Re: eclipse locks up on egit commit [message #642320 is a reply to message #642124] |
Tue, 30 November 2010 19:07 |
justin Messages: 4 Registered: November 2010 |
I've gone through all the tracked files (of which there quite a few) and made sure no binary files are being tracked, I figured this should ensure as fast a result as possible, but it's still a 20 minute wait to get the commit window up.
Here is the trace dump, I'm posting it here because at the moment I'm not sure this is a bug or just something I'm doing due to noob status. From what I've read Git is one of the preffered methods of version tracking, but I can't believe that I'm bringing it to it's knees with my set of files. I can't seem to find a way of it telling me how many files it's tracking or their overall size, I would guess something like just under 100 files, however they are in a project that contains probably over 50,000 (lots of assets and images that don't need version control, I really just want it for the code)
2010-11-30 10:47:18
Full thread dump Java HotSpot(TM) Client VM (17.1-b03 mixed mode, sharing):
"Worker-11" prio=6 tid=0x02d8c400 nid=0x104 in Object.wait() [0x0465f000]
java.lang.Thread.State: TIMED_WAITING (on object monitor)
at java.lang.Object.wait(Native Method)
at org.eclipse.core.internal.jobs.WorkerPool.sleep(WorkerPool.j ava:185)
- locked <0x1c0b2fc8> (a org.eclipse.core.internal.jobs.WorkerPool)
at org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPoo l.java:217)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:51)
Locked ownable synchronizers:
- None
"Worker-9" prio=6 tid=0x10457400 nid=0xa74 in Object.wait() [0x0f14f000]
- None
"JavaScript indexing" daemon prio=4 tid=0x05601400 nid=0xe4 in Object.wait() [0x06b7f000]
java.lang.Thread.State: WAITING (on object monitor)
- waiting on <0x2087ccb8> (a org.eclipse.wst.jsdt.internal.core.search.indexing.IndexMana ger)
at java.lang.Object.wait(Object.java:485)
at org.eclipse.wst.jsdt.internal.core.search.processing.JobMana ger.run(JobManager.java:370)
- locked <0x2087ccb8> (a org.eclipse.wst.jsdt.internal.core.search.indexing.IndexMana ger)
- None
"[ThreadPool Manager] - Idle Thread" daemon prio=6 tid=0x03e96400 nid=0x148 in Object.wait() [0x0714f000]
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Execut or.run(Executor.java:106)
- locked <0x1fb13558> (a org.eclipse.equinox.internal.util.impl.tpt.threadpool.Execut or)
- None
"Java indexing" daemon prio=4 tid=0x03fb5c00 nid=0x5f0 in Object.wait() [0x06e7f000]
- waiting on <0x1f927d18> (a org.eclipse.jdt.internal.core.search.indexing.IndexManager)
at org.eclipse.jdt.internal.core.search.processing.JobManager.r un(JobManager.java:381)
- locked <0x1f927d18> (a org.eclipse.jdt.internal.core.search.indexing.IndexManager)
- None
"PHP Debugger Daemon Thread - Port: 9000" daemon prio=6 tid=0x03ee2c00 nid=0xa14 runnable [0x06d7f000]
java.lang.Thread.State: RUNNABLE
at java.net.PlainSocketImpl.socketAccept(Native Method)
at java.net.PlainSocketImpl.accept(Unknown Source)
- locked <0x1f84a5e0> (a java.net.SocksSocketImpl)
at java.net.ServerSocket.implAccept(Unknown Source)
at java.net.ServerSocket.accept(Unknown Source)
at org.eclipse.php.internal.debug.core.daemon.AbstractDebuggerC ommunicationDaemon$ReceiverThread.run(AbstractDebuggerCommun icationDaemon.java:185)
- None
"PHP Debugger Daemon Thread - Port: 10000" daemon prio=6 tid=0x0500f000 nid=0xa1c runnable [0x06a7f000]
- locked <0x1f84a7c8> (a java.net.SocksSocketImpl)
- None
"DLTK indexing" daemon prio=4 tid=0x035cf000 nid=0x85c in Object.wait() [0x0697f000]
- waiting on <0x1f6fb928> (a org.eclipse.dltk.core.search.indexing.IndexManager)
at org.eclipse.dltk.internal.core.search.processing.JobManager. run(JobManager.java:426)
- locked <0x1f6fb928> (a org.eclipse.dltk.core.search.indexing.IndexManager)
- None
"net.sourceforge.phpdt.internal.ui.text.JavaReconciler" daemon prio=2 tid=0x050b2400 nid=0x17c in Object.wait() [0x061bf000]
at org.eclipse.jface.text.reconciler.AbstractReconciler$Backgro undThread.run(AbstractReconciler.java:179)
- locked <0x1f58c118> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
