How to create a database object by code [message #641953] |
Mon, 29 November 2010 11:07 |
Henzler Peter Messages: 19 Registered: July 2009 |
I would like to use the datatools plugins to validate a DB2 SQL query against a DB2 database.
I found this description:
http://www.eclipse.org/datatools/project_sqldevtools/sqltool s_doc/SQL%20Query%20Parser%20User%20documentation.htm
But I cant find out how to get the Database object for the desired DB2 database to validate the tables and fields like described under 2.3
The code below is not working, because
managedConnection.getConnection().getRawConnection()
can not be cast to ConnectionInfo.
Can anyone help?
Properties baseProperties = new Properties();
baseProperties
.setProperty(
IDriverMgmtConstants.PROP_DEFN_JARLIST,
"C:\\Program Files\\IBM\\IBM Data Studio stand-alone\\plugins\\com.ibm.datatools.db2_2.1.102.v2009102 4_0211\\driver\\db2jcc.jar ");
baseProperties.setProperty(IJDBCDriverDefinitionConstants.DA TABASE_CATEGORY_ID,
ILUWConnectionProfileConstants.DB2_LUW_CATEGORY_ID);
baseProperties.setProperty(IJDBCConnectionProfileConstants.D ATABASE_NAME_PROP_ID, "SCODIREP");
baseProperties.setProperty(IJDBCConnectionProfileConstants.D RIVER_CLASS_PROP_ID, "com.ibm.db2.jcc.DB2Driver");
baseProperties.setProperty(IJDBCConnectionProfileConstants.U RL_PROP_ID, "jdbc:db2://localhost:50000/SCODIREP");
baseProperties.setProperty(IJDBCConnectionProfileConstants.U SERNAME_PROP_ID, user);
baseProperties.setProperty(IJDBCConnectionProfileConstants.P ASSWORD_PROP_ID, password);
baseProperties.setProperty(IJDBCConnectionProfileConstants.D ATABASE_VENDOR_PROP_ID, "DB2 UDB");
baseProperties.setProperty(IJDBCConnectionProfileConstants.D ATABASE_VERSION_PROP_ID, "V9.1");
// baseProperties.setProperty( IJDBCConnectionProfileConstants.SAVE_PASSWORD_PROP_ID, String.valueOf( true ) );
IConnectionProfile profile = null;
try {
profile = ProfileManager.getInstance().createTransientProfile(
" org.eclipse.datatools.enablement.ibm.db2.luw.connectionProfi le ", baseProperties);
} catch (ConnectionProfileException e) {
e.printStackTrace();
org.eclipse.datatools.enablement.ibm.db2.internal.luw.JDBCLU WConnectionFactory fac = new JDBCLUWConnectionFactory();
IConnection iConnection = fac.createConnection(profile, user, password);
Database db = null;
IManagedConnection managedConnection = iConnection.getConnectionProfile().getManagedConnection(
" org.eclipse.datatools.connectivity.sqm.core.connection.Conne ctionInfo ");
if (managedConnection != null) {
try {
ConnectionInfo connectionInfo = (ConnectionInfo) managedConnection.getConnection().getRawConnection();
if (connectionInfo != null) {
db = connectionInfo.getSharedDatabase();
} catch (Exception e) {
throw new ValidationException("db", e);
Re: How to create a database object by code [message #642552 is a reply to message #641953] |
Wed, 01 December 2010 18:37 |
Brian Fitzpatrick Messages: 500 Registered: July 2009 |
Hi there...
There's some details here: http://wiki.eclipse.org/DTP_FAQ that should
help you create a transient connection profile and then get the database
model for the connection profile... See specifically "Q: How do I get at
the database model from my connected connection profile?" and "Q: How do
I create a Transient connection profile vs. a Persisted profile?"
Hope that helps!
--Fitz
Henzler Peter wrote:
> Hi
> Can anyone help?
> baseProperties
> .setProperty(
> TABASE_CATEGORY_ID,
> true ) );
> try {
> profile =
> baseProperties);
> user, password);
> Database db = null;
> try {
FUDForum. Page generated in 0.02856 seconds
