p2 update site appearance [message #642067] |
Mon, 29 November 2010 17:51 |
Richard Adams Messages: 77 Registered: July 2009 Location: Edinburgh |
Member |
Hello
For our RCP app based on EClipse 3.5.2 we have a p2 update site.
Our features on the update site are simple single plugins wrapped in a feature, and each feature is in its own category (www.sbsi.ed.ac..uk/update)
But for some reason instead of a single feature entry appearing within the category we get info about the plugin as well. I.e., there are two entries. Has anyone else had this problem? Would appreciate any replies,
Thanks very much
Richard
Here is the p2 config in our build.xml
runPackager=true
p2.gathering=true
p2.flavor=ParallelDimensionView
p2.publish.artifacts=true
p2.compress=true
and here is the content.xml generated:
<?xml version='1.0' encoding='UTF-8'?>
<?metadataRepository version='1.1.0'?>
<repository name='file:/Users/radams/PDVIEWBUILDS/PDViewRepo - metadata' type='org.eclipse.equinox.internal.p2.metadata.repository.Lo calMetadataRepository' version='1.0.0'>
<properties size='2'>
<property name='p2.timestamp' value='1291051057471'/>
<property name='p2.compressed' value='false'/>
</properties>
<references size='2'>
<repository uri='http://www.sbsi.ed.ac.uk/update' url='http://www.sbsi.ed.ac.uk/update' type='0' options='0'/>
<repository uri='http://www.sbsi.ed.ac.uk/update' url='http://www.sbsi.ed.ac.uk/update' type='1' options='0'/>
</references>
<units size='3'>
<unit id='uk.ac.ed.csbe.sbsivisual.paralleldimensionview' version='1.0.1.201011291717'>
<update id='uk.ac.ed.csbe.sbsivisual.paralleldimensionview' range='[0.0.0,1.0.1.201011291717)' severity='0'/>
<property name='org.eclipse.equinox.p2.name' value='Parallel Dimension View'/>
<property name='org.eclipse.equinox.p2.provider' value='Centre for Systems Biology, Edinburgh'/>
</properties>
<provides size='4'>
<provided namespace='org.eclipse.equinox.p2.iu' name='uk.ac.ed.csbe.sbsivisual.paralleldimensionview' version='1.0.1.201011291717'/>
<provided namespace='osgi.bundle' name='uk.ac.ed.csbe.sbsivisual.paralleldimensionview' version='1.0.1.201011291717'/>
<provided namespace='java.package' name='uk.ac.ed.csbe.sbsivisual.paralleldimensionview' version='0.0.0'/>
<provided namespace='org.eclipse.equinox.p2.eclipse.type' name='bundle' version='1.0.0'/>
</provides>
<requires size='4'>
<required namespace='osgi.bundle' name='org.eclipse.ui' range='0.0.0'/>
<required namespace='osgi.bundle' name='org.eclipse.core.runtime' range='0.0.0'/>
<required namespace='osgi.bundle' name='org.eclipse.core.resources' range='3.5.2'/>
<required namespace='osgi.bundle' name='org.eclipse.draw2d' range='3.5.2'/>
</requires>
<artifacts size='1'>
<artifact classifier='osgi.bundle' id='uk.ac.ed.csbe.sbsivisual.paralleldimensionview' version='1.0.1.201011291717'/>
</artifacts>
<touchpoint id='org.eclipse.equinox.p2.osgi' version='1.0.0'/>
<touchpointData size='1'>
<instructions size='1'>
<instruction key='manifest'>
Bundle-ManifestVersion: 2
Export-Package: uk.ac.ed.csbe.sbsivisual.paralleldimensionview
Bundl e-RequiredExecutionEnvironment: J2SE-1.5
Require-Bundle: org.eclipse.ui,org.eclipse.core.runtime,org.eclipse.core.res ources;bundle-version="3.5.2",org.eclipse. draw2d;bundle-version="3.5.2"
Bund le-Activator: uk.ac.ed.csbe.sbsivisual.paralleldimensionview.Activator& ;#xA;Bundle-Name: Parallel Dimension View
Bundle-Version: 1.0.1.201011291717
Bundle-Vendor: Centre for Systems Biology, Edinburgh
Bundle-SymbolicName: uk.ac.ed.csbe.sbsivisual.paralleldimensionview;singleton:=tr ue
Bundle-ActivationPolicy: lazy
Manifest-Version: 1.0
Bundle-ClassPath: lib/commons-io-1.4.jar,.