- None
"Bundle File Closer" daemon prio=6 tid=0x05025c00 nid=0x204 in Object.wait() [0x05e0f000]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .getNextEvent(EventManager.java:397)
- locked <0x1f273670> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:333)
- None
"[Timer] - Main Queue Handler" daemon prio=6 tid=0x03d25400 nid=0x95c in Object.wait() [0x0441f000]
at org.eclipse.equinox.internal.util.impl.tpt.timer.TimerImpl.r un(TimerImpl.java:141)
- locked <0x1c1c0710> (a java.lang.Object)
- None
"Provisioning Event Dispatcher" daemon prio=6 tid=0x03ccc400 nid=0xe48 in Object.wait() [0x0421f000]
- waiting on <0x1c0b2ed8> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- locked <0x1c0b2ed8> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- None
"Worker-0" prio=6 tid=0x03c8d400 nid=0x9d8 waiting on condition [0x0411f000]
java.lang.Thread.State: WAITING (parking)
at sun.misc.Unsafe.park(Native Method)
- parking to wait for <0x1f7fb528> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$Condit ionObject)
at java.util.concurrent.locks.LockSupport.park(Unknown Source)
at java.util.concurrent.locks.AbstractQueuedSynchronizer$Condit ionObject.await(Unknown Source)
at java.util.concurrent.LinkedBlockingQueue.take(Unknown Source)
at org.eclipse.epp.usagedata.internal.gathering.services.UsageD ataService.getQueuedEvent(UsageDataService.java:221)
at org.eclipse.epp.usagedata.internal.gathering.services.UsageD ataService.access$0(UsageDataService.java:219)
at org.eclipse.epp.usagedata.internal.gathering.services.UsageD ataService$1.run(UsageDataService.java:157)
- None
"Framework Event Dispatcher" daemon prio=6 tid=0x03627800 nid=0x98c in Object.wait() [0x03b7f000]
- locked <0x1bf87308> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- None
"Start Level Event Dispatcher" daemon prio=6 tid=0x0361d400 nid=0x784 in Object.wait() [0x03a7f000]
- waiting on <0x1bf87380> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- locked <0x1bf87380> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- None
"State Data Manager" daemon prio=6 tid=0x03631400 nid=0xca8 waiting on condition [0x0397f000]
java.lang.Thread.State: TIMED_WAITING (sleeping)
at java.lang.Thread.sleep(Native Method)
at org.eclipse.osgi.internal.baseadaptor.StateManager.run(State Manager.java:306)
- None
"Low Memory Detector" daemon prio=6 tid=0x02ccc400 nid=0xc60 runnable [0x00000000]
- None
"CompilerThread0" daemon prio=10 tid=0x02cc6800 nid=0xd64 waiting on condition [0x00000000]
- None
"Attach Listener" daemon prio=10 tid=0x02cc5000 nid=0x3b4 waiting on condition [0x00000000]
- None
"Signal Dispatcher" daemon prio=10 tid=0x02cc3c00 nid=0x27c runnable [0x00000000]
- None
"Finalizer" daemon prio=8 tid=0x02cbcc00 nid=0x35c in Object.wait() [0x0309f000]
at java.lang.ref.ReferenceQueue.remove(Unknown Source)
- locked <0x1bee0318> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)
- None
"Reference Handler" daemon prio=10 tid=0x02cbb400 nid=0xf50 in Object.wait() [0x02f9f000]
at java.lang.ref.Reference$ReferenceHandler.run(Unknown Source)
- locked <0x1bee03a8> (a java.lang.ref.Reference$Lock)
- None
"main" prio=6 tid=0x009c6800 nid=0x944 runnable [0x0013e000]
at java.util.ArrayList.indexOf(Unknown Source)
at java.util.ArrayList.contains(Unknown Source)
at org.eclipse.egit.ui.internal.actions.CommitActionHandler.inc ludeList(CommitActionHandler.java:324)
at org.eclipse.egit.ui.internal.actions.CommitActionHandler.bui ldIndexHeadDiffList(CommitActionHandler.java:304)
at org.eclipse.egit.ui.internal.actions.CommitActionHandler.exe cute(CommitActionHandler.java:89)
at org.eclipse.egit.ui.internal.actions.RepositoryAction.run(Re positoryAction.java:77)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3910)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3503)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
- None
"VM Thread" prio=10 tid=0x02cb9c00 nid=0x9a4 runnable
"VM Periodic Task Thread" prio=10 tid=0x02cd7800 nid=0x764 waiting on condition
JNI global references: 1686
FUDForum. Page generated in 0.01777 seconds
