headings
* lists (starting with * and #)
* definition lists
* preformatted blocks (lines starting with a space)
* tables
* table of contents (__TOC__)
* <nowiki>
* bold, italic, bolditalic
* HTML tags
* HTML comments
* (tm), (c), (r)
* images ([Image:])
* hyperlinks
* hr via ----
* entity references
* templates when using mediawiki-to-eclipse-help Ant task
You bet, any contributions that you have in this area are very welcome.
The best way to get started is to take a look at
org.eclipse.mylyn.wikitext.mediawiki.core.MediaWikiLanguage. Also any
new markup support should have corresponding JUnit tests (See
MediaWikiLanguageTest)
David
> Regards
> Per A.
Previous Topic:Work log description
Next Topic:do any mylyn task repositories support gantt charts?
Current Time: Sat Jul 19 02:25:51 EDT 2025
Powered by FUDForum. Page generated in 0.27506 seconds