</instruction>
</instructions>
</touchpointData>
</unit>
<unit id='uk.ac.ed.csbe.sbsivisual.paralleldimensionview.feature.f eature.group' version='1.0.1.201011291717' singleton='false'>
<update id='uk.ac.ed.csbe.sbsivisual.paralleldimensionview.feature.f eature.group' range='[0.0.0,1.0.1.201011291717)' severity='0'/>
<properties size='6'>
<property name='org.eclipse.equinox.p2.name' value='Visualizations for Parameter Optimization'/>
<property name='org.eclipse.equinox.p2.description' value=''/>
<property name='org.eclipse.equinox.p2.description.url' value='http://www.sbsi.ed.ac.uk/update'/>
<property name='org.eclipse.equinox.p2.provider' value='CSBE, University of Edinburgh'/>
<property name='org.eclipse.equinox.p2.type.group' value='true'/>
<property name='org.eclipse.equinox.p2.type.category' value='true'/>
</properties>
<provides size='1'>
<provided namespace='org.eclipse.equinox.p2.iu' name='uk.ac.ed.csbe.sbsivisual.paralleldimensionview.feature .feature.group' version='1.0.1.201011291717'/>
</provides>
<requires size='6'>
<required namespace='org.eclipse.equinox.p2.iu' name='org.eclipse.ui' range='0.0.0'/>
<required namespace='org.eclipse.equinox.p2.iu' name='org.eclipse.core.runtime' range='0.0.0'/>
<required namespace='org.eclipse.equinox.p2.iu' name='org.eclipse.core.resources' range='3.5.2'/>
<required namespace='org.eclipse.equinox.p2.iu' name='org.eclipse.draw2d' range='3.5.2'/>
<required namespace='org.eclipse.equinox.p2.iu' name='uk.ac.ed.csbe.sbsivisual.paralleldimensionview' range='[1.0.1.201011291717,1.0.1.201011291717]'/>
<required namespace='org.eclipse.equinox.p2.iu' name='uk.ac.ed.csbe.sbsivisual.paralleldimensionview.feature .feature.jar' range='[1.0.1.201011291717,1.0.1.201011291717]'>
<filter>
(org.eclipse.update.install.features=true)
</filter>
</required>
</requires>
<touchpoint id='null' version='0.0.0'/>
<touchpointData size='1'/>
<licenses size='1'>
<license>
</license>
</licenses>
<copyright>
Copyright Centre for Systems Biology Edinburgh, University of
Edinburgh, 2010
</copyright>
</unit>
<unit id='uk.ac.ed.csbe.sbsivisual.paralleldimensionview.feature.f eature.jar' version='1.0.1.201011291717'>
<properties size='5'>
<property name='org.eclipse.update.feature.plugin' value='uk.ac.ed.csbe.sbsivisual.paralleldimensionview'/>
</properties>
<provides size='3'>
<provided namespace='org.eclipse.equinox.p2.iu' name='uk.ac.ed.csbe.sbsivisual.paralleldimensionview.feature .feature.jar' version='1.0.1.201011291717'/>
<provided namespace='org.eclipse.equinox.p2.eclipse.type' name='feature' version='1.0.0'/>
<provided namespace='org.eclipse.update.feature' name='uk.ac.ed.csbe.sbsivisual.paralleldimensionview.feature ' version='1.0.1.201011291717'/>
</provides>
<filter>
</filter>
<artifact classifier='org.eclipse.update.feature' id='uk.ac.ed.csbe.sbsivisual.paralleldimensionview.feature' version='1.0.1.201011291717'/>
</artifacts>
<instruction key='zipped'>
true
</instruction>
</instructions>
</touchpointData>
<licenses size='1'>
<license>
</license>
</licenses>
<copyright>
Edinburgh, 2010
</copyright>
</unit>
</units>
</repository>
Dr Richard Adams, University of Edinburgh
http://richardadams606blog.blogspot.com/
http://csbe.bio.ed.ac.uk/adams.php
FUDForum. Page generated in 0.03366 seconds
